טריפל C, שוב בעיית פינגים מטורפים?
ping walla.co.il -t
Pinging walla.co.il [192.118.82.140] with 32 bytes of data
Reply from 192.118.82.140: bytes=32 time=16ms TTL=243
Reply from 192.118.82.140: bytes=32 time=43ms TTL=243
Reply from 192.118.82.140: bytes=32 time=44ms TTL=243
Reply from 192.118.82.140: bytes=32 time=147ms TTL=243
Reply from 192.118.82.140: bytes=32 time=131ms TTL=243
Reply from 192.118.82.140: bytes=32 time=117ms TTL=243
Reply from 192.118.82.140: bytes=32 time=40ms TTL=243
Reply from 192.118.82.140: bytes=32 time=167ms TTL=243
Reply from 192.118.82.140: bytes=32 time=34ms TTL=243
Reply from 192.118.82.140: bytes=32 time=180ms TTL=243
Reply from 192.118.82.140: bytes=32 time=84ms TTL=243
Reply from 192.118.82.140: bytes=32 time=22ms TTL=243
Reply from 192.118.82.140: bytes=32 time=48ms TTL=243
Reply from 192.118.82.140: bytes=32 time=154ms TTL=243
Reply from 192.118.82.140: bytes=32 time=68ms TTL=243
Reply from 192.118.82.140: bytes=32 time=69ms TTL=243
Reply from 192.118.82.140: bytes=32 time=227ms TTL=243
Reply from 192.118.82.140: bytes=32 time=73ms TTL=243
Ping statistics for 192.118.82.140:
Packets: Sent = 19, Received = 19, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 16ms, Maximum = 227ms, Average = 94ms
וזה עוד רגוע, מקודם זה הגיע ל500MS
tracert walla.co.il
Tracing route to walla.co.il [192.118.82.140]
over a maximum of 30 hops:
1 <1 ms <1 ms <1 ms 1.1.1.1
2 138 ms 191 ms 107 ms 109.226.0.226
3 * * * Request timed out.
4 * * * Request timed out.
5 * * * Request timed out.
6 * * * Request timed out.
7 * * * Request timed out.
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 21 ms 36 ms 13 ms 192.118.82.140
Trace complete.
האם עוד מישהו בטריפל חווה כרגע את אותה הבעייה, או שהבעייה היא אצלי?
C:\Users\Dolev>ping www.walla.co.il
Pinging www.walla.co.il [192.118.82.140] with 32 bytes of data:
Reply from 192.118.82.140: bytes=32 time=20ms TTL=243
Reply from 192.118.82.140: bytes=32 time=19ms TTL=243
בזק + TRIPLE C עשר מגה
כן האמת זה הסתדר מעצמו אחרי איזה שעה-שעה וחצי.
