שאלה| בקשר לראוטר EDIMAX אלחוטי
שלום, יש לי ראוטר EDIMAX BR6204WG אלחוטי...
אובכן, ראיתי בתפריט איפה הWAN, איפה שבוחרים את התקשורת עם האינטרנט יש לי אפשרויות כאלו:
WAN TYPE
You can setup different modes to LAN and WLAN interface for NAT and bridging function.
Ethernet:
In this mode, the device is supposed to connect to internet via ADSL/Cable Modem. The NAT is enabled and PCs in LAN ports share the same IP to ISP through WAN port. The connection type can be setup in WAN page by using PPPOE, DHCP client, PPTP client or static IP.
Wireless ISP (AP Enabled):
In this mode, all ethernet ports are bridged together and the wireless client will connect to ISP access point. The NAT is enabled and PCs in ethernet ports share the same IP to ISP through wireless LAN. The connection type can be setup in WAN page by using PPPOE, DHCP client, PPTP client or static IP.
Wireless ISP (AP Disables):
In this mode, all ethernet ports are bridged together and the wireless client will connect to ISP access point. The NAT is enabled and PCs in ethernet ports share the same IP to ISP through wireless LAN. You must set the wireless to client mode first and connect to the ISP AP in Site-Survey page. The connection type can be setup in WAN page by using PPPOE, DHCP client, PPTP client or static IP
אז רציתי לשאול מה זו האפשרות האחרונה והלפני אחרונה...?
תודה ענקית מראש... :]
