הדיון הראשי על הדרייבר-AM​​D Catalyst (שוחרר AMD Catalyst™ 15.3 beta)
אחרי חודשים של המתנה וגרסאות בטא, שוחרר דרייבר רשמי AMD Catalyst 13.12 WHQL :
גרסת 32 סיביות להורדה:
http://sites.amd.com/us/game/downloads/Pages/radeon_win8-32.aspx#1
גרסת 64 סיביות להורדה:
http://sites.amd.com/us/game/downloads/Pages/radeon_win8-64.aspx
מערכות הפעלה נתמכות:
Windows Vista, 7, 8 and 8.1.
תומך בסדרות כרטיסים:
HD5000, HD6000, HD7000, R7, R9
כרטיסים חדשים שנתמכים:
AMD Radeon R9 290, 280, and 270 Series
AMD Radeon R7 260, 250, and 240 Series
שיפורים חדשים:
​Improved AMD CrossFire​ scaling for the following game titles:
  • Call of Duty: Ghosts (multiplayer component)
  • Splinter Cell Blacklist
  • Saints Row 4
  • Metro Last Light
​New AMD Enduro Technology profiles for the following game titles:
  • XCOM: Enemy Unknown
  • Need for Speed Rivals
  • Total War​: Rome 2
  • Battlefield 4
  • Saints Row 4
  • FIFA 14
​Support For AMD CrossFire frame pacing
  • Frame pacing ensures that frames rendered across multiple GPUs in an AMD CrossFire configuration will be displayed at an even and regular pace
  • Frame pacing is enabled through the AMD Catalyst Control Center, or on a per application basis
  • Frame pacing is supported on DirectX 10 and DirectX 11 applications using resolutions up to (and including) 2560x1600 on a single display
בעיות שנפתרו:
  • May resolve intermittent black screens or display loss observed on some AMD Radeon R9 290X and AMD Radeon R9 290 graphics cards
  • Resolves intermittent crashes seen in legacy DirectX 9 applications
  • AMD Radeon R9 290 Series - Power Tune update to reduce variance of fan speed / RPM
  • PCI-E bus speed is no longer set to x1 on the secondary GPU when running in an AMD CrossFire configuration
  • Resolves incorrect HDMI Audio Driver information being listed in the AMD Catalyst Control Center
  • Resolves AMD Steady Video option being grayed out in the AMD Catalyst Control Center
  • Resolves intermittent flickering seen on some AMD Radeon R9 270X graphics cards
  • Resolves graphics corruption issues found in Starcraft
  • Resolves image corruption seen in Autodesk Investor 2014
  • Resolves flickering water corruption found in World of Warcraft
  • Resolves intermittent black screen when resuming from a S3/S4 sleep-state if the display is unplugged during the sleep-state on systems supporting AMD Enduro Technology
  • Resolves intermittent crashes experienced with Battlefield 4 on Windows 8 based systems
  • Resolves the display turning green when using Windows Media Player to view HD .avi format video in an extended desktop configuration
  • Resolves Metro applications experiencing frame drops during playback of interlaced video content
  • Resolves video playback corruption of .wmv format files in Windows Media Player
נערך על-ידי idanmal
  • תגובות 303
  • צפיות 204.5k
^לא ראיתי שום אזכור לזה :nixweiss:
משום מה לא מופיע לי כלום בדף ההורדות. אפשר קישור לWINDOWS 8.1 X64?
עם 12.13 קיבלתי מסך כחול ומשחקים מתרסקים לדסקטופ. חזרתי לבטא.
יש מצב שנשארו שאריות מדרייבר קודם, אצלי עובד בסדר גמור.
לא הבנתי למה לא שחררו 13.11 רשמי (הכוונה לא בטא) וישר הוציאו 13.12?
כי בדרך כלל תמיד הבטא גרסה קדימה מהרשמי עד כמה שאני זוכר, או שאני טועה?
אין לזה חוקים, לדעתי כבר נמאס להם מהמספר 13.11 אחרי כמה חודשים של בצורת מבחינת גרסה רשמית ורצו להתחדש עם מספר חדש, עם כמה שזה ישמע מצחיק.
גם יותר קל לחפש 13.12 מאשר עכשיו להתחיל להתבלבל בין כל הגרסאות בטא שהיו ל-13.11.
מספרי הגרסאות הן לפי השנה והחודש שבו הדרייבר אמור לצאת.
את זה לא ידעתי :-)
זה ממש לא כלל, גם אם ב AMD נוהגים כך...
איך נקבע איזה Pixel Shader version או Vertex Shader version מתאים לכרטיס מסך?
לפי מה שאני מבין, מדובר בקבצים שקשורים לדרייברים או משהו כזה, או שאני טועה?
זה חומרתי.
אוקיי, ויש טבלה עם דגם כרטיס וגרסה שמתאימה לו?
