Grand Theft Auto IV - הדיון הראשי
יש לי משהו מוזר מאוד המשחק בהגדרות הוא מראה רק 447mb זיכרון בכרטיס מסך ויש לי 8800gt 512mb
למי שיש 8800gt גם לכם הוא לא מראה את כל הזיכרון ? או שזה אמור להיות ככה?
  • תגובות 606
  • צפיות 72.8k
אצלי מראה 474...
מישהו יודע למה אני לא רואה קירות של בתים וגם הכביש לפעמים נעלם ?!
טוב... החבילה המשופצרת תגיע בקרוב... ולא, לא מישראל המסורסת
מאיפה המידע? :D
IGN: Can you talk about what you're working on right now, like a patch?
Kevin Hoare: We've never stopped working on the game, we're working on it every day. We haven't had the typical break after it's gone gold. We're continually working on improvements, we're working on a patch right now.
IGN: Can you say what the patch will address and what sort of timetable there might be?
Kevin Hoare: We've done some improvements to the video editor and the rendering engine for the replay editor. We've added, again from feedback from the forums, we initially didn't support direct-input controller devices and people seemed to want that, so we added support for direct-input devices. I think there was an issue with bowling
Arthur Chiang: We read that some people with sensitive mice were having trouble with the bowling mini-game so we looked into that more and we've got a fix for that. There's a bunch of little UI tweaks because we've come a long way in our video editing prowess and we've been slowly increasing the user functionality to make things easier for what we want to do with it.
Jeronimo Barrera: Let's not beat around the bush here. There's a lot of noise like this game doesn't run at all or there's missing textures and everything else. From what we've gathered a lot of those problems are either out of date drivers or we don't support that type of card or you're underspecced or whatever, it's always a combination of one of those things, it's not necessarily that we don't know what we're doing because obviously we put in hundreds and hundreds of hours of test into this. From what we did and from going through certification with Microsoft and our external QA process we didn't run into the amount of problems that the boards seemed to be saying there are. I know that Nvidia and ATI are constantlyI think they're releasing new drivers pretty soon.
(ATI drivers are coming next Wednesday, according to Rockstar. Nvidia drivers are up now)
Obviously when you start talking about high-end PC games people want to tweak with their drivers and everything else and we've found some situations where people have modified their drivers by going to sites where you can customize drivers, and we've found problems with that. We're seeing some of the things that people are complaining about but they're so peripheral of the target audience.
http://www.maxconsole.net/?mode=news&newsid=34331
קשה לישר לשמאל?
מישהו יכול להסביר לי טיפה על האצימנטים
איפה הם נשמרים ? (בחשבון LIVE או על המחשב)
הם רק ל multi player או גם בסינגל?
ועוד שאלה, במידה ואני קונה את המשחק דרך חנות, אני יוכל להוסיף את המשחק לחשבון STEAM שלי דרך ה CDKEY?
יש לי כרטיס מסך 8500gt geforce 512mb
זיכרון 2.0gb
והמעבד דואל כור e6750 2.66 GHZ
אתם אומרים המשחק יעבוד אצלי?
אגב למי שיש את הגרסה של ה-PS3, יצא עידכון שמוסיף Achievements סליחה Trophies (גם ל BF:BC אגב), אבל הוא דופק שמירות מסוף המשחק (שמירות Story Completed).
עם כרטיס מסך טוב (כרגע זה לא משנה איזה, אני אקנה בהתאם לדרישה אחרי שיצאו פאצ'ים עדכון).
ה- E8400 (באוברקלוק ל 4.3) יהווה צוואר בקבוק רציני בגלל שהוא "רק" דואל קור ?
השאלה לא אם המשחק יכול לפעול טוב יותר על קוואד אלא אם הוא יצלע בגלל זה.
תודה.
הוא מתוכנת לעבוד על מרובעי ליבה
ראיתי את הצ'יטים בדף הראשי אבל מה זה אצ'יבמנטים?
וגם יש לי בעיה קטנה..
אני נכנס להגדרות-Audio ואז עושה scan (אחרי ששמתי שירים בתיקיה שצריך..) וזה לוקח לו 0.0001 שניות (הוא לא עושה כלום בעצם..) ואז שאני נכנס לרכב לתחנה שצריך אני לא שומע את השירים שלי..
מה לעשות?
תודה.
יכול להיות בכלל שה512MB שבכרטיס שלי יגבילו אותי קצת במשחק? כי הבנתי שהוא זולל זיכרון לא נורמלי.
איך זה יכול להיות? הרי לXBOX360 יש 512MB בכרטיס (או פחות?).
