עזרה בהתקנת דרייברים IBM ThinkCentre A50
מצאתי דרייברים לפי שם הלוח,משום מה אני לא מצליח להתקין אותם.
אולי צריך לחפש בצורה אחרת? הנה הריפורט
--------[ EVEREST Corporate Edition ]-----------------------------------------------------------------------------------
Version EVEREST v5.30.1900/he
Benchmark Module 2.4.273.0
Homepage http://www.lavalys.com/
Report Type Quick Report
Computer AVI-572B12431DA
Generator avi
Operating System Microsoft Windows XP Professional 5.1.2600 (WinXP RTM)
Date 2010-02-12
Time 15:30
--------[ CPU ]---------------------------------------------------------------------------------------------------------
CPU Properties:
CPU Type Intel Pentium 4, 3000 MHz (15 x 200)
CPU Alias Prescott
CPU Stepping E0
Instruction Set x86, MMX, SSE, SSE2, SSE3
Original Clock 3000 MHz
Min / Max CPU Multiplier 14x / 15x
Engineering Sample No
L1 Trace Cache 12K Instructions
L1 Data Cache 16 KB
L2 Cache 1 MB (On-Die, ECC, ATC, Full-Speed)
Multi CPU:
CPU #1 Intel® Pentium® 4 CPU 3.00GHz, 2992 MHz
CPU #2 Intel® Pentium® 4 CPU 3.00GHz, 2992 MHz
CPU Manufacturer:
Company Name Intel Corporation
Product Information http://www.intel.com/products/processor
CPU Utilization:
CPU #1 / HTT Unit #1 0 %
CPU #1 / HTT Unit #2 0 %
--------[ CPUID ]-------------------------------------------------------------------------------------------------------
CPUID Properties:
CPUID Manufacturer GenuineIntel
CPUID CPU Name Intel® Pentium® 4 CPU 3.00GHz
CPUID Revision 00000F41h
IA Brand ID 00h (Unknown)
Platform ID 1Fh / MC 04h (Socket 478)
Microcode Update Revision 17
HTT / CMP Units 2 / 1
Instruction Set:
64-bit x86 Extension (AMD64, Intel64) Not Supported
AMD 3DNow! Not Supported
AMD 3DNow! Professional Not Supported
AMD 3DNowPrefetch Not Supported
AMD Enhanced 3DNow! Not Supported
AMD Extended MMX Not Supported
AMD MisAligned SSE Not Supported
AMD SSE4A Not Supported
AMD SSE5 Not Supported
Cyrix Extended MMX Not Supported
IA-64 Not Supported
IA MMX Supported
IA SSE Supported
IA SSE 2 Supported
IA SSE 3 Supported
IA Supplemental SSE 3 Not Supported
IA SSE 4.1 Not Supported
IA SSE 4.2 Not Supported
IA AVX Not Supported
IA FMA Not Supported
IA AES Extensions Not Supported
VIA Alternate Instruction Set Not Supported
CLFLUSH Instruction Supported
CMPXCHG8B Instruction Supported
CMPXCHG16B Instruction Not Supported
Conditional Move Instruction Supported
LZCNT Instruction Not Supported
MONITOR / MWAIT Instruction Supported
MOVBE Instruction Not Supported
PCLMULQDQ Instruction Not Supported
POPCNT Instruction Not Supported
RDTSCP Instruction Not Supported
SYSCALL / SYSRET Instruction Not Supported
SYSENTER / SYSEXIT Instruction Supported
VIA FEMMS Instruction Not Supported
Security Features:
Advanced Cryptography Engine (ACE) Not Supported
Advanced Cryptography Engine 2 (ACE2) Not Supported
Data Execution Prevention (DEP, NX, EDB) Not Supported
