הגרלת פאנלים בSamsung SyncMaster T220?
http://www.xtremesystems.org/forums/showthread.php?t=184289
PROS
* Very little calibration needed. Black and white levels are excellent as is colour reproduction.
* Picture very sharp and crisp.
* Made in Romania with Q4 build date, so built last month.
* No panel version on the back or in the secret menu, but version is M-TW22H0CAA-1000.6, which should be a Samsung panel:
* X-xxxxxxxAx-xxxx: Samsung panel.
* X-xxxxxxxLx-xxxx: AU Optronics panel.
* X-xxxxxxxDx-xxxx: CMO panel.
* X-xxxxxxxIx-xxxx: CPT panel.
* No noise from the monitor whatsoever.
* No artifacts from using RTA (overdrive for better response times)
* Good smoothness during movement
* Bezel design looks good but very red in daylight! Fits with my setup though.
CONS
* Some backlight bleed evident, but seems to be fading.
* Only came with a generic manual. Proper manual available online though.
* Software provided didn't work. Needed to download updated version.
I have a couple of weeks to see if the bleed fades enough before deciding whether to keep it or not.
