פורסם 2002 במרץ 1624 שנים ניסיתי את המלצתך בעניין, להשתמש באותם קבצי איתחול =========AUTOEXEC.BAT=========@ECHO OFFREM This Boot configuration was prepared by Prognathous. REM For any questions and suggestions, contact prognathous@hotmail.comREM You are free to modify the files, but if you choose to so, please keep these remarks intact.IF "%config%"=="REAL" GOTO QUITset EXPAND=YESSET DIRCMD=/O:Nset LglDrv=27 * 26 Z 25 Y 24 X 23 W 22 V 21 U 20 T 19 S 18 R 17 Q 16 P 15set LglDrv=%LglDrv% O 14 N 13 M 12 L 11 K 10 J 9 I 8 H 7 G 6 F 5 E 4 D 3 Ccall setramd.bat %LglDrv%set temp=%RAMD%:\set tmp=%RAMD%:\set nc=%RAMD%:\tools\ncpath=%RAMD%:\;%RAMD%:\tools\nc;%RAMD%:\Tools\Command\;a:\;x:\ncfull\;X:\;copy command.com %RAMD%:\ > NULset comspec=%RAMD%:ommand.comIF "%config%"=="NOCD" GOTO FINISHIF "%config%"=="VIANOCD" GOTO FINISHLH A:\MSCDEX.EXE /D:mscd001 /L:x > %RAMD%:\mscdex.logecho.echo The CD-ROM is accessible at Drive X:echo.lh x:\Tools\Command\Smartdrv.exe lh x:\Tools\Command\Smartdrv.exe /s > %RAMD%:\smartdrv.log:COPYTOOLSecho Please wait while the diagnostic utilities are being loaded to %RAMD%:\Tools\X:\tools\xcopy.exe x:\tools\*.* %RAMD%:\tools\*.* /e > %RAMD%:\xcopy.logecho Operation completed successfully.echo.GOTO FINISH:FINISHecho.mem /c > %RAMD%:\memclss.logmem /d > %RAMD%:\memdbg.loglh a:\Doskey.com > %RAMD%:\Doskey.logIF "%config%"=="NOCD" GOTO QUITIF "%config%"=="VIANOCD" GOTO QUITIF "%config%"=="REAL" GOTO QUITREALlh %RAMD%:\Tools\PQ6\Mouse.com > %RAMD%:\mouse.log%RAMD%:cd tools\ncnc.exe:QUITecho.:QUITREALa:echo If you wish to test your RAM, enter "docmem" at the command-line (without the quotes).========CONFIG.SYS========[menu]menuitem=CD, Start computer with CD-ROM support.menuitem=VIACD, Start computer with CD-ROM support (VIA KT/KX chipsets).menuitem=NOCD, Start computer without CD-ROM support.menuitem=VIANOCD, Start computer without CD-ROM support (VIA KT/KX chipsets).menuitem=REAL, Start computer without CD-ROM support (Real-Mode).menudefault=CD,4menucolor=7,0[CD]device=himem.sys /testmem:offdevice=UMBPCI.SYSNUMLOCK=ONdevicehigh=oakcdrom.sys /D:mscd001 devicehigh=btdosm.sys devicehigh=flashpt.sysdevicehigh=btcdrom.sys /D:mscd001devicehigh=aspi2dos.sysdevicehigh=aspi8dos.sysdevicehigh=aspi4dos.sysdevicehigh=aspi8u2.sysdevicehigh=aspicd.sys /D:mscd001[VIACD]device=himem.sys /testmem:offdevice=Emm386.exe NoemsNUMLOCK=ONdevicehigh=oakcdrom.sys /D:mscd001 devicehigh=btdosm.sys devicehigh=flashpt.sysdevicehigh=btcdrom.sys /D:mscd001devicehigh=aspi2dos.sysdevicehigh=aspi8dos.sysdevicehigh=aspi4dos.sysdevicehigh=aspi8u2.sysdevicehigh=aspicd.sys /D:mscd001[NOCD]device=himem.sys /testmem:offdevice=UMBPCI.SYSNUMLOCK=ON[VIANOCD]device=himem.sys /testmem:offdevice=Emm386.exe NoemsNUMLOCK=ON[REAL]NUMLOCK=ON[COMMON]files=50buffers=64dos=high,umbstacks=9,256devicehigh=ramdrive.sys /E 16384lastdrive=zdevicehigh=display.sys con=(ega,,1)country=972,862,country.sysהשינוי היחיד שערכתי הוא גודל ה-RAMDRIVEהמשך...
