האם אוכל לשים זיכרונות של SDRAM?
שאלה שניה: יש לי כבר סטיק 256MB של DDR האם נכון להוסיף 2 סטיקים של SDRAM?
מצ"ב דו"ח אוורסט
motherboard: Epox EP-8RDA3(I)/8RDAE(I)
Motherboard:
CPU Type AMD Athlon XP, 1833 MHz 2500+
Motherboard Name nVidia-nForce
Motherboard Chipset nVIDIA nForce2 Ultra 400
System Memory 256 MB
--------[ DMI ]---------------------------------------------------------------------------------------------------------
[ BIOS ]
BIOS Properties:
Size 64 KB
Boot Devices Floppy Disk, Hard Disk, ATAPI ZIP, LS-120
Capabilities Unknown
Supported Standards DMI, ACPI
Expansion Capabilities AGP, USB
[ System ]
System Properties:
Wake-Up Type Power Switch
[ Motherboard ]
Motherboard Properties:
Product nVidia-nForce
[ Chassis ]
Chassis Properties:
Chassis Type Desktop Case
[ Memory Controller ]
Memory Controller Properties:
Error Detection Method 8-bit Parity
Error Correction None
Supported Memory Interleave 1-Way
Current Memory Interleave 1-Way
Supported Memory Speeds 70ns, 60ns
Supported Memory Types SPM, EDO
Supported Memory Voltages 5V
Maximum Memory Module Size 32 MB
Memory Slots 3
[ Processors / AMD Athlon(tm) XP ]
Processor Properties:
Manufacturer AMD
Version AMD Athlon(tm) XP
External Clock 166 MHz
Current Clock 1833 MHz
Type Central Processor
Voltage 3.3 V
Status Enabled
Upgrade ZIF
Socket Designation Socket A
[ Caches / Internal Cache ]
Cache Properties:
Type Internal
Status Enabled
Operational Mode Write-Back
Maximum Size 128 KB
Installed Size 128 KB
Supported SRAM Type Synchronous
Current SRAM Type Synchronous
Socket Designation Internal Cache
[ Caches / External Cache ]
Cache Properties:
Type External
Status Enabled
Maximum Size 512 KB
Installed Size 512 KB
Socket Designation External Cache
[ Memory Modules / A0 ]
Memory Module Properties:
Socket Designation A0
Speed 60 ns
Installed Size 256 MB
Enabled Size 256 MB
[ Memory Modules / A1 ]
Socket Designation A1
Speed 60 ns
Installed Size Not Installed
Enabled Size Not Installed
[ Memory Modules / A2 ]
Socket Designation A2
Speed 60 ns
[ Memory Devices / A0 ]
Memory Device Properties:
Form Factor DIMM
Size 256 MB
Device Locator A0
Bank Locator Bank0/1
[ Memory Devices / A1 ]
Form Factor DIMM
Device Locator A1
Bank Locator Bank2/3
[ Memory Devices / A2 ]
Form Factor DIMM
Device Locator A2
Bank Locator Bank4/5
[ System Slots / PCI0 ]
System Slot Properties:
Slot Designation PCI0
Type PCI
Usage In Use
Data Bus Width 32-bit
Length Long
[ System Slots / PCI1 ]
Slot Designation PCI1
Type PCI
Usage Empty
Length Long
[ System Slots / PCI2 ]
Slot Designation PCI2
Type PCI
Usage In Use
Length Long
[ System Slots / PCI3 ]
Slot Designation PCI3
Type PCI
Usage In Use
Length Long
[ System Slots / PCI4 ]
Slot Designation PCI4
Type PCI
Usage Empty
Length
--------[ Motherboard ]-------------------------------------------------------------------------------------------------
Motherboard ID <DMI>
--------[ Chipset ]-----------------------------------------------------------------------------------------------------
[ North Bridge: nVIDIA nForce2 Ultra 400 ]
North Bridge Properties:
North Bridge nVIDIA nForce2 Ultra 400
Supported FSB Speeds FSB200, FSB266, FSB333, FSB400
Supported Memory Types DDR-200 SDRAM, DDR-266 SDRAM, DDR-333 SDRAM, DDR-400 SDRAM
Chipset Manufacturer:
Company Name NVIDIA Corporation
Product Information [url]http://www.nvidia.com/page/mobo.html[/url]
Driver Download [url]http://www.nvidia.com/content/drivers/drivers.asp[/url]
Driver Update
יש לוחות ישנים שתומכים גם ב DDR וגם ב SDR, בכל מקרה אי אפשר לשלב DDR אם SDR.
