HP או Lenovo?
איזה מהמחשבים הבאים עדיף:
HP G62-B50SJ‎
‎Model‎ ‎G62-B50SJ‎
‎ Color‎ ‎G62-B50SJ - שחור מט עם דפוס פריזמה‎
‎ CPU‎ ‎Intel® Core i3 350M Processor, 2.26GHz,3MB Cache,1066MHz FSB‎
‎ Memory‎ ‎3GB DDR3 1066MHz (1 x 2048 MB + 1 x 1024 MB), Up to 4 GB‎
‎ HD‎ ‎320 GB (5400Rpm)‎
‎ Display‎ ‎15.6'' Diagonal High-Definition LED HP BrightView Widescreen Display (1366 x 768)‎
‎ GPU‎ ‎Intel HD Graphics, up to 1274 MB total available graphics memory‎
‎ Optical Device‎ ‎SATA optical drive: LightScribe SuperMulti DVD±R/RW with Double Layer Support‎
‎ Sound‎ ‎Altec Lansing speakers‎
‎ Wireless‎ ‎802.11 b/g/n‎
‎ Bluetooth‎ ‎No‎
‎ Network Card‎ ‎Integrated 10/100BASE-T Ethernet LAN‎
‎ Card Reader‎ ‎5-in-1 integrated Digital Media Reader for Secure Digital cards, MultiMedia cards, Memory Stick, Memory Stick Pro or xD Picture cards‎
‎ Ports‎ ‎1 HDMI port‎
‎ 1 VGA port ‎
‎ 1 stereo headphone-out ‎
‎ 1 microphone-in ‎
‎ 3 USB 2.0 ports ‎
‎ 1 RJ45 ethernet port‎
‎ Integrated Camera‎ ‎Webcam with Integrated Microphone (VGA)‎
‎ OS‎ ‎Linux SuSe SLED11‎
‎ Weight‎ ‎Starting at 2.20 kg‎
‎ Battery‎ ‎6-cell Lithium-Ion (Li-Ion) battery‎
או
Lenovo IdeaPad G560 M27B6IV‎
‎Model‎ ‎M27B6IV‎
‎ Machine Type‎ ‎0679-B6G‎
‎ CPU‎ ‎Intel® Core i3 380M Processor, 2.53GHz,3MB Cache,1066MHz FSB‎
‎ Memory‎ ‎2GB DDR3 1066MHz (1 x 2048 MB), Up to 8 GB‎
‎ HD‎ ‎250GB Sata‎
‎ Display‎ ‎15.6'' High-Defnition LED (1366x768), 16:9 Widescreen‎
‎ GPU‎ ‎Intel® HD Graphics With Dynamic Frequency‎
‎ Optical Device‎ ‎Tray-in Rambo drive (DVD/CD Combo burner/reader)‎
‎ Wireless‎ ‎Wi-Fi 802.11bg/bgn‎
‎ Network card‎ ‎Ethernet 10/100M‎
‎ Bluetooth‎ ‎No‎
‎ Integrated Camera‎ ‎Yes‎
‎ Sound‎ ‎2.0 speakers (2x2W)‎
‎ Card Reader‎ ‎5-in-1 Card Reader (SD/SD pro/MMC/MS pro/XD)‎
‎ Ports‎ ‎3 USB 2.0‎
‎ 1 VGA‎
‎ 1 RJ45 ethernet connector‎
‎ 1 Headphones-Out ‎
‎ 1 Mic-In‎
‎ OS‎ ‎Genuine Windows 7 Home Premium 64Bit‎
‎ Weight‎ ‎2.6kg with 6-cell battery‎
‎ Battery‎ ‎6-cell Lithium-Ion (Li-Ion) battery ‎
‎ Warranty‎ ‎אחריות לשנה אחת בינלאומית, שירות שליחים בטלפון
הדפסה על CD - לא חשוב.
השאלה הגדולה היא מבחינת אמינות ואיכות. מה עדיף?
hp עדיפים בהרבה מבחינת אמינות ואיכות.
ואיך בדיוק הסקת את המסקנה הזו?
אז מה עדיף בהנחה שהמפרט פחות או יותר אותו הדבר???
HP או LENOVO???
מה זה "בהנחה שהמפרט פחות או יותר אותו הדבר"?
הוא לא.
כמו שאמרו לך - בהשוואה בין הנ"ל ללנובו מעבד מעט מהיר יותר, אך דיסק יותר קטן, ופחות זכרון. כמו כן, נראה שאין לו יציאת HDMI בעוד שלHP יש. הלנובו מגיע עם רישיון לWindows, הHP ללא (מותקן לינוקס).
תחליט אתה מה עדיף לך.
מבחינת איכות / אמינות - במחיר כזה אל תצפה למשהו מרהיב, וגם לא להבדלים משמעותיים.
hp