פורסם 2002 במרץ 1624 שנים מחבר לאחר האיתחול זה מה שקיבלתילאחר הודעה שהסידירום זמין בכונן XFile not foundFile not foundלאחר הודעה על טעינת ה-TOOLS ל-RAMDRIVEBad command or file nameהפעולה הצליחה מיד אחרי זה..Bad command or file nameBad command or file nameFile not foundFile not foundInvalid directoryBad command or file nameלבסוף הכותרת האחרונה ב-AUTOולסיום A:\>
פורסם 2002 במרץ 1624 שנים מחבר צרבת דרך הנרו? עיש בנרו אופציה לעשות את זה נסה להשתמש בה במה להשתמש? משתמש בנירו וגם ב-NTI 2000 רגיל ומעדיף להשתמש ב-WinOnCd (מחכה שחבר שלי יעביר לי אותה - ל-XP) אין לי בעיה בצריבת BOOTCD אולי תסביר/תפרט יותר למה התכוונת ? אגב, לאחר כל צריבת BOOTCD אני צריך לפרמט אותו פירמוט מלא! כך זה צריך להיות? לא מספיק מחיקה רגילה? לעזאזל! אני צריך כל פעם להמתין 21 דקות של פירמוט מלא.. גררר כמובן שאני מדבר על CD-RW
פורסם 2002 במרץ 1624 שנים כשאתה פותח את הנרו יש לך אפשרויות צריבה נכון?אז לך לcd-rom (boot) ויש לך שם מספיק אפשרויות לצריבת boot cd יש אפשריות לחיקוי של התקנים כמו פלופי והרד דיסק
פורסם 2002 במרץ 1624 שנים מחבר כשאתה פותח את הנרו יש לך אפשרויות צריבה נכון?אז לך לcd-rom (boot) ויש לך שם מספיק אפשרויות לצריבת boot cd יש אפשריות לחיקוי של התקנים כמו פלופי והרד דיסק1.אם הבנתי אותך נכון אז אין לי בעיות בלצרוב CDBOOT 2.מה לגבי הפירמוט (של ה-CDRW) מדוע לא מספיק לבצע מחיקה וזהו?
פורסם 2002 במרץ 1624 שנים בטח אתה צורב עם fainalze sesion (אני יודע...... זה עם שגיאות כתיב)אז אל תצרוב עם זה ותוכל למחוק נורמלי
פורסם 2002 במרץ 1624 שנים מחבר בטח אתה צורב עם fainalze sesion (אני יודע...... זה עם שגיאות כתיב)אז אל תצרוב עם זה ותוכל למחוק נורמלידווקא לא, אני תמיד מבצע מולטיסשן (Multisession), אלא אם כן אני צורב On The Fly אגב, איך זה קשור לבעיה שהצגתי ? (בהודעה הראשית)
פורסם 2002 במרץ 1624 שנים OK, חזרתי (הסרט החדש של האחים כהן לא רע בכלל...)דבר ראשון למי שצריך רקע, נושא הדיון הוא יצירת ה-BootableCD האולטימטיבי.פרטים כאן ובדיון ההמשך, כאן.לגבי הצריבה, אני משתמש ב-NTI CD-Maker 2000 Pro v5 ולא בנרו, אבל העקרון דומה. מנסיוני אין בעיה לצרוב אותו ב-Multisession, אם זה לא מסתדר נסה לצרוב ב-Disc-At-Once, ובכל מקרה אל תוסיף עוד sessions לדיסק עד שיש לך ביד קונפיגורציה שעובדת בלי בעיות.גם לא אמורה להיות בעיה במחיקת מהירה של הדיסק ולא במלאה, מפתיע אותי שעם נרו זה לא עובד כמו שצריך. מה הודעת השגיאה שאתה מקבל?שים לב שיש דרך נוספת שבה תוכל לחסוך הרבה מאוד זמן, במקום לאתחל את המחשב מה-CD בכל פעם שאתה רוצה לבדוק שינוי שביצעת בהגדרות שלו, תאתחל את הדיסק בתוך חלון של Virtual PC For Windows.התוכנה הנהדרת הזאת מאפשרת להריץ מספר מערכות הפעלה בתוך חלונות שונים, שימושי מאוד במקרה הזהו כדי לאתחל את Win9x (command-line) בתוך חלון של WinXP (או בגירסת חלונות שאיתה אתה עובד).כדי לאבחן את הבעיה, כדאי שתתחיל משתי משימות:1. בדיקה נקודתית של הבעיה ב-BootCD הקיים. בשביל זה מחק את ה-"ECHO OFF@" מה-autoexec.bat, זה יאפשר לראות בדיוק כל שורה שמבוצעת וכך נוכל לעשות סדר בהודעות השגיאה השונות.מציאת הסיבה ל-File not found הראשון, תיתן לנו כיוון ראשוני.כדאי שתצרף כאן גם את כל קבצי ה-log.* שנוצרו ב-ramdrive, אולי אפשר למצוא בהם את הנקודה המדוייקת שבה התהליך נכשל.2. בדיקה ש-BootCD סטנדרטי עובד כמו שצריך. צור דיסקט אתחול של Win9x וממנו צרוב BootableCD. אם הוא עובד כמו שצריך אז לא צריכה להיות בעיה להוסיף לו את ההרחבות שלי :smoke:Prog.
פורסם 2002 במרץ 1724 שנים מחבר מפתיע אותי שעם נרו זה לא עובד כמו שצריך. מה הודעת השגיאה שאתה מקבל?כשאני *רק* מוחק את ה-CDRW עם נירו ומנסה לצרוב שוב הכל, את הפלופי יחד עם התוכנות, הצורב מתחיל להעתיק קבצים (השלב הראשון) ומיד לאחר מכן כשהוא ניגש לצרוב מתקבלת הודעה על כך (בתוך חלון הצריבה ולא חלון נפרד) שהצריבה נכשלה ללא ציון הבעיה.תאתחל את הדיסק בתוך חלון של Virtual PC For Windows.על פי דרישות המערכת המופיעות בשם באתר, אין לי סיכוי! יש לי רק 128MB RAM (יתווסף בהמשך) מיד בודק ומעלה את הלוג
פורסם 2002 במרץ 1724 שנים מחבר אז ככה..כל קבצי הלוג ריקים מלבד MSCDEX MSCDEX Version 2.25Copyright © Microsoft Corp. 1986-1995. All rights reserved. Drive X: = Driver MSCD001 unit 0 Drive Y: = Driver MSCD001 unit 1DOSKEY = 0MOUSE = 0SMARTDRV = 0לגבי ה-DOSKEY אני יכול להבין, מהסיבה הפשוטה שהוא לא קיים (אני מעדיף להשתמש ב-4DOS )לגבי ה-MOUSE אני יכול להבין, מהסיבה הפשוטה שלא הגדרתי את מיקומו.
פורסם 2002 במרץ 1724 שנים מחבר זהו מבנה ספרית ה-TOOLS שלי.. ה-4DOS צריך להחליף את ה-DOSKEY העכבר נמצא כרגע תחת PQMAGIC ואיני מעוניין להתחיל עם NC או NU או כל תוכנה אחרת, אני רוצה שהכל יבוצע ידנית. בשלב יותר מאוחר ארצה שהכל ינוהל ע"י תפריט שבו אבחר איזו תוכנה להפעיל.
פורסם 2002 במרץ 1724 שנים כשאני *רק* מוחק את ה-CDRW עם נירו ומנסה לצרוב שוב הכל, את הפלופי יחד עם התוכנות, הצורב מתחיל להעתיק קבצים (השלב הראשון) ומיד לאחר מכן כשהוא ניגש לצרוב מתקבלת הודעה על כך (בתוך חלון הצריבה ולא חלון נפרד) שהצריבה נכשלה ללא ציון הבעיה. כנראה שבתחום הדוקומנטציה, ל-Ahead יש עדיין מה ללמוד מ-NTI. הכי פשוט? תעבור ל-CD Maker. היא היחידה שתומכת בפורמט Romeo (עד 128 תווים לשם קובץ, כפול מ-Joliet) ובכלל, היא קלה לשימוש כמו EZCD, וחזקה ואמינה כמו נרו. בקיצור, all gain, no pain :smoke: על פי דרישות המערכת המופיעות בשם באתר, אין לי סיכוי! יש לי רק 128MB RAM (יתווסף בהמשך) אתה צוחק נכון? יש לך חנות מחשבים ברשת ואתה עם 128MB RAM אתה מביא את "הסנדלר הולך יחף" למאה ה-21... Prog. נ.ב. ZIP עם קבצי האתחול הרלוונטיים מצורף להודעה הזאת.
פורסם 2002 במרץ 1724 שנים מחבר אתה צוחק נכון? יש לך חנות מחשבים ברשת ואתה עם 128MB RAM ממש לא צוחק. עד לפני ה-XP עבדתי נהדר עם *רק* 128MB מהסיבה הפשוטה שיותר מזה אני לא (הייתי) צריך. המחשב משמש לעסק *בלבד* ללא משחקים ושום דבר אחר. יותר מזה, אני משתמש בכרטיס מסך מובנה. עכשיו אתה יכול להתגלגל מצחוק
