בעיית wifi ב-tplink 1043ND
עדכון:
עדיין הנתב מאוד מאכזב - לאחר החלפת נתב, עדכון גרסא, החלפת כבלים, שינוי מיקום, הרצתי היום בדיקת פינג - תוצאות:
CHNNEL 3:
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\Udi>ping 192.168.1.1 -t
Pinging 192.168.1.1 with 32 bytes of data:
Request timed out.
Reply from 192.168.1.1: bytes=32 time=652ms TTL=64
Reply from 192.168.1.1: bytes=32 time=268ms TTL=64
Reply from 192.168.1.1: bytes=32 time=178ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=332ms TTL=64
Request timed out.
Ping statistics for 192.168.1.1:
Packets: Sent = 7, Received = 4, Lost = 3 (42% loss),
Approximate round trip times in milli-seconds:
Minimum = 178ms, Maximum = 652ms, Average = 357ms
Channel 1:
Request timed out.
Reply from 192.168.1.100: Destination host unreachable.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Reply from 192.168.1.1: bytes=32 time=569ms TTL=64
Reply from 192.168.1.1: bytes=32 time=1ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3ms TTL=64
Reply from 192.168.1.1: bytes=32 time=2ms TTL=64
Reply from 192.168.1.1: bytes=32 time=3871ms TTL=64
Reply from 192.168.1.1: bytes=32 time=403ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=219ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=55ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=504ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1261ms TTL=64
Reply from 192.168.1.1: bytes=32 time=303ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=713ms TTL=64
Reply from 192.168.1.1: bytes=32 time=27ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=480ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1236ms TTL=64
Reply from 192.168.1.1: bytes=32 time=302ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=993ms TTL=64
Reply from 192.168.1.1: bytes=32 time=51ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=443ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=1200ms TTL=64
Request timed out.
Reply from 192.168.1.1: bytes=32 time=262ms TTL=64
Channel 6:
C:\Users\Udi>PING 192.168.1.1 -t
Reply from 192.168.1.1: bytes=32 time=3597ms TTL=64
Reply from 192.168.1.1: bytes=32 time=307ms TTL=64
Reply from 192.168.1.1: bytes=32 time=221ms TTL=64
Reply from 192.168.1.1: bytes=32 time=44ms TTL=64
Reply from 192.168.1.1: bytes=32 time=86ms TTL=64
Reply from 192.168.1.1: bytes=32 time=297ms TTL=64
Reply from 192.168.1.1: bytes=32 time=203ms TTL=64
Reply from 192.168.1.1: bytes=32 time=111ms TTL=64
Reply from 192.168.1.1: bytes=32 time=35ms TTL=64
Reply from 192.168.1.1: bytes=32 time=13ms TTL=64
Channel 11:
Reply from 192.168.1.1: bytes=32 time=293ms TTL=64
Reply from 192.168.1.1: bytes=32 time=193ms TTL=64
Reply from 192.168.1.1: bytes=32 time=12ms TTL=64
Reply from 192.168.1.1: bytes=32 time=49ms TTL=64
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Minimum = 12ms, Maximum = 293ms, Average = 136ms
Reply from 192.168.1.1: bytes=32 time=321ms TTL=64
Reply from 192.168.1.1: bytes=32 time=232ms TTL=64
Reply from 192.168.1.1: bytes=32 time=135ms TTL=64
Reply from 192.168.1.1: bytes=32 time=57ms TTL=64
Reply from 192.168.1.1: bytes=32 time=288ms TTL=64
Reply from 192.168.1.1: bytes=32 time=213ms TTL=64
Reply from 192.168.1.1: bytes=32 time=134ms TTL=64
Reply from 192.168.1.1: bytes=32 time=58ms TTL=64
Reply from 192.168.1.1: bytes=32 time=290ms TTL=64
Reply from 192.168.1.1: bytes=32 time=211ms TTL=64
Reply from 192.168.1.1: bytes=32 time=979ms TTL=64
Reply from 192.168.1.1: bytes=32 time=289ms TTL=64
אני מתחיל להתייאש ממנו.... הבדיקת מהירות האחרונה הביאה לי קצב 0.64 מתוך 100
  • תגובות 35
  • צפיות 4.5k
ערכתי לך את ההודעה על מנת שתהיה קריאה יותר.
מדובר בחיבור אלחוטי?
ניסית להחליף כרטיס רשת?
תודה על העריכה
הבגיקה התבצעה במחשב נייד בגלישה אלחוטית
תוצאה דומה הייתה עם מחשב נייד נוסף
עדכון נוסף:
אתמול ניתקתי את הנתב מהמחשל, חיברתי בסלום, עשיתי ping וקיבלתי ms=1
התחלתי לחשוד שכנראה משהו בחדר עושה את הבעיה - והתחלתי לנתק דברים - לבסוף ניתקתי את האל פסק.
חיברתי את הנתב והפלא ופלא - קיבלתי ping 1גם בחדר!
ככה זה היה(במספר בדיקות עם המחשב נייד שלי) עד היום בצהריים - לפתע הפינגים חזרו לסורם, התנתקויות חוזרות ונשנות, טעינת אתרים איטית, בדיקת מהירויות שמחזירה מהירות הורדה 0.63 ועוד ועוד.
מה נסגר????
לא הייתי ישן עם הראש ליד האל פסק הזה...
אולי האל פסק קרוב לאנטנה של הנתב או המחשב?
האל פסק לא מחובר מיום ראשון ועדיין התקלה חוזרת על עצמה
