פורסם 2002 בפברואר 924 שנים אני מקבל הודעות מתוכנות שונות שה-WRITE CACHE לא פועל וההרד דיסק ממש איטי :'( H.D IBM 45 MBABIT KT7כל הדרייברים מעודכניםיש למישהו פיתרון לבעיה
פורסם 2002 בפברואר 924 שנים לקוח מפה : In order to ensure your memory subsystem is performing as best it can you need to have your Hard Drive configured to perform similarly, this is because the Pagefile resides on the Hard Drive also. As a result improving your Hard Drives performance will also improve memory performance. Right click on My Computer & select Properties, then the Hardware tab, followed by the Device Manager button. Expand the Disk drives tree & highlight (select) your Hard Drive (If you have multiple Hard Drives installed apply the following steps to each of them). Right click on the selected drive & select Properties then the Policies button Enable write caching on the disk. Ticking this setting can improve hard drive I/O performance by enabling the use of the hard drive write-back cache. This could cause data corruption in the event of the PC shutting down unexpectedly, e.g. through power failure. If your PC is prone to this sort of failure then Untick this setting to ensure data integrity, although it would be wisest to find the source of this problem & get it fixed of course. Those without such problems should leave this Ticked for best Hard Drive performance.
