Crysis 3 - הדיון הראשי.
ניראה מעניין
אבל לא באמת אפשר לצפות להצלחה של ההרחבה
בכל מקרה אני אקנה אותה
  • תגובות 175
  • צפיות 29k
Patch 1.4 זמין
Multiplatform
XP Bonus module now applies to kill assists
Issues with Rip & Throw items getting out of sync between client and server fixed
All after match awards count towards getting dog tags, not just the three displayed on the progression screen
Support bonuses on Brooklyn Bridge changed
Support bonuses on Hell's Kitchen changed
Retriever rank 3 now displays the correct Max Suit timer on the HUD
Fix for tagging icon incorrectly displaying after player respawn
Trying to zoom to second stage during iron sight no longer melees and breaks you out of zoom
Fix for win/loss stats in Hunter game mode
Fix for Maximum Suit moving slower than intended when activated when in Armour mode
Explosive damage to targets now provides assist points when they are killed
Brought "Survival Instinct" skill assessment in line with the UI text
Fix for Surveillance failing to prevent the user being tagged when at rank 3
Fix for reduced recoil when tapping fire
Fix for team switching in Assault resulting in having the wrong loadout for the side you are on
Fix for Expanded Arsenal module giving 3 additional JAW rockets instead of 1
Reduced caching of player profiles in the lobby so player stats are more up to date
Ripped off HMGs now have consistent accuracy when ADS
Fixes for some Max Suit issues when triggered just as the player is dying
PC Only
Iron sight sensitivity override fix
Added ability to disable HMGs and auto unlock attachments on unranked servers
Transition from ranked prematch to unranked ingame now respawns players correctly
Fixed issues with Ping attack not rebinding when Melee is rebound
אני לא יודע מה הם חושבים שם בקרייטק, נראה להם שזה COD שאנשים ייקנו חבילת מפות ב - 15$ ? ה - MP של המשחק לא פופולארי בעליל ובקושי יש אנשים שמשחקים בו.
דווקא הסינגל של המשחק היה לא רע יחסית אבל מאד קצר אבל במקום הרחבה בשבילו הם מוציאים תוספת ל - MP שלא מעניין אף אחד.
הם יכלו למכור את זה ב-10$ ואז אף אחד לא היה מתלונן. אבל נראה לי שיש כאן השקעה.
להבדיל מ COD יש כאן מפות בסביבות שונות לחלוטין שדרשו קצת יותר עבודה, מה גם שלא נראה לי שהיו חלק מהפיתוח אלא התווספו עכשיו.
מה שבטוח זה שהיה כדאי שהתוכן למשחק יהיה לסינגל ולא למולטי השומם משחקנים
בהחלט הרחבה למולטי היא רעיון גרוע
אבל אולי הם מנסים לשקם את המולטי בעזרת ההרחבה הזאת .. אולי הם סוף סוף יפתיעו לטובה
לגבי המחיר
15 דולר מחיר סביר ל 4 מפות ושתי מודים
אבל כמובן במידה והמפות\מודים לא ימותו לאחר כמה ימים כמו שקרה בקרייסיס הקודם
ההרחבה שוחררה במחיר של 14.99 אירו !
http://youtu.be/fCnDEInd7UM יסיים להעלות עוד כמה דקות..
המוד השני - Team possession
  • 1 חודש מאוחר יותר...
חברים יקרים צריך את עזרתכם!!!!
אני תקוע בשלב WELCOME TO THE JUNGLE
לקחתי את היד הביונית ואני צריך להרוס את המיגדל שיורה עלי עם הליזר,
הבעיה שאין לי "כדורים" בנשק.....
מה לעשות לא יכול להתקדם.
עזרתכם ,תודה.
עזרתכם ,תודה.
זה אומר שיש לך את המשחק הפרוץ ולא המקורי (:
נכון היה לי את הפרוץ,אתמול קניתי את המקורי...
איך אני נפתר מהשמירות של הפרוץ?
גם שאני מתחיל את המשחק מהתחלה הוא עדיין לא מראה לי את האותיות במשחק וכו'...
בספריית LogBackups מופיע log 1 tאחרון מהיום,שאני נכנס למשחק אני עדיין רואה שיש את הישנים מהפרוץ...\
מה לעשות עזרתכם המהירה
תודה.
