מחפש לוח אם למחשב אינטל הכולל כ.מסך
מחפש לוח אם אינטל טוב הכולל כרטיס מסך OB טוב ( כמו NFORCE2 )
865PE כולל הכל: DUALDDR, RAID, SATA, X8, 5.1, G-LAN, FIREWIRE, PAT
יש את ה Abit IS7-M שהוא זול יחסית ומעולה
ויש גם את ה GIGABYTE GA-8IG1000 Pro שהוא קצת יותר יקר
יש את ה p4p800 vm שכולל כ מסך ..
יש את ה ASUS P4P800 DELUXE שיש לו את כל הנתונים שאתה מחפש.
P4P800 Deluxe is 865PE which has no onboard Video card, only the 865GE has onboard VG. The ny case, the onboard VGA on Intel chipsets is Intel Accelerated Graphics 2 which can't run games at all, it's not even as good a Voodoo and it's no way near the level of the onboard MX440 that comes with the nForce 2.
In any case I haven't seen a single board based on 865GE that has RAID and G-Lan and everything you asked for, these are usually low end boards thus not a lot of features.
ATI is about to release a chipset for P4 that has a very good intergrated GPU but that might take some time.
To make it simple, you're looking for something that doesn't exist.
