E7200 vs E8400
hey everyone,
I can't write in hebrew although I can read
I am interested in buying a new computer and was wondering what's the difference between the
E7200 and E8400. i thought that the advantage of these processors is the 45nm litography which they both are
is it just clock speed and 1066mhz vs 1333mhz? how significant is it with normal DDR2 memory sticks?
the cost difference is significant standing at 540 vs 785nis and was just wondering what will i lose by choosing the E7200
thanks[br]פורסם בתאריך: 29.09.2008 בשעה 23:47:49
I think that what i'm trying to say is that i'm looking for the best bang for the buck,
meaning that if the e8400 is alot better than the e7200, i can afford to buy that, but if its just a little advantage that won't be noticed and is only noticed in say.... overclocking which I won't do... then the cheaper one will do
שכחת גם של 7200 יש חצי מכמות הקאש של ה 8400
so how much of a difference in performance is it ?
for a +45% in price difference, worth the addition clock speed, cache and all ?
שניהם ממשפחת WOLFDALE הE7200 הוא יותר כלכלי זה כן,
בקשר לביצועים הE7200 נשאר 10% מאחור במשחקים(ביישומים זה 5%)
לאחר המהרה ל4.0GHZ! זיכרון המטמון משחק תפקיד חשוב וכך גם הFSB
אז אם התקציב מאפשר אין כל כך התלבטות.
