AMD Radeon HD6000 - מי מה כמה ולמה, ריכוז מידע ושאלות
  • תגובות 383
  • צפיות 71.1k
shadow, אין צורך שאגיד לך לחפש איפה בשביל לדעת שהתמונות האלה מפוברקות.
אפשר להגיד שזה וודאי. GTX 580 יותר חזק מ ATI 6970 (שמביא תוצאות דומות מאוד ל- GTX 570 (
Radeon HD 6970 slower than GTX 580 in 3Dmark 2011
Slower or similar to GTX 570, tests in
We got some numbers for Radeon HD 6970 in 3Dmark Vantage and the latest 2011 version. We know that this test is not real life based, but it still provides a nice reference.
We have compared the 3Dmark data we acquired from a source with our own that we got on a similar configuration. In 3Dmark 2011 Radeon HD 6970 scores slightly lower than 8000 at entry settings while the GTX 580 scores 8700 in that same test. The runner up, GTX 570, scores slightly above 8000 while the GTX 480 is slightly below 8000.
At performance settings Radeon HD 6970 a.k.a. Cayman XT scores around 5300 while the GTX 580 scores are just tad below 6000 and the GTX 570 loses by an inch with 5250 score. GTX 480 scores almost identical to the GTX 570, its 5250 points are again slightly lower than HD 6970.
In more extreme conditions Radeon HD 6970 scores 1800 while the GTX 580 scores 1950. Radeon HD 6970 again wins against GTX 570 and GTX 480 who scored 1680.
The launch is on Wednesday December 15th 5AM Central European Time or 6PM GMT or Greenwich time. Chaps in New York or across east coast will be able to see the card launching on November 15th at 00.00 AM while those from California get a slight advantage and can see the card selling already on December 14th 09.00 PM.
Sources have also confirmed that the GTX 580 wins in most of the games. You’ll see some official scores in less than 48 hours from now
http://www.fudzilla.com/graphics/item/21184-radeon-hd-6970-slower-than-gtx-580-in-3dmark-2011
זה רשמי - 3DMARK 11 לא משקף בשיט את מה שקורה בביצועי משחקים.
ותן לי לנחש את המקור לזה, FUDZILLA?
אפשר להפסיק עם הדרמות המטומטמות ולהמתין לתוצאות האמיתיות בעוד יומיים? תודה.
תקרא את השורה התחתונה שמתייחסת למשחקים...וכן בשלב כזה אפשר לסמוך על ''הדלפות'' (יומים לפני שהכרטיס יוצא)
איזה דרמות ואיזה נעליים....ואני מבין ש ATI יקרים לליבך אבל לא צריך להגזים :xyxthumbs:
כולנו ניווכח עוד יומים.
אגב - FUDZILLA נחשב לאתר אמין לדעתי..וזה ש''תפסת'' אותו (בעבר) מזייף זה לא אומר שהוא תמיד ככה ואם נדייק שהוא ברוב המוחלט של ידיעות חומרה כן אמין וקולע.
בטח ש-ATI יקרים לליבי, זה למה קניתי SLI.
פאדזילה זה אחד מ5 האתרים הכי פחות אמינים לדעתי, הם עושים הכל בשביל רייטינג, בעיקר מפיצים שמועות ומשנים את דעתם על בסיס שבועי
יש להם הסטוריה ארוכה של פאשלות שהם אפילו רטרואקטיבית דואגים לטאטא מתחת לשטיח שחלילה לא יראו.
יכול מאוד להיות ש-GTX580 יהיה חזק מHD6970, אני לא אומר שלא. אבל הפסטיבל השערות הזה שמתחיל חודשיים לפני השקת כל דור באמת יצא מכל חור.
גם להביא תמונות שערוכות בצורה חובבנית בצייר זה לא חכם shadow, האנשים האלה רוצים רייטינג נטו, ככה זה עובד.
מסכים עם DJ, בכל פעם מחדש אותו הסיפור...
חכו למחר ויהיה לכולנו מידע ודאי.
כן גם את המחיר של HD6950 של סאפיר הם הורידו ל1612 שקלים, אפילו שזה נשמע נמוך מאוד אל תטעו את עצמכם זה מחיר גבוה.
1500-1550 יהיה מחיר טוב לכרטיס כזה, אבל כמו שאני מכיר את השוק ייקח הרבה זמן עד שזה יקרה.
זה מסתמן כאילו זה מבנה שמאוד דומה לדור הקודם, רק שעכשיו:
HD6950 בתפקיד HD5850.
HD6970 בתפקיד HD5870.
GTX570 בתפקיד GTX470.
GTX580 בתפקיד GTX480.
יחס המחיר והביצועים נשמר, רק שעכשיו הכרטיסים של AMD לא חסכוניים בחשמל כמו הדור הקודם.
אם זה אמיתי אז זה די מאכזב...
אל תצפו לניסים כבר עכשיו אני יכול להגיד, HD6970 יהיה חזק בכמה אחוזונים מGTX570, הHD6950 יהיה חלש מGTX570 בכמה אחוזים ופה נגמר הסיפור
עכשיו המחלמה שמתחילה היא המלחמה על המחיר
