בעיית OpenGL \ דרייברים
נגמרו לי הפתרונות. ככל הנראה, כל משחק שרץ על על OpenGL פשוט מתמוטט ולא עובד לי. ניסיתי להתקין דרייברים מחדש, וזה לא עזר.
תגללו לאמצע ותמצאו את הקטע של "|Extension GL_EXT_clip_volume_hint not available" וכו'.
בינתיים זה קרא לי ב-Second Life ו-ב911 first responders
911 First Responders:
Init Filesystem...
Registered FS device "local"
Registered FS device "base"
Registered FS device "lang"
Init UpdateChain...
Init Timer...
Init Screen...
Init Scriptscheduler...
!Graphics system: Microsoft Corporation GDI Generic
GL_WIN_swap_hint GL_EXT_bgra GL_EXT_paletted_texture
CPU speed detected: 2411
Init GFX...
Init Vision...
|Vision DLL path: E:\Games\911 First responders\vision71.dll
|Vision(TM), Version PC-4, 7, 28, 0
|Loading entity plugins of directory <E:\Games\911 First responders\Data> ...
|List of loaded plug-ins:
|Plug-in named 'CubeMapHandle_cl' loaded statically!
|Plug-in named 'VisionConsoleEntity_cl' loaded statically!
|Plug-in named 'VisBase_cl' loaded statically!
|Plug-in named 'VisBaseEntity_cl' loaded statically!
|Plug-in named 'VisMouseCamera_cl' loaded statically!
|Plug-in named 'VisObject3D_cl' loaded statically!
|Plug-in named 'VisActionHelperEntity_cl' loaded statically!
|Plug-in named 'VarManager_cl' loaded statically!
|Plug-in named 'BaseEntity_cl' loaded statically!
|Plug-in named 'VBaseCameraEntity' loaded statically!
|Plug-in named 'VCamEntity' loaded statically!
|Plug-in named 'GameEntity_cl' loaded statically!
|Plug-in named 'Emitter_cl' loaded statically!
|Plug-in named 'BaseGameEntity_cl' loaded statically!
|Plug-in named 'TargetEntity_cl' loaded statically!
|Registering plug-ins done !
|Initializing Vision Graphics Engine
|Detecting CPU type and features
|CPU:Pentium II/III FPU MMX ISSE 3DNow!
|Vision Core: Allocated 28 kB of memory for Polygon Chunks
|Vision Core: Allocated 9 kB of memory for Entities
|Settings renderer configuration
Initializing post processor 'PerceptionCore'
* Skipping config file
Initializing post processor 'MotionBlur'
Initializing post processor 'Nightvision'
|Initialising video driver: 0
|Setting screen mode to x:1024 / y:768 / bpp:32 / refresh:0
|Screen Mode is fullscreen, return value: -401
|Stencil buffer: 8 bit / ZBuffer: 32 bit
|Initializing OpenGL rendering subsystem
|Setting initial Renderer States
|Vendor: Microsoft Corporation
|Renderer: GDI Generic
|Driver Version: 1.1.0
|Extension GL_EXT_texture_filter_anisotropic not available
|Extension GL_EXT_texture_lod_bias not available
|Extension GL_ARB_multitexture not available
|Extension GL_ARB_texture_env_dot3 not available
|Extension GL_ARB_texture_env_subtract not available
|Extension GL_EXT_texture_edge_clamp not available
|Extension GL_EXT_texture_env_add not available
|Extension GL_EXT_texture_env_combine not available
|Extension GL_EXT_texture_cube_map not available
|Extension GL_ARB_texture_compression not available
|Extension GL_EXT_point_parameters not available
|Extension GL_EXT_vertex_weighting not available
|Extension GL_EXT_separate_specular_color not available
|Extension GL_EXT_stencil_wrap not available
|Extension GL_EXT_vertex_shader not available
|Extension GL_EXT_multi_draw_arrays not available
|Extension GL_ATI_fragment_shader not available
|Extension GL_ATI_pn_triangles not available
|Extension GL_ATI_map_object_buffer not available
|Extension GL_NV_texgen_reflection not available
|Extension GL_NV_fence not available
|Extension GL_NV_blend_square not available
|Extension GL_NV_register_combiners not available
|Extension GL_NV_register_combiners2 not available
|Extension GL_NV_texture_env_combine4 not available
|Extension GL_NV_texture_shader not available
|Extension GL_NV_vertex_program not available
|Extension GL_NV_vertex_program1_1 not available
|Extension GL_NV_occlusion_query not available
|Found Extension GL_EXT_paletted_texture
|Extension GL_ATI_separate_stencil not available
|Extension GL_EXT_texture_rectangle not available
|Extension GL_ARB_depth_texture not available
|Extension GL_ARB_shadow not available
|Extension GL_SGIS_generate_mipmap not available
|Extension GL_ARB_vertex_buffer_object not available
?ERROR: The Vision engine requires support for the ARB_multitexture extension!
Please make sure you have the latest video drivers installed for your 3D card.
|Extension GL_ARB_shader_objects not available
|Vertex Buffer Object extension not found - disabling fast geometry memory!
!WARNING: global listener object is still registered! Unregister listener before destroying object!
מה אני אמור לעשות?
להתקין את הדריברים של הכרטיס מסך שלך.
איזה מן עצה זאת?
בכל אופן יעזור אם תתן מפרט כדי לראות את החומרה שלך
העצה הנכונה, רואים בחלון שהוא משתמש בדריברים הגנרים של מיקרוסופט במקום בדריברים של הכרטיס מסך שלו.
בסדר אז יכול להיות גם שזה קורה מבעיה חומרתית
התקנתי את הדרייברים לפחות 5 פעמים כבר. :nixweiss:
שמתי לב באמת שזה משתמש בדרייברים הגנריים של מיקרוסופט, וזו ככל הנראה הבעיה, אבל איך בדיוק אני אמור לתקן אותה?
נ.ב: משתמש ב- 8800GT
איזה גירסא של דריברים אתה משתמש ?
175.19_geforce_winxp_32bit_english_whql
מה השגיאה שאתה מקבל ב SL ?
Second life is unable to run because your video card drivers did not install properly, are out of date, or are for unsupported hardware. Please make sure you have the latest video card drivers and even if you do have the latest, try reinstalling them.
If you continue to receive this message, contact customer service.
או במילים אחרות... שוב הכל נופל על הדרייברים, שכבר התקנתי מאות פעמים. :s07:
אתה בטוח שהתקנת אותם ולא פשוט חילצת אותם מהארכיב?
ניסית להסיר את הדריברים ע"י תוכנת ניקוי ? בדקת גירסאות אחרות של הדריברים ?
תוכנת ניקוי?
