מפרט מחשב של YARDEN PC ב- 3680 ש"ח. שווה? או שעדיף מפרט עצמי ב-6006 ש"ח?
אוקיי. עכשיו תעזרו לי בבקשה לבחור מארז...
Midi Tower ATX Case For Pentium IV 300 Watt 149.8 ¤
Baby ATX Case Workstations Pentium 4 250W 189.36 ¤
Super Midi Tower Case USB Front ATX 300 Watt 206.13 ¤
Magnetix Super Midi Tower 300W USB Front Case w/Transparent X-Window 231.77 ¤
Book Size CS2005 USB / Audio Front Case 295.38 ¤
Full Tower Case 701A P4 ATX 350 Watt 345.59 ¤
Super ALUMINIUM A01 Midi Tower Case Front USB/Firewire/Audio 400 Watt 468.44 ¤
Chieftec Midi Tower ATX Case For Pentium IV 300 Watt 149.8 ¤
Compucase-HEC
Compucase-HEC Mini Tower CI-6825 Front USB 300W Case 236.3 ¤
Compucase-HEC Midi Tower CI-6A19 Front USB 300W Case 303.55 ¤
Compucase-HEC Midi Tower CI-6A19 BLACK Front USB 300W Case 321.17 ¤
Compucase-HEC Super Midi Tower CI-6919 Front USB 300W Case 383.99 ¤
Compucase-HEC Super Midi Tower CI-6919 BLACK Front USB 300W Case 405.09 ¤
Compucase-HEC Super Midi Tower CI-6920 Front USB 300W Case 435.68 ¤
Compucase-HEC Full Tower CI-9109 Case 443.07 ¤
Genius
Genius Venus Professional Case Set ( Case+Keyboard+Mouse+Speakers ) 348.12 ¤
Simbadda
Simbadda 206-1 USB Front 350W Case 164.57 ¤
Simbadda Mask 2 Blue 400W Case 174.06 ¤
Simbadda Mask 2 Grey 400W Case 174.06 ¤
Simbadda Mask 2 Silver 400W Case 189.89 ¤
Simbadda 201H Grey USB Front 400W Case 189.89 ¤
Simbadda C850 USB Front 400W Case 246.85 ¤
Simbadda C650L-SG 400W USB Front Case 250.54 ¤
Simbadda C750L-B 400W Case 265.84 ¤
Simbadda Master I LU Midi Tower Case Silver 480 Watt 281.03 ¤
Simbadda Master I LU Midi Tower Case Black 480 Watt 281.03 ¤
TASK
TASK Golf 202 P4 300W Case 142.41 ¤
TASK 5200B Front USB 300W Case 183.56 ¤
TASK KL1-203C Front USB 350W Case 194.95 ¤
TASK 3003 Color 300W Case 205.71 ¤
TASK A-2310 Screwless USB Front 350W Case 212.57 ¤
TASK 3005 Screwless USB Front 300W Case 219.42 ¤
TASK 3001 Screwless USB Front 300W Case 226.81 ¤
TASK E-Star Silver 350W Case 227.86 ¤
TASK 6200 350W Case 240.52 ¤
TASK 6688 350W Case 247.91 ¤
TASK 9988L Screwless Front USB 350W Case w/Transparent X-Window 255.19 ¤
TASK 7799 P4 350W Case 274.28 ¤
TASK 7799 P4 Front USB 350W Case 282.19 ¤
TASK 700L P4 350W Case 356.46 ¤
Tsunami
Tsunami Virgo Blue 350W P4 Case 217.84 ¤
  • תגובות 107
  • צפיות 13.2k
300W ???????
אתם בטוחים שזה מספיק למפרט שלי ?
לא כדאי יותר? 350 או 400 ?
ועוד שאלה אחרונה ....
מאיזה חברה כדאי לקנות את הזיכרונות?
מישהו פה כתב שסמסונג זה לא טוב אז מה כן ?
אני מתכוון לקנות שני צ'יפים של 256K 400MHZ.
WINBOND זה טוב?
חשבתי על קינגסטון אבל זה די יקר. זה שווה את המחיר?
ומה לגבי CORSAIR? הם גם יקרים...
TWINMOS? MUSHKIN?
מה איתם ?
תודה על העזרה
כדאי לך ללכת על TWINMOS
בדיוק, TwinMOS. וכן, ה300Watt יספיקו לך בהחלט.
בשעה טובה החלטתי על המפרט הסופי אלא אם כן יש לכם עדיין הערות...
CPU : Intel Pentium IV 2.4C GHz HT 512K 800MHz Socket 478 CPU BOX [ ¤ 1166.74 ] 1
Motherboards for Intel : Asus P4P800 Intel 865PE Motherboard (HT, FSB800, Dual DDR, S-ATA, 5.1 Sound, 3Com G-LAN, USB 2.0) [ ¤ 726.63 ] 1
Memory : Twinmos DDR-RAM 256MB 3200 Memory [ ¤ 316.48 ] 2
Hard Discs : Western Digital 80GB 7200 rpm 8MB Buffer ATA100 HDD [ ¤ 594.92 ] 1
Video Cards : ATI Radeon 9500 PRO 128MB DVI OEM Video Card [ ¤ 1147.38 ] 1
Floppy : Teac / Alps / Mitsumi 1.44MB 3,5" Floppy Drive [ ¤ 52.22 ] 1
CD-RW / DVD-RW : Lite-On 52/24/52 Retail CD-RW [ ¤ 333.78 ] 1
Monitors : 17" CTX PR705F Flat Trinitron Monitor [ ¤ 1083.51 ] 1
Keyboards : Microsoft Multimedia Keyboard + Optical Mouse KIT [ ¤ 157.61 ] 1
Speakers : Creative Inspire 2400 2.1 Speakers [ ¤ 329.98 ] 1
Cases : Compucase-HEC Midi Tower CI-6A19 Front USB 300W Case [ ¤ 303.55 ] 1
Service : Computer Assembly [ ¤ 152.96 ] 1
Total Price ¤ 6682.24
מפרט מצוין תתחדש!
אחד מהרכיבים הבאים חייב להיות מוחלף באחר. הזיכרון והמארז. אם אין OC, זיכרון ג'נרי עם צ'יפים של Winbond עדיף. אם ישנו OC, המארז לא מקורר מספיק.
לא הבנתי.
לאיזה זיכרון להחליף ולאיזה מארז ?
נייק הזכרונות של טווינמוס עולים 2 ש"ח יותר(לפחות ככה זה בפיסי הארדוור) לכן הוא יכול לקנות אותם בלי שום קשר
גם ביצועים עדיפים וגם אמינות.
עכשיו בלבלתם אותי לגמרי !!!!
איזה זיכרון לבחור ??
ואיזה ספק כח ? איזה מארז ?
אתם בטוחים ש 300 וואט יחזיקו את המערכת ?
טווינמוס עולים 70 ש"ח יותר לצ'יפ. שווה?
זה המפרט:
CPU : Intel Pentium IV 2.6C GHz HT 512K 800MHz Socket 478 CPU BOX [ ¤ 1441.44 ] 1
Total Price ¤ 6956.94
שימו לב: שני צ'יפים של טווינמוס !!!
ועם לא מתוכנן OC האם אפשר להשאיר את הזיכרון והמארז?
לא הבנתי הבנתי מה אמרת כל כך................................
הבעיה שלכם היא שאתם פשוט מקבלים מידע ולא מבינים אותו. לא הבנתם מה אמרתי משום שלא הבנתם את ההשלכות ואת הכוונות שלי.
"אם אין OC, זיכרון ג'נרי עם צ'יפים של Winbond עדיף." - כלומר, את המארז יש להשאיר, משום שלא דרוש קירור רציני כ"כ.
"אם ישנו OC, המארז לא מקורר מספיק." - כלומר, את הזיכרון יש להשאיר, משום שתוספת המחיר שהוא דורש שווה את הזיכרון.