Hardware Random Number Generator (RNG) Not Supported
PadLock Hash Engine (PHE) Not Supported
PadLock Montgomery Multiplier (PMM) Not Supported
Processor Serial Number (PSN) Not Supported
Power Management Features:
Automatic Clock Control Supported
Digital Thermometer Not Supported
Dynamic FSB Frequency Switching Not Supported
Enhanced Halt State (C1E) Supported, Disabled
Enhanced SpeedStep Technology (EIST, ESS) Not Supported
Frequency ID Control Not Supported
Hardware P-State Control Not Supported
LongRun Not Supported
LongRun Table Interface Not Supported
PowerSaver 1.0 Not Supported
PowerSaver 2.0 Not Supported
PowerSaver 3.0 Not Supported
Processor Duty Cycle Control Supported
Software Thermal Control Not Supported
Temperature Sensing Diode Not Supported
Thermal Monitor 1 Supported
Thermal Monitor 2 Supported
Thermal Monitoring Not Supported
Thermal Trip Not Supported
Voltage ID Control Not Supported
CPUID Features:
1 GB Page Size Not Supported
36-bit Page Size Extension Supported
Address Region Registers (ARR) Not Supported
CPL Qualified Debug Store Supported
Debug Trace Store Supported
Debugging Extension Supported
Direct Cache Access Not Supported
Dynamic Acceleration Technology (IDA) Not Supported
Fast Save & Restore Supported
Hyper-Threading Technology (HTT) Supported, Enabled
Invariant Time Stamp Counter Supported
L1 Context ID Supported
Local APIC On Chip Supported
Machine Check Architecture (MCA) Supported
Machine Check Exception (MCE) Supported
Memory Configuration Registers (MCR) Not Supported
Memory Type Range Registers (MTRR) Supported
Model Specific Registers (MSR) Supported
Nested Paging Not Supported
Page Attribute Table (PAT) Supported
Page Global Extension Supported
Page Size Extension (PSE) Supported
Pending Break Event Supported
Physical Address Extension (PAE) Supported
Safer Mode Extensions (SMX) Not Supported
Secure Virtual Machine Extensions (Pacifica) Not Supported
Self-Snoop Supported
Time Stamp Counter (TSC) Supported
Turbo Boost Not Supported
Virtual Machine Extensions (Vanderpool) Not Supported
Virtual Mode Extension Supported
x2APIC Not Supported
XSAVE / XRSTOR Extended States Not Supported
CPUID Registers (CPU #1):
CPUID 00000000 00000005-756E6547-6C65746E-49656E69
CPUID 00000001 00000F41-00020800-0000441D-BFEBFBFF
CPUID 00000002 605B5001-00000000-00000000-007C7040
CPUID 00000003 00000000-00000000-00000000-00000000
CPUID 00000004 00004121-01C0003F-0000001F-00000000
CPUID 00000004 00004143-01C0103F-000003FF-00000000
CPUID 00000005 00000040-00000040-00000000-00000000
CPUID 80000000 80000008-00000000-00000000-00000000
CPUID 80000001 00000000-00000000-00000000-00000000
CPUID 80000002 20202020-20202020-20202020-6E492020
CPUID 80000003 286C6574-50202952-69746E65-52286D75
CPUID 80000004 20342029-20555043-30302E33-007A4847
CPUID 80000005 00000000-00000000-00000000-00000000
CPUID 80000006 00000000-00000000-04006040-00000000
