המלצה על חבילת תוכנות שנתקלתי בה כרגע
נתקלתי כרגע בשיטוטי באינטרנט בחבילת התוכנות:
Winternals Administrators Pak v4.0 Enterprise Edition
אני מכיר חלק מהתוכנות בחבילה זו ואני חייב לומר שתוכנות אלה/גרסאות קודמות שלהם בהחלט עזרו לי בשיקום מערכות נפולות שלי ושל אחרים. מומלץ ביותר:
Administrator's Pak 4.0 is a comprehensive suite of powerful, versatile tools that allow you to repair damaged or unbootable systems, restore lost data, and diagnose problems associated with Windows operating systems and file systems. Administrator's Pak includes 1. ERD Commander 2003, 2. Disk Commander, 3. NTFSDOS Professional, 4. Remote Recover, 5. Monitoring Tools, and 6. TCPView Pro. Incorporates the Locksmith utility for resetting lost Administrator passwords.
Key features:
* Boots dead systems directly from CD
* Easy, familiar Windows-like interface
* Includes the Locksmith utility to reset lost Administrator passwords
* Includes FileRestore so that you can quickly find and recover deleted files
* Provides access to XP Restore Points on unbootable Windows XP systems
* Compares key info on unbootable systems with that of a working system for diagnosis and trouble-shooting
* Allows for formatting and partitioning of disks
* Built-in network access to safely copy data to/from dead systems
* Repair and diagnostic tools located on Start menu
* Repair tools include Service and Driver Manager, Locksmith, FileRestore, Registry Editor, Explorer, Disk Management, and Command Prompt
* Diagnostic tools include the System Compare, Event Log Viewer, System Information, TCP/IP Configuration, and Logical volumes utilities
* Compatible with Windows NT, 2000, XP, and Server 2003
