Hearts of Iron 3 - הדיון הראשי
מפתחת המשחק: Paradox Interactive
קישור לאתר הרשמי של המשחקהאתר הרישמי של המשחק , DEMO להורדה, קישור למשחק ב STEAM
בונוס מהיוצרים המדריך המקוצר למשחק ו המדריך המלא למשחק
Hearts of Iron 3:
The next Grand Strategy title from the Paradox Interactive development team is the third instalment in the critically acclaimed Hearts of Iron series.
The Hearts of Iron series has become renowned for being the biggest, most detailed and complete strategic game series on World War 2 ever made. Hearts of Iron III will follow that tradition closely while focusing on satisfying veteran players through a multitude of brand new features and systems, including a huge map with more than 14,000 land and sea provinces.
# Hearts of Iron III is scheduled for release in Q3, 2009.
# Currently in beta development stages.
Preview:
You'll be able to play as any country in the world, and while it will be beneficial to control one of the major Allied or Axis forces, there's no reason you can't head up Romania or an equally small nation instead.
You'll command your armies using a world map view, and it's from here that you can dip into the various menus that will influence your actions. The diplomacy menu will let you see your relationship with other countries, and you'll be able to see each nation's political allegiance towards democracy, communism, and fascism.
Another key aspect of the game is where each country stands in terms of being aligned with the Allied powers, Axis forces, or Comintern. This affects certain skills, because the Comintern states, for instance, can barter for goods, whereas the Axis powers tend to take things by force. You also have to take care of technology, and the game displays tech trees where you can allocate resources to things such as infantry theory. We're also promised a greater number of intelligence considerations, which are tied in to the number of spies you have, and it's all about allocating spies to certain countries over others.
The military aspect of the game promises to have stronger AI than before; you'll be able to tell your troops where to march and then let the computer take care of the rest. The game will also give you hints every step of the way, so you don't need to have played the previous games to get into the third. We also like the new leadership option that gives you greater control of your country's manpower, right down to lower-level skill groups and university graduates.
Features:
* Play as any nation from 1936 to 1948, more than 150 countries to choose from.
* Control the oceans with aircraft carriers, submarines and battleships and use your air force to defend
your skies, support your naval and ground forces, and to bomb your enemies
* Thousands of historically accurate real-world military commanders and politicians.
* Realistic military command AI with unprecedented levels of interaction
* In-depth diplomatic and political system.
* Historical accuracy combined with an unparalleled level of freedom of choice
* Customize your divisions in detail with more than 20 types of brigades
* Government-in-exile makes it possible to continue to struggle from abroad with underground
movements and uprisings against the oppressing power.
* Strategic warfare system makes it more important to defend the skies and oceans against foreign attacks
leaving cities open to enemy bombing will now be devastating.
* A completely new intelligence system, with several types of intelligence sources, makes it possible to
get information about enemy reserves and troop movements.
* Assign troops to theatres on the map to fight two-front wars more successfully.
* The new AI system and more detailed map will allow for more strategic decisions.
* Flexible technology system with hundreds of categories, and unlimited research.
* Highly realistic historical order of battles.
* The first realistic logistic system ever in a strategy game.
Minimum Requirements to play the game and not see a slideshow:
# PC with 1024 MB of RAM (2048 on Vista)
# Windows XP/Vista
# Graphics card with at least 256 MB onboard memory, and 2.0 vertex and pixel shaders.
# The game will take advantage of multi-core systems.
הטיזר של המשחק:
Hearts of Iron 3 - Early Game Presentation
Hearts of Iron 3 - Blitzkrieg
HOI3 ingame footage (no comentary just footage + background music) תאמת קצת משעממים.
סרטון מהמשחק הקודם בסדרה HOI2(שיצא בשנת 2005) של איזה שחקן שמתעד את המשחק שלו עם גרמניה:
טרילר מהמשחק הקודם בסדרה:
http://www.youtube.com/watch?v=5Jot0g_XuMw
סרטון כללי בשביל להכנס לאווירה:
  • 3 חודשים מאוחר יותר...
יש כאן עוד ישראלים עם המשחק?