CPUID 80000007 00000000-00000000-00000000-00000000
CPUID 80000008 00002024-00000000-00000000-00000000
CPUID Registers (CPU #2 Virtual):
CPUID 00000001 00000F41-01020800-0000441D-BFEBFBFF
MSR Registers:
MSR 00000017 000A-0000-0000-0000 [PlatID = 2]
MSR 0000001B 0000-0000-FEE0-0900
MSR 0000002A 0000-0000-0000-0080
MSR 0000002C 0000-0000-0F12-010F
MSR 0000008B 0000-0017-0000-0000
MSR 00000198 0000-0F2D-0000-0F2D
MSR 00000199 0000-0000-0000-0F2D
MSR 0000019A 0000-0000-0000-0000
MSR 0000019B 0000-0000-0000-0000
MSR 0000019C 0000-0000-0000-0000
MSR 0000019D 0000-0000-0000-0E2A
MSR 000001A0 0000-0000-2084-00C9
MSR 000001A1 0000-0000-0000-0000
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard Properties:
Motherboard ID <DMI>
Motherboard Name IBM ThinkCentre A50
Front Side Bus Properties:
Bus Type Intel GTL+
Bus Width 64-bit
Real Clock 200 MHz (QDR)
Effective Clock 800 MHz
Bandwidth 6400 MB/s
Memory Bus Properties:
Bus Type DDR SDRAM
Bus Width 64-bit
DRAM:FSB Ratio 4:5
Real Clock 160 MHz (DDR)
Effective Clock 320 MHz
Bandwidth 2560 MB/s
Chipset Bus Properties:
Bus Type Intel Hub Interface
Bus Width 8-bit
Real Clock 67 MHz (QDR)
Effective Clock 267 MHz
Bandwidth 267 MB/s
--------[ Memory ]------------------------------------------------------------------------------------------------------
Physical Memory:
Total 1014 MB
Used 214 MB
Free 800 MB
Utilization 21 %
Swap Space:
Total 2445 MB
Used 122 MB
Free 2323 MB
Utilization 5 %
Virtual Memory:
Total 3460 MB
Used 336 MB
Free 3123 MB
Utilization 10 %
Paging File:
Paging File C:\pagefile.sys
Initial / Maximum Size 1524 MB / 3048 MB
Current Size 1524 MB
Current / Peak Usage 5 MB / 5 MB
Utilization 0 %
Physical Address Extension (PAE):
Supported by Operating System Yes
Supported by CPU Yes
Active No
--------[ SPD ]---------------------------------------------------------------------------------------------------------
[ DIMM1: Kingston K ]
Memory Module Properties:
Module Name Kingston K
Serial Number 7406F1F3h (4092659316)
Module Size 512 MB (2 ranks, 4 banks)
Module Type Unbuffered
Memory Type DDR SDRAM
Memory Speed PC2700 (166 MHz)
Module Width 64 bit
Module Voltage SSTL 2.5
Error Detection Method None
Refresh Rate Reduced (7.8 us), Self-Refresh
Memory Timings:
@ 166 MHz 2.5-3-3-7 (CL-RCD-RP-RAS) / 10-12-2 (RC-RFC-RRD)
@ 133 MHz 2.0-3-3-6 (CL-RCD-RP-RAS) / 8-10-2 (RC-RFC-RRD)
Memory Module Features:
Early RAS# Precharge Not Supported
Auto-Precharge Not Supported
Precharge All Not Supported
Write1/Read Burst Not Supported
Buffered Address/Control Inputs Not Supported
Registered Address/Control Inputs Not Supported
On-Card PLL (Clock) Not Supported
Buffered DQMB Inputs Not Supported
Registered DQMB Inputs Not Supported
Differential Clock Input Supported
Redundant Row Address Not Supported
Memory Module Manufacturer:
Company Name Kingston Technology Company, Inc.
