נמצא כוכב כמו כדה"א (בערך) פי 3 בגודלו
A newly detected planet that orbits a red dwarf star called Gliese 581 and appears to be three times the mass of the Earth could support life, the team at the University of California, Santa Cruz, and the Carnegie Institution of Washington said on Wednesday (September 29).
The team found it using indirect measurements from the Keck telescope in Hawaii, which has been used to scrutinize Gliese 581 for 11 years and has spotted other potential planets orbiting it.
"The goldilocks zone is the range of orbits around any star where it's neither too hot nor too cold but just right for liquid water to exist on the surface. And that's the key ingredient for the existence of life," said Doug Hudgins, NASA's Exoplanet Exploration Program Scientist.
The planet, called Gliese 581g, is 20 light-years away from Earth in the constellation Libra, according to the paper to be published in the Astrophysical Journal. Gliese 581g, one of six whizzing planets around the little cool star, has a mass three to four times that of the Earth and orbits every 37 or so days, they calculated.
"Gliese 581, like I said a red dwarf star, much cooler than our sun emits much less radiation. So in fact those planets need to snuggle up much closer to that star in order to get the warmth," said Hudgins.
"There are now nearly 500 known extrasolar planets," the team of scientists wrote. "If the local stellar neighborhood is a representative sample of the galaxy as a whole, our Milky Way could be teeming with potentially habitable planets."
They estimate temperatures on the planet average from -24 to 10 degrees Fahrenheit (-31 to -12 degrees C). The planet is locked facing its sun, like Mercury, so one side would be extremely hot and the other perpetually cold, with the livable range being at the edge where dawn and dusk would be on a spinning planet like Earth's.
If it was rocky, like Earth, it could have gravity similar to Earth's and it would be possible for liquid water to be on the surface, they said,
although they have not detected water on Gliese 581g.
http://www.timesnow.tv/New-planet-similar-to-Earth-discovered/articleshow/4355114.cms
לא רע, מצד שני- 20 שנות אור...בקטנה אה.
  • תגובות 85
  • צפיות 26.6k
מתי יתחילו המכרזים לקניית דונמים שם?
שיומצאו חוקי פיזיקה המאפשרים לעבור את מהירות האור.
אבל לך תדע, האנושות ידועה בטיפשותה.
20 שנות אור,כמה זה ב"עיברית"?
20 שנות טיסה במהירות האור...
או שאתה רוצה לדעת את הקילומטראז' ?
בשעות טיסה,או בשנים
ידוע מזמן על הכוכב הזה...
תעשה את החישוב:מהירות האור כפול Xימים בשנה כפול 20.
אומרים שגם 13 ימים שם זה שנה אצלנו (!?!?)
21900000000 שנים הלוך??!
13 ימים זה שנה זה אומר אם אני בן 32 כאן אז ביחס אליהם אני בן 416
אני צודק כאן?
בחלק הראשון זה כמה קילומטרים יש ב 20 שנות אור.
בחלק השני זה כמה זמן ייקח להגיע לשם ב"חללית" הכי מהירה כיום.
כמובן שזה לא כל כך מדוייק כי זו לא המהירות הקבועה לכל אורך המסלול, החללית מאיצה במהלך המסלול תלוי במנוע שיש לה.
C = 299,792,458 m/s (meters per sec)
C/1000 *60*60 *24*365 *20
KM/s KM/h KM/year years
= 189,085,099,109,760 KM => ~189 Trillion KM
986925 m/s => 1,023,243,840 ~1.023 Billion KM per year
=> ~184789.87 years
בעברית:
בסביבות 190 ביליון קילומטר, שזה מיליון כפול מיליון כפול 190(12 אפסים), קילומטרים.
בחללית רגילה טסה בערך 13 קילומטר בשניה, שזה ביחס למהירות האור 13:300000 בערך פי 28 אלף יותר לאט, כלומר 20 שנה כפול 28,000.
שזה-
560 אלף שנה, זה הזמן שייקח לחללית רגילה להגיע, שזה אומר שהרבה דברים ישתנו ביקום בזמן הזה.
בואנה אז תאכלס עד שלא ימציאו חללית שנעה במהירות האור לפחות אין בכלל על מה לדבר
על מסעות אינטר גלקטים אה?
מה שרשמת לא מתיישב עם חוקי הפיזיקה הידועים לנו :)
תאורתית רק חלקיק חסר מסה יכל לנוע במהירות האור כך שחללית יכולה לנוע ב 99.9999% מהירות אור... (בעזרת כמות בלתי נתפסת של אנרגיה)
אבל אולי יש דרכים עקיפות כמו קיצורי דרך בזמן חלל עצמו שקיימים באופן טבעי ולא גילנו או שצריך ליצור.
בכל מקרה אם לא ינחתו מחר בבוקר חייזרים ידידותיים ויגלו לנו את סודות היקום אנחנו תקועים במערכת השמש עוד שנים רבות :)
וגם אם יהיה אפשר לטוס במהירות האור, יש עצמים ביקום במרחק של מאות, אלפי ומיליוני שנות אור מאיתנו, כך שזה עדיין קצת בעייתי.
קיפול חלל נראה כמו הדרך הכי אפשרית כרגע.
אבל לפי מה שהבנתי הרעיונות האלה הם תיאורטיים לא?
בקיצור , עדיף לנו להשלים עם מר גורלנו ולגסוס כגזע עם חיוך :lol:
