כרטיס מסך מקסימלי על המחשב שלי
Hello, i want to know what is the highest GPU Card that i can put in my comp without getting bottle neck?
(after adding 1 giga more of DDR memory)
Without considering about bottle neck, the 9800GT will make better performance than the 8800 GT for example?
thx
I DONT REMEMBER BUT I THINK THAT THERE IS A RULE THAT YOU CAN WRITE HERE ONLY IN HEBREW... NOW THE ANSWER TO YOUR QUESTION YOUR CPU WILL BE A HUGE BOTTLENECK FOR THE 9800 GT I THINK THE OPTIMAL CHOISE FOR YOU IS THE 9600GT IN OVERCLOCKED VERSION
About the English, im sory for that but im stuck without Hebrew language on my computer for a while...
thx for your answer, but i think to buy for now the 9800GT and in 2-3 months upgrade my computer to even SLI system cus i will have 9800GT...
what u think about that?
(i can read in hebrew...)
i think the 9800GT XXt will be a good choice for you....its a good price to performance ratio card :xyxthumbs:
אבל יש לבחור פנטיום 4 מה הוא לא יחנוק את ה9800 GT המסכן???
יחנוק.....
אתה יודע מה....
אני חושב 9600GTXT יהיה מעולה בשבילו..
tamid efshar lihtov kacha...
AFAL LO TAMID EFSHAR LEHAVIN MA KOTVIM KACHA ;D
:lol: :lol: :lol: :lol:
tov... lanose!
מסכימים ש9600GT XT יהיה טוב?
