פורסם 2010 במרץ 3016 שנים http://www.addictivetips.com/windows-tips/how-to-disable-automatic-driver-installation-in-windows-vista/במקרים מסויימים, זה יכול להיות שימושי. Suppose you have connected a device with your computer, Windows 7 / Vista will now automatically search for the driver and install it. If you want to select every driver manually(because you have a manual driver that is better), then you should disable automatic driver installation. To do this you don’t need to install any software at all, you can do this using Windows Driver Settings.
