Albatron GeForce FX 5700 Ultra
גם של ה5700 וגם של ה5900XT?
תבדוק את המחיר של שניהם אצל הדובים - יותר גבוה מ-PCH?
לא הגיוני - נכון?
  • תגובות 49
  • צפיות 4.7k
רק אני שמתי לב שה5700U מנצח ב:משחקים מבוססי QUAKE3 ומבחנים סינטטים?
ילדים, מה למדנו על דרייברים של NVIDIA ומבחנים סינטטים? ולא קשה לשים לב לזה כאשר ה5700 מנצח בבנצ'מרק של UT2003 וה9600XT מנצח בבמשחק עצמו
image.php?src=2177&ts=1071470569
image.php?src=2181&ts=1071471813
it would be a disservice to you, the consumer, if I did not acknowledge the issue of "aggressive optimizations" or "cheating" within video card drivers. This is a very touchy subject and one that has staunch supporters on both sides of the fence. So, for those that are not already aware you should know that both ATI and NVIDIA have been accused of "cheating" in their drivers dating back years and many different situations. It's beyond the scope of this review to dive deeply into this issue but you can find out as much as you'd like with a quick trip over to Google to learn more.
My personal take on this topic is that the term "cheating" is slung around very loosely at times and that there is a fine line between "cheating" and making innovative, beneficial and positive optimizations to drivers. After all, that is what drivers are all about in the first place, to improve/optimize performance, stability and functionality of the hardware that they communicate to and the OS. I won't deny that some questionable changes have been made to drivers but I also will not jump to conclusions and use a review as a platform for trying to convince you of my opinions on this topic. In summary, you should decide for yourself what is acceptable to you, and what is not, regarding changes to the drivers for your particular hardware.
אנשים...
שימו לב למחירים אצל הדובים ל-5700U.
עכשיו היבואן של אלבטרון הוא רוזטק.. שעובד מאוד מאוד קרוב עם הדובים..
מה שאומר שמישהו כאן התבלבל במחיר, כי לא יכול להיות ש-PCH יהיה יותר זול במשהו שהם מיבאים בעצמם.
טוב שאלתי כרגע את רוזטק.. הם הפיצו כמה מחירונים ואלכס לא מועדכן.
המחיר ב-PCH שגוי.
לא! זה לא נכון....
אם PCH קונים את הALBETON האלה ב400 (זאת רק דוגמא) שקל הם מוכרים אותם נגיד לפנדז ב500 פנדס יכולים למכור את הכרטיס ב1200 וPCH ימכרו ב950 זה לשניהם יש רווח כל שהוא.....זה לא משנה מי היבואן ובכמה הוא מוכר תבין שפנדז יכולים למכור את המוצר גם ב550 שקל פשוט יהיה להם רווח קטן מאוד אני בספק אם זאת טעות
ואפילו שאתה צודק, אני מדבר בכלליות עכשיו.
אז ברור שאתה לא מכיר את הדובים.. הם מוכרים לפעמים במחירים מאוד קרובים למחירי הפסד, רק על מנת למשוך את הלקוחות.
הם היבואנים (לצורך העניין רוזטק ופנדה עובדים ביחד), ולכן הם היחידים שיכולים להרשות לעצמם את המחיר הכי נמוך של המוצר.
ואויי הפלא ופלא.. המחיר ב-PCH פתאום עלה... ::)