Product Information http://www.kingston.com/products/default.asp
[ DIMM2: ProMos/Mosel Vitelic V826632K24SCTG-D3 ]
Module Name ProMos/Mosel Vitelic V826632K24SCTG-D3
Serial Number D51B031Ah (436411349)
Manufacture Date Week 23 / 2005
Module Size 256 MB (1 rank, 4 banks)
Memory Speed PC3200 (200 MHz)
Module Width 64 bit
Memory Timings:
@ 200 MHz 3.0-3-3-8 (CL-RCD-RP-RAS) / 12-14-2 (RC-RFC-RRD)
@ 133 MHz 2.0-2-2-6 (CL-RCD-RP-RAS) / 8-10-2 (RC-RFC-RRD)
[ DIMM3: Samsung M3 68L3223FTN-CB3 ]
Module Name Samsung M3 68L3223FTN-CB3
Serial Number F503B20Fh (263324661)
Manufacture Date Week 51 / 2004
Module Width 64 bit
Memory Timings:
Company Name Samsung
Product Information http://www.samsung.com/global/business/semiconductor
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: Intel Springdale-G i865G ]
North Bridge Properties:
North Bridge Intel Springdale-G i865G
Supported FSB Speeds FSB400, FSB533, FSB800
Supported Memory Types DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM
Maximum Memory Amount 4 GB
Revision / Stepping 02 / A2
Package Type 932 Pin FC-BGA
Package Size 3.75 cm x 3.75 cm
Core Voltage 1.5 V
In-Order Queue Depth 12
Memory Controller:
Type Dual Channel (128-bit)
Active Mode Single Channel (64-bit)
PAT Disabled
Memory Timings:
CAS Latency (CL) 2.5T
RAS To CAS Delay (tRCD) 3T
RAS Precharge (tRP) 3T
RAS Active Time (tRAS) 7T
Refresh Period (tREF) 7.8 us
Error Correction:
ECC Not Supported
ChipKill ECC Not Supported
RAID Not Supported
ECC Scrubbing Not Supported
Memory Slots:
DRAM Slot #1 512 MB (DDR SDRAM)
DRAM Slot #2 256 MB (DDR SDRAM)
DRAM Slot #3 256 MB (DDR SDRAM)
Integrated Graphics Controller:
Graphics Controller Type Intel Extreme Graphics 2
Graphics Controller Status Enabled
Graphics Frame Buffer Size 8 MB
Chipset Manufacturer:
Product Information http://www.intel.com/products/chipsets
Driver Download http://support.intel.com/support/chipsets
BIOS Upgrades http://www.esupport.com/biosagent/index.cfm?refererid=40
Driver Update http://driveragent.com?ref=59
[ South Bridge: Intel 82801EB ICH5 ]
South Bridge Properties:
South Bridge Intel 82801EB ICH5
Revision / Stepping C2 / A2/A3
Package Type 460 Pin mBGA
Package Size 3.1 cm x 3.1 cm
Core Voltage 1.5 V
--------[ BIOS ]--------------------------------------------------------------------------------------------------------
BIOS Properties:
BIOS Type Phoenix
BIOS Version 2CKT20AUS
System BIOS Date 10/26/04
Video BIOS Date 04/12/04
BIOS Manufacturer:
Company Name Phoenix Technologies Ltd.
Product Information http://www.phoenix.com/en/products/default.htm
--------[ ACPI ]--------------------------------------------------------------------------------------------------------
[ APIC: Multiple APIC Description Table ]
ACPI Table Properties:
ACPI Signature APIC
Table Description Multiple APIC Description Table
Memory Address 3F779F43h
Table Length 94 bytes
OEM ID PTLTD
OEM Table ID APIC
OEM Revision 060400D0h
Creator ID LTP
Creator Revision 00000000h
Local APIC Address FEE00000h
[ BOOT: Simple Boot Flag Table ]
ACPI Signature BOOT
Table Description Simple Boot Flag Table
Memory Address &nbs
מה בדיוק המטרה של כל התוכן שהדבקת פה? אתה בכלל מבין מה כתוב שם?
אם זה מחשב מותג פשוט תיכנס לאתר של היצרן ותמצא את מה שצריך להדגם או ה product number/id.
זה מחשב שולחני (לא מותג)
בד'כ חיפוש דרייברים לפי שם הלוח בלבד מביא אותי לתוצאה.
משום מה אף דרייבר שהותקן משם לא עבד.
חשבתי אולי המידע הזה יעזור במשהו
אילו הבנתי מה נכתב שם לא הייתי שואל,ברור שלא.
מה זה משנה מה הform factor שלו אם זה מחשב מותג?
אתה גם לא תמצא שום דבר אם תמשיך לחפש ככה.
תעשה את מה שאמרתי ותמצא את מה שצריך.
תודה רבה!
