autocad 2009
מהם דרישות החומרה להרצת התוכנה בצורה סבירה
תודה מראש
32-bit AutoCAD 2009
Running under Windows XP:
•Microsoft Windows XP SP2 operating system
•Intel® Pentium® 4 processor or AMD Athlon®, 2.2 GHz or greater
or
Intel or AMD Dual Core processor, 1.6 GHz or greater
•1 GB RAM
•750 MB free hard disk space for installation
•1024x768 VGA with true color
•Microsoft Internet Explorer 6.0 (SP1 or higher)
If you are using AutoCAD for 3D modeling, you should bump up your system as follows:
•Intel Pentium 4 processor or AMD Athlon, 3.0 GHz or greater
or
Intel or AMD Dual Core processor, 2.0 GHz or greater
•2 GB RAM or greater
•2 GB of additional free hard disk space
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, OpenGL or Direct3D capable workstation class graphics card.
Running under Windows Vista:
•Microsoft Windows Vista operating system
or
•750 MB of free hard disk space for installation
•1,280 x 1,024 32-bit color video display adapter (true color) 128 MB or greater, Direct3D capable workstation class graphics card.
64-bit AutoCAD 2009
(The 64-bit AutoCAD cannot be installed on a 32-bit operating system)
•Windows XP Professional x64 Edition operating system
or
Windows Vista 64-bit operating system
•AMD 64 processor
or
Intel EM64T processor
•2 GB RAM
תודה רבה רבה מר בחור
