שגיאה במשחק MOH Breakthrough
שלום
אני רוצה לשחק במשחק moh Breakthrough במחשב ואני מקבל את השגיאה הבאה
--- Common Initialization ---
Medal of Honor: Breakthrough 0.00 win-x86 Aug 30 2003
----- FS_Startup -----
Current search path:
E:\Program Files\EA GAMES\MOHAA\maintt\pak4.pk3 (11 files)
E:\Program Files\EA GAMES\MOHAA\maintt\pak3.pk3 (142 files)
E:\Program Files\EA GAMES\MOHAA\maintt\pak2.pk3 (1228 files)
E:\Program Files\EA GAMES\MOHAA\maintt\pak1.pk3 (7888 files)
E:\Program Files\EA GAMES\MOHAA/maintt
E:\Program Files\EA GAMES\MOHAA\main\Pak7Nl.pk3 (102 files)
E:\Program Files\EA GAMES\MOHAA\main\pak7.pk3 (89 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak6EnUk.pk3 (395 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak5.pk3 (259 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak4.pk3 (593 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak3.pk3 (669 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak2.pk3 (4722 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak1.pk3 (396 files)
E:\Program Files\EA GAMES\MOHAA\main\Pak0.pk3 (11174 files)
27668 files in pk3 files
execing default.cfg
execing buildver.cfg
execing menu.cfg
execing newconfig.cfg
execing localize.cfg
Config: unnamedsoldier.cfg
execing configs/unnamedsoldier.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 68
You are now setup for medium mode.
----- Client Initialization -----
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\Windows\system32\opengl32.dll' ): succeeded
...setting mode 8: 1280 1024 FS
...using colorsbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1280x1024)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 32, 0 )
...35 PFDs found
...GLW_ChoosePFD failed
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (8)
...using colorsbits of 16
...calling CDS: ok
...GLW_ChoosePFD( 16, 24, 0 )
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
