מהו המחיר של זכרון Kingston DDR I
לא כל לוח מאפשר 3 סטיקים של זכרונות.. תן דגם של לוח-אם, ואני אבדוק לך מה הלוח שלך מאפשר.
SiSoftware Sandra
Mainboard
Manufacturer : Gigabyte Technology Co., Ltd.
Multi-Processor (MP) Support : No
MPS Version : 1.40
Model : GA-K8NMF-9
Version : x.x
Serial Number : Sun Aug 14 03:56:51 2005
System BIOS : 07/16/2005-NF-CK804-6A61FG0FC-00
Chipset : nVidia nForce4 & Ultra MCP
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 4
Maximum Installable Memory : 16GB
Bank0/1 - A0 : DIMM 512MB/64 @ 200MHz
Bank2/3 - A1 : DIMM 512MB/64 @ 200MHz
Bank4/5 - A2 : Empty
Bank6/7 - A3 : Empty
Chipset
Model : AMD Athlon 64 / Opteron HyperTransport Technology Configuration
Revision : A1
Bus : HyperTransport
Version : 1.02
Front Side Bus Speed : 2x 804MHz (1.61GHz)
Maximum FSB Speed : 2x 1GHz (2GHz)
In/Out Width : 16-bit / 16-bit
I/O Queue Depth : 8 request(s)
Maximum Bus Bandwidth : 6.28GB/s
Chipset 1 Hub Interface
Type : HyperTransport
Version : 1.02
Logical/Chipset Memory Banks
Bank 0 : 512MB DDR 3.0-3-3-8 2-11-3-2 2T
Supported Memory Types : ECC DDR Registered
Channels : 2
Memory Bus Speed : 2x 201MHz (402MHz)
Maximum Memory Speed : 2x 200MHz (400MHz)
Multiplier : 1/9x
Width : 64-bit
Memory Controller in Processor : Yes
Cores per Memory Controller : 1 Unit(s)
Refresh Rate : 7.80µs
Power Save Mode : No
Fixed Hole Present : No
Maximum Memory Bus Bandwidth : 6.28GB/s
APIC 1
Version : 1.01
Maximum Interrupts : 24
IRQ Handler Engaged : Yes
Enhanced Support : Yes
Memory Module 1
Manufacturer : Kingston
Model : K
Serial Number : 77068CC2
Type : 256MB DDR
Technology : 8x(32Mx8)
Speed : PC3200U DDR-200
Standard Timings : 3.0-3-3-8 2-11-0-0
Date of Manufacture : יוםשני 25 מרץ 1996
Memory DC Line : 2.50V
Set Timing @ 200MHz : 3.0-3-3-8 2-11-0-0
Set Timing @ 167MHz : 2.5-2-2-7 2-9-0-0
Set Timing @ 133MHz : 2.0-2-2-5 1-7-0-0
Memory Module 2
Model : K
Serial Number : 760680C2
Type : 256MB DDR
Environment Monitor 1
Model : ITE IT8712F LPC
Version : 5.00
Mainboard Specific Support : No
Environment Monitor 2
Model : AMD K8 CPU [P0, C1, SC0, SN0]
Version : 47.00
Temperature Sensor(s)
Board Temperature : 53.00°C
CPU Temperature : 44.00°C td
Auxiliary Temperature : 71.00°C
Cooling Device(s)
Auto Fan Speed Control : No
System Fan : 3516rpm
Voltage Sensor(s)
CPU DC Line : 1.42V
Aux DC Line : 2.59V
+3.3V DC Line : 3.28V
+5V DC Line : 2.10V
+12V DC Line : 11.48V
-12V DC Line : -4.46V
-5V DC Line : -2.39V
Standby DC Line : 3.44V
System Bus(es) on Hub 1
Version : 2.30
System Bus 0 : PCI
System Bus 1 : PCI
System Bus 2 : PCIe 1.00 x2 2.5Gbps
System Bus 3 : PCIe 1.00 x1 2.5Gbps
System Bus 4 : PCIe 1.00 x1 2.5Gbps
System Bus 5 : PCIe 1.00 x16 2.5Gbps
LPC Hub Controller 1
Model : Giga-Byte nForce4 PCI to ISA Bridge
Revision : K4
ACPI Power Management Support : Yes
ACPI Power Management Enabled : No
LPC Hub Controller 2
Model : Giga-Byte nForce4 SMBus
Revision : K3
Audio Device
Model : Giga-Byte nForce4 AC'97 Audio Controller
Revision : K3
Type : AC '97
Version : 2.03
Audio Codec
Model : Realtek Semiconductor ??? (0090)
Revision : A1
Version : 2.03
USB Controller 1
Model : Giga-Byte nForce4 USB Controller
Revision : K3
Version : 1.00
Interface : OHCI
Channels : 10
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps)
Legacy Emulation Enabled : No
USB Controller 2
Model : Giga-Byte nForce4 USB 2.0 Controller
Revision : K4
Version : 2.00
Specification : 1.00
Interface : EHCI
Channels : 10
Companion Controllers : 1
Supported Speed(s) : Low (1.5Mbps) Full (12Mbps) High (480Mbps)
Addressing Support : 32-bit
FireWire/1394 Controller 1
Model : Giga-Byte TSB43AB23 1394a-2000 OHCI PHY/link-layer Controller
Revision : A1
Version : 1.10
Interface : OHCI
Channels : 64
Speed : 400MHz
System SMBus Controller 1
Model : nVidia MCP2+ SMBus 1
Version : A.02
Advanced TCO Mode Enabled : No
Slave Device Enabled : No
PEC Support : No
System SMBus Controller 2
Model : nVidia MCP2+ SMBus 2
Version : A.02
PEC Support : No
Expansion Slot(s)
PCI (9h) : PCI 32-bit +5V +3.3V PME i2c/SMBus Full-Length Available
PCI (Eh) : PCI 32-bit +5V +3.3V PME i2c/SMBus Full-Length Available
Port Connector(s)
PRIMARY IDE : ATA
SECONDARY IDE : ATA
FDD : 8251 FIFO / Floppy Disk
COM1 : Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male
COM2 : Serial Port 16450 / 9 Pin Dual Inline / DB-9 pin male
LPT1 : Parallel Port ECP/EPP / DB-25 pin female / DB-25 pin female
Keyboard : Keyboard / PS/2
PS/2 Mouse - No Detected : Mouse / PS/2 / PS/2
USB : USB / USB
Performance Tips
Tip 2532 : Consider adding more CPUs for better utilisation.
Notice 224 : SMBIOS/DMI information may be inaccurate.
Tip 2511 : Some memory slots are free so the memory can be easily upgraded.
Warning 100 : Large memory sizes should be made of Registered/Buffered memory.
Tip 2546 : Large memory modules should be ECC/Parity.
Warning 2518 : Mainboard temperature is too high.
Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip.
העתקתי הכל :S
הלוח שלך לא מאפשר 3 סטיקים.. או שתוסיף עוד 2 ואז יהיו לך 4 סטיקים.
או שתחליף את 2 הסטיקים בשניים אחרים.
עדיף לך ארבעה סטיקים ככה אתה לא מפסיד את הנפח שכבר יש לך, זה יותר משמעותי מירידה בCL או במהירות הכללית.
