Pentax K-7 :: היא כבר כאן
ביצועי AF
Compared to the K20D, the new Pentax K-7 feels faster and more responsive in virtually every respect. One area of particular improvement appears to be its AF system.
We don't have a quantitative measurement of AF performance in our test suite, and as of this writing have been able to make only limited and fairly unscientific comparisons between the prototype K-7 and K20D, but our strong subjective impression has been that the Pentax K-7 achieves focus much more quickly in difficult situations of low light and/or low subject contrast than does the K20D. This contributed greatly to the sense of responsiveness we felt when using the Pentax K-7.
http://www.imaging-resource.com/PRODS/K7/K7A.HTM#AFsystem
  • תגובות 120
  • צפיות 14.5k
במאמר ב-imaging-resource.com מציינים שתי סיבות לשיפור, הראשונה היא ה-AF Assist שמובנה במצלמה, אבל הסיבה השנייה מעניינת יותר ומראה שפנטקס לקחו מאוד ברצינות את נושא הפוקוס באור חלש:
This means that incoming reddish light won't be bent as much as bluish-tinted light would be. AF systems are adjusted to produce accurate results with daylight-balanced lighting, where all the colors are more or less equally represented. This works well in most situations, but when faced with a strongly-tinted light source, an AF system can misjudge the point of correct focus. Two commonly-encountered extremes are the very warm hue of household incandescent lighting, or the cool bluish tones of open shade outdoors. By measuring the overall tint of the ambient lighting, the AF system in the Pentax K7 can compensate for these errors, and deliver more accurate focusing under a wide range of light colors.
ציטוטים מעניינים נוספים:
We're pleased to report that the Pentax K7's Auto White Balance is excellent, easily compensating for tungsten lighting
- אף מצלמת DSLR לא עומדת בתיאור הזה, גם לא המצלמות של אולימפוס עם חיישן WB מובנה.
When shooting on a tripod, it is possible to fine-tune your framing by manually controlling the position and rotation of the image sensor. A total of one degree rotation and two millimeters of horizontal or vertical adjustment are available on either side of the centered position.
- אף מצלמה אחרת לא מאפשרת לשלוט על קומפוזיציה והטייה מבלי להזיז את המצלמה. נשמע נוח מאוד לצילום מדוייק עם חצובה.
Thanks to an internal leveling sensor, the K-7 also offers an electronic level function that actually rotates the sensor to a level position when enabled, correcting for errors of one degree in either direction. The Pentax K7 performs this unique trick whether held horizontal or vertical.
- עוד פיצ'ר חדשני. יש לאולימפוס ניקון וריקו מצלמות עם פלס דיגיטלי, אבל באף אחת מהן אין תיקון מובנה להטייה.
We've recorded videos with other SLRs using IS lenses, but the level of stabilization we found in the Pentax K7 seemed to significantly exceed anything we'd seen previously.
your videos will be remarkably stable, even holding the camera at arm's length, or when shooting with a long telephoto lens
- מלבד נושא המייצב, גם שאר הטקסט מלא התלהבות בכל מה שקשור במימוש של הווידאו ב-K-7. שווה מאוד לקרוא את החלק הזה.
ומביקורת אחרת:
One of the big deals about the K-7 to me is the shutter noise. It's very quiet. The main point of having a smallish camera is so that it's easy to carry it around with you wherever you go; and if you're using it as a visual notepad, you might call it, then quite often it's useful not to call attention to yourself by clacking away piercingly and drawing stares from anyone nearby. The K-7's shutter is quiet for an SLR by any standard, both in the level and the type of noise it makes. The AF noise is actually louder than the shutter.
- אחד החסרונות הכי בולטים של פנטקס (ובמידה רבה גם של סוני/מינולטה) הוא הרעש החזק יחסית של התריס. אם התיאור הזה נכון, מדובר בשיפור חשוב ומשמעותי.
אני לא יודע לגביך עמרי, אבל בשביל $1300 המצלמה הזו היא בהחלט WOW בעיני.
ביקורת מחמיאה נוספת:
http://www.digitalcamerareview.com/default.asp?newsID=4001&review=pentax+k7
the K-7 is the fastest Pentax DSLR ever made with a top burst shooting speed of 5.2 frames per second (40 JPEGs, 15 RAW/PEF or 14 RAW/DNG). Anyone who's still foolish enough to think Pentax cameras aren't fast enough for professional motorsports needs to spend an afternoon at the track with the K-7. Pentax also claims that the 11-point autofocus system in the K-7 uses improved focus algorithms over previous Pentax cameras ... and during my week-long test of the K-7 I can confirm it is noticeably faster than any Pentax camera I've previously used.
When it comes to image quality, I honestly feel like kissing the Pentax engineers responsible for the K-7. Although our pre-production unit didn't come with the final firmware, image quality at all ISO settings seems noticeably superior to the K10D or K20D in terms of image noise and color. More importantly, Pentax finally seems to have figured out how to build a camera with extremely accurate white balance.
כבוד גדול לפינטעקס. :yelclap:
מה דעתכם, המחיר עוד ירד שכן הוא MSRP?
עוד ציטוט בנושא הפוקוס:
I paired the K-7 with three high-quality lenses from Pentax DA* 55mm f/1.4 SDM; DA 55-300mm f/4-5.8ED; and 15mm f/4ED AL. I also shot with an excellent lens from Sigma in a Pentax mount, the 24-70mm, f/2.8 IF EX DG.
