הדיון הראשי על הדרייבר - AMD Catalyst (שוחרר 12.08)
ה-11.4 דופק לי את הפוטושופ.
האם חזרה ל-11.3 יהווה ירידה בביצועים?
  • תגובות 2.4k
  • צפיות 360k
תבדוק ... אין תשובה עדיין זה דרייבר חדש
אולי תתקין שוב את הפוטושופ ? תנסה
זה קרה לי גם עם הבטא.
גם אם קיים הפרש ביצועים בן המלא ובטא, לא מחייב שהוא דווקא ב 3DMARK...
בקרוב יצוצו ביקורות שלו מול הבטא...
Performance Enhancements
A number of performance enhancements are seen with the AMD Radeon HD 6900 Series and AMD Radeon HD 6800 Series:
Call of Duty Black Ops – gains of up to 15% with Anti-Aliasing and Anisotropic Filtering on single GPU configurations.
Battleforge – gains of up to 15% with Anti-Aliasing and Anisotropic Filtering on single and multiple GPU configurations.
Batman Arkham Asylum – gains of up to 20% with Anti-Aliasing and Anisotropic Filtering on single and multiple GPU configurations.
Aliens vs. Predator – gains of up to 8% with Anti-Aliasing and Anisotropic Filtering on single and multiple GPU configurations.
Civilization 5 – gains of up to 15% on single and multiple GPU configurations.
Far Cry 2 – gains of up to 6% on single and multiple GPU configurations.
Just Cause 2 – gains of up to 9% on single and multiple GPU configurations.
Lost Planet 2 – gains of up to 10% on single and multiple GPU configurations.
Resolved Issues for the Windows 7 Operating System
This section provides information on resolved known issues in this release of the AMD Catalyst 11.4 software suite for Windows 7. These include:
The GPU no longer shows high GPU usage after running Firefox 4 with hardware acceleration enabled.
Bioshock no longer displays random tearing and screen corruption with Vsync and MLAA enabled.
Water textures no longer flicker in Two Worlds II in Crossfire mode.
Bulletstorm lightshafts no longer appear broken when running on a HD 6970 series product.
Bulletstorm no longer displays random texture corruption when running in Crossfire mode.
FI 2010 no longer slows down intermittently when in Crossfire mode.
PowerDVD no longer crashes if Crossfire is enabled / disabled during playback of a BD title.
WinDVD no longer displays corrupted BD playback when the monitor is rotated to portrait mode.
Crysis Warhead corruption is no longer randomly observed when launching the game.
Running the Heaven benchmark no longer displays graphics corruption during DirectX 11 tests.
Catalyst Control Center Avivo settings are now correctly displayed after connecting a secondary display.
The Catalyst Control Center screen no longer flickers while adjusting screen brightness.
  • 2 שבועות מאוחר יותר...
ידוע פרטים עליו?
כרגע רק שהוא מתקן את הבעיה בפוטושופ שיש עם 11.4, שיפור ביצועים שולי ב HEAVEN + 3DMARK.
אני מאמין שיהיה בנצ'ים בקרוב...
אני מקווה שה"בעיה" ב- Photoshop נובעת משינוי מהותי במחסנית ה- Open GL של ATI.
כי היא לא כל כך מרשימה ויש שם הרבה מה לתקן.
המקור שהבאת הוא אמין? זה בא מטעם ATI?
כמובן שזה מגיע מ AMD, כמו כל דרייבר, ההדלפה נלקחה מהפורומים של GURU3D, נזקים זה לא עושה... תנסה, אוליי יסדר לך את הבעיה בפוטושופ ( לך הייתה בעיה לא ? )
ואם כן תעדכן שנדע :)
שוחרר השניה 11.5 גירסה רישמית.
לווינדז 7 64ביט:
http://sites.amd.com/us/game/downloads/Pages/radeon_win7-64.aspx
ווינדוז 7 32ביט:
http://sites.amd.com/us/game/downloads/Pages/radeon_win7-32.aspx
עוד לא יצא לי להיות על ווינדוז בשביל לבדוק עם הפוטושופ, אז אבדוק בהקדם ואני יעדכן כאן.
בבקשה לעדכן את הכותרת שידעו כל אלו שעוקבים פה..
:s05: רשמית בתאריך כל כך מוקדם ?!
מוזר... מוריד :D
אחד המתכנתים שלו כתב בטוויטר.. לכן ידעתי את זה ישר..
למה אתה לא יכול לערוך את הכותרת הראשית של ההודעה הזו?
