מסך כחול במחשב נייח וינדוס 7
בדקתי את הארד דיסק עם התוכנה Acronis Drive Monitor והוא תקין .
זה הדו"ח שקיבלתי :
On Sun 13/10/2013 13:21:08 GMT your computer crashed
crash dump file: C:\Windows\Minidump\101313-181865-01.dmp
uptime: 00:24:13
This was probably caused by the following module: symevent.sys (SYMEVENT+0x14A69)
Bugcheck code: 0x1A (0x8886, 0xFFFFFFFF84EC2B90, 0xFFFFFFFF84EC1000, 0x502)
Error: MEMORY_MANAGEMENT
file path: C:\Windows\system32\drivers\symevent.sys
product: SYMEVENT
company: Symantec Corporation
description: Symantec Event Library
Bug check description: This indicates that a severe memory management error occurred.
This might be a case of memory corruption. More often memory corruption happens because of software errors in buggy drivers, not because of faulty RAM modules.
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: symevent.sys (Symantec Event Library, Symantec Corporation).
Google query: Symantec Corporation MEMORY_MANAGEMENT
מה של סימנטק מותקן אצלך ? תעדכן אותו.
יש לי אנטי וירוס נורטון
לפי הדוח ששמת הוא הגורם.