The new 11-point SAFOX VIII+ (lousy name) autofocus system was also quick and reliable even in this pre-production camera. The system uses 9 cross sensors, 2 wide-angle sensors, and has a dedicated assist lamp to help target your subject while shooting in low light. Speaking of low light, I was impressed with how quickly the pre-production camera locked in its focus in uneven and downright bad lighting.
According to a Pentax product person I spoke with, the K-7's new autofocus system detects colors and wavelengths of light which helps its locks in autofocus in tricky lighting conditions such as tungsten. I experienced very little to no "lens hunting" which was a big plus.
http://www.demystifyingdigital.com/Digital-SLR/Pentax-K7-Digital-SLR/index.aspx
מעניין אם ההתייחסות למהירות הפוקוס תופסת גם ל-55-300, עדשה שידועה כבעלת פוקוס איטי.
יודעים ?
זאת פעם ראשונה שאני מסתכל על מצלמת פנטקס כמועמדת רצינית לקנייה.
עד היום צילמתי עם Minolta בעיקר ולא רציתי לעבור לניקון וקאנון בגלל צבעים בתמונה.
נראה תוצאות מחיר סופי בארץ ומחירי עדשות של הפנטקס הזאתי ונשפוט.
באתר הזה יש מספר סירטוני פלאש שמציגים את ה K-7
http://www.popco.net/zboard/view.php?id=dica_review&no=399
יפה במיוחד היא ההשוואה ב-fps שלה מול ה-K20D, שהשאירה אותי בפה פעור, לא פחות.
K20D
K-7
וכאן יש השוואה במהירות הפוקוס על עדשת הקיט הסטנדרטית, 18-55:
K20D
K-7
השרת של האתר הזה ממש איטי, אני הורדתי את הקבצים עם FlashGet (בערך 2MB כ"א, בחלוקה של 4 חלקים במקביל זה יורד מהר) וראיתי אותם ברציפות מההרדיסק שלי.
אני בהלם מההשוואה.
וטוב לדעת שיש לי גוף שאני אוכל להתקדם אליו מהK200D כשאני אהיה מוכן D:
איפה יש השוואה טובה של הוידאו שהמצלמה עושה ?
במצלמות האחרות שנכנס אליהן וידאו 1080 או 720 כשמזיזים את המצלמה, הוידאו נוטה לצדדים, בא :puke:
אין, עדיין לא קיימת בעולם בכלל גירסת production של המצלמה הזאת.
אבל לא הבנתי מה אתה רוצה... שתזיז את המצלמה והוידאו לא יזוז? :screwy:
נראה לי שהוא מתכוון לזה שהתמונה "מנסה להתמיד במצבה" (נו מה לעשות.. עוד כמה ימים מגן במכניקה ;D) ואז פתאום קופצת.
אני חושב שזה קורה מframe rate נמוך
יתרונות ל-D300:
‏- AF עדיף - ‏51 חיישנים (מול 11), מתוכם ‏15 חיישנים מוצלבים (מול 9), שליטה על כמות הנקודות (9/21/51), פוקוס עוקב מבוסס צבע
- סנכרון 1/250 מול 1/180
- 8 תמונות בשניה (עם הגריפ) מול 5
- עינית עם הגדלה טיפה יותר גדולה (0.94 מול 0.92)
- תמיכה ב-RAW ‏14 ביט
- תצוגת גריד בעינית
- כפתור FUNC ניתן לתכנות
- תצוגת מצב סוללה מפורטת יותר
בשביל השלמת התמונה, הנה היתרונות של ה-K-7 על ה-D300, מהמשמעותי ועד לטריוויאלי (בעיני):
- מייצב מובנה בגוף
- ווידאו HD (‏720P, שליטה על צמצם ובהירות, כניסה למיקרופון סטראופוני, פוקוס מבוסס קונטרסט עם או בלי זיהוי פנים, ייצוב עם כל העדשות)
- מחיר נמוך ב-$400
- משקל נמוך ב-175 גרם; מימדים קומפקטיים באופן משמעותי
- פלס אלקטרוני כולל תיקון אופק אוטומטי בחיישן
- תמיכה ב-RAW פתוח (פורמט DNG עם דחיסה ללא אובדן מידע)
- מיפוי פיקסלים
- Preview דיגיטלי (צילום תמונת טסט ללא שמירה בכרטיס)
- הכפתור הירוק (משמש לאיפוס M ולמטרות נוספות); כפתורי WB, ISO ו-Menu נגישים ע"י יד ימין; כפתור RAW
- תיקון לסטיות AF מבוסס צבע
- HDR מובנה מבוסס על 3 חשיפות; אופציה לעד 9 חשיפות מרובות ללא מיפוי טונים וללא חשיפת יתר
- HyperProgram (עדיפות תריס ועדיפות צמצם כחלק מ-P)
- רזולוציה גבוהה יותר (14.6 מ"פ מול 12.3)
- אפשרות לכיול צבעים במסך ה-LCD
- התאמה לעבודה בטמפרטורה של עד 10- מעלות (מול 0 מעלות בניקון)
- חיווי לאבק על החיישן ע"י פריים לבן
- אופציה לשינוי קומפוזיציה באמצעות הזזת החיישן (הסטה למעלה/למטה/לצדדים והטייה)
- אופציה לשילוב שם הצלם ב-EXIF
אני חושב שהוא מתכוון לזה:
http://www.nikonwatch.com/2008/09/23/d90-movies-look-like-jello-oh-no/
http://www.crunchgear.com/2008/09/27/canon-5d-mark-ii-exhibits-jello-effect-not-as-bad-as-d90
קרא חבר ותפסיק לעשות לי פרצופים :silly:
http://www.dpreview.com/reviews/nikond90/page18.asp
