Lord Of The Rings The Return Of The King gameplay question
hello
i have a gameplay question. I reached the level of minas tirit when i play with gandolf and i have to defend the walls. Now i understood that i can't let the orcs overrun be. i know that i need to pust the ladders down. My quistion is this. there are 2 towers aproaching the walls. First one on the left(the left catapult takes it down) and one on the right. Now i can't find a second catapult to take that onw down and the first allways turned to the lest so i can't use that one. PLEASE HELP ME.:(
help will be much apprisheated
You can destroy the towers by firing lightning bolts from Gundalf's staff.
As I remember 5 shots did the job very well.
And please next time if you write in English would you be so kind to align the text to the left side of the screen.