יהיה נחמד לעשות משחק multi של ישראלים ולמחוק ביחד את היהודים מן העולם 8)
אני לא מצליח להוריד את המשחק :nixweiss:
כל פעם שאני מוריד (והורדתי כבר 3 פעמים) בשלב מסויים של פתיחת הקובץ הוא אומר שהקובץ מושחת ושצריך להוריד מחדש.
יש למישהו מושג למה? ???
מצטער אני בהפסקה ממשחקים עד סוף החודש כך שאני אלא יכול להגיד לך מניסיון
אבל תנסה אולי לפנות ל STEAM ??
ניסיתי להוריד בפעם הרביעית (כל פעם זה ממקור אחר) ושוב זה נכשל....
זו ההודעה שהוא מציג בlog
CRC failed in data2.cab
Unexpected end of archive
[br]פורסם בתאריך: 10.08.2009 בשעה 13:35:45
פעם חמישית גלידה! :yelclap:
עכשיו התחלתי את ההדרכה, יש להם חוש הומור! :o
המממ הבנתי שכמו רוב יצרני המשחקים היום גם PARADOX לא מסוגלים שלא לדחוף מוצר לא מוכן לשוק ...
מה שיותר גרוע במשחק הספציפי הזה מכיוון שבמשחקי MICRO כאלה יש הרבה דברים שיכולים להיותר GAME BRAKERS
ממולץ, לחכות עד לפרסום PATCH 1.2 אמור לפתור בעיות ביצועים הרבה באגים
ולהוסיף את הSLIDERים האוטומטים עבור הבניה וניהול יחסי מסחר אוטומטים מה שימנע CLICK FEST מטורף, אין לי מושג למה הם החליטו להוריד את זה מלכתחילה...
בכל מקרה אם מישהו עכשיו נתקל בבעיות איטיות יש מצב שיש לו את ה נאג עם קבצי ה SAVE שינסה את זה:
http://rapidshare.com/files/267122527/HoI3SaveCleanerA2.rar
בכל מקרה עד סוף חודש לא יהיה לי זמן, אבל אחרי זה אני אפרט יותר ואפתח את הכול מחדש לבקשת המנהל פה.
המשחק מורכב ואיטי מדיי לטעמי.... :'(
כנראה שאני אסיר את הדמו. :-\
המשחק שעבר למנוע משחק אחר, סובל מאותם הבעיות שקודמו בסדרה סבל בתחילתו אבל בתקווה שזה אמור להפתר בקרוב.
לגבי האיטיות, אתה בהחלט צודק ... מה שבטוח זה בהחלט משחק עם הבסיס הכי טוב שיש כרגע בשוק
צריך רק לחכות שיצאו כמה PATCHים וכמה מודים לFLAVOR, במקרה הזה אני חושב שאני יודע איזה MOD יהיה הכי טוב לחברה חדשים כי זה בהחלט יכול להיות קצת יותר מידי בהתחלה, גמו שצינתי אני העדכן בעתיד.
לי פשוט אין סבלנות במשחק הזה. יש שם learning curve לא קטן. אני מעדיף משחקים עם יכולת שליטה טקטית . אני רוצה לראות את החיילים נהרגים בשטח ושיהיה לי שליטה על מהלך הקרב. כל הmicromanagment כבד לי מדי על המוח.
המשחקים בתורות שאני אוהב הם jagged alliance 2 , slient storm series, xcom 1-3 , ufo aftershock ,master of orion 1/2 . אני גם משחק infantry online ולמרות שזה משחק פעולה יש שם הרבה מאוד טקטיקה והראית משחק היא top down כמו בrts . יש לשחקנים בעלי ראיה טקטית טובה את היכולת לקדם את הקבוצה אפילו יותר מאשר שחקנים עם יכולת אישית טובה בעיקר במשחקי capture the flag שאני משחק. צריך לדעת באיזה נשק להשתמש מתי, מי המטרה שהכי כדאי להרוג (לרוב את הmedic ) ומתי כדאי להקריב את עצמך תמורת התקדמות טקטית. צריך גם לדעת לחשב סיכויי הישרדות ורמת סיכון של מסתננים כדי לא להחליש את מערך ההגנה הקידמית (להרחיק את האויב מהמטרה זאת ההגנה הכי טובה או במילים אחרות התקפה).
