EP43-DS3L s775 C2Q 1333Mhz, Intel P43, DDRII 1066, PCI-E חוות דעת?
MODEL GA-EP43-DS3L (rev. 1.0)
CPU 1. Support for an Intel® Core 2 Extreme processor/ Intel® Core 2 Quad processor/Intel® Core 2 Duo processor/ Intel® Pentium® Dual-Core processor/Intel® Celeron® processor in the LGA 775 package
(Note) This motherboard is designed with VRD11.1 power phase, and cannot be compatible with VRD10 designed CPU. Please refer to ''CPU Support List'' for details.
2. L2 cache varies with CPU
Front Side Bus 1. 1600(O.C.)/1333/1066/800 MHz FSB
Chipset 1. North Bridge: Intel® P43 Express Chipset
2. South Bridge: Intel® ICH10
Memory 1. 4 x 1.8V DDR2 DIMM sockets supporting up to 8 GB of system memory
2. Dual channel memory architecture
3. Support for DDR2 1200(O.C.)/1066/800/667 MHz memory modules (Go to GIGABYTE's website for the latest memory support list.)
Audio 1. Realtek ALC888 codec
2. High Definition Audio
3. 2/4/5.1/7.1-channel
4. Support for S/PDIF In/Out
5. Support for CD In
LAN 1. Realtek 8111C chip (10/100/1000 Mbit)
Expansion Slots 1. 1 x PCI Express x16 slot
(The PCI Express x16 slot conforms to PCI Express 2.0 standard.)
2. 4 x PCI Express x1 slots
3. 2 x PCI slots
Storage Interface South Bridge:1. 6 x SATA 3Gb/s connectors supporting up to 6 SATA 3Gb/s devices
JMicron 368 chip:1. 1 x IDE connector supporting ATA-133/100/66/33 and up to 2 IDE devices
iTE IT8718 chip:1. 1 x floppy disk drive connector supporting up to 1 floppy disk drive
USB 1. Integrated in the South Bridge
2. Up to 12 USB 2.0/1.1 ports (8 on the back panel, 4 via the USB brackets connected to the internal USB headers)
Internal I/O Connectors 1. 1 x 24-pin ATX main power connector
2. 1 x 4-pin ATX 12V power connector
3. 1 x floppy disk drive connector
4. 1 x IDE connector
5. 6 x SATA 3Gb/s connectors
6. 1 x CPU fan header
7. 2 x system fan headers
8. 1 x power fan header
9. 1 x front panel header
10. 1 x front panel audio header
11. 1 x CD In connector
12. 1 x S/PDIF In header
13. 1 x S/PDIF Out header
14. 2 x USB 2.0/1.1 headers
15. 1 x parallel port header
16. 1 x serial port header
17. 1 x power LED header
18. 1 x chassis intrusion header
Back Panel Connectors 1. 1 x PS/2 keyboard port
2. 1 x PS/2 mouse port
3. 1 x coaxial S/PDIF Out connector
4. 1 x optical S/PDIF Out connector
5. 8 x USB 2.0/1.1 ports
6. 1 x RJ-45 ports
7. 6 x audio jacks (Center/Subwoofer Speaker Out/Rear Speaker Out/Side Speaker Out/Line In/Line Out/Microphone)
I/O Controller 1. iTE IT8718 chip
H/W Monitoring 1. System voltage detection
2. CPU/System temperature detection
3. CPU/System/Power fan speed detection
4. CPU overheating warning
5. CPU/System/Power fan fail warning
6. CPU/System fan speed control
BIOS 1. 2 x 8 Mbit flash
2. Use of licensed AWARD BIOS
3. Support for DualBIOS
4. PnP 1.0a, DMI 2.0, SM BIOS 2.4, ACPI 1.0b
Unique Features 1. Support for @BIOS
2. Support for Q-Flash
3. Support for Virtual Dual BIOS
4. Support for Download Center
5. Support for Xpress Install
6. Support for Xpress Recovery2
7. Support for EasyTune
8. Support for Dynamic Energy Saver Advanced
9. Support for Time Repair
10. Support for Q-Share
Bundle Software 1. Norton Internet Security (OEM version)
Operating System 1. Support for Microsoft® Windows® Vista/XP
Form Factor1. ATX Form Factor; 30.5cm x 21.0cm
http://tw.giga-byte.com/Products/Motherboard/Products_Overview.aspx?ProductID=2847
מחיר 508 ש"ח.
מפרט מחשב:
intel Q9300
2X2gb ram 800mhz
9800GTX+ 512MB PCI-E
500Watt
go for it :xyxthumbs:
במחיר הזה יש את ה P43 NEO F3 של MSן שתומך ב RAID ובעל קרור טוב יותר ובעל פוטנציאל OC גדול יותר מהתקציבי הזה של גיגהבייט
גם אני שקלתי לקחת אותו למחשב שאני קונה בשבועות הקרובים, אבל אז הופיע בקייאספי ‏P45 Neo-F s775 C2Q 1333Mhz, Intel P45, DDR2 1066, PCI-E‎ של MSIב- 420 ש"ח...
מה ההבדל ביניהם אם אפשר לשאול?
אם אני לא טועה הם כמעט זהים. לערכת השבבים P45 יש יתרון על P43 בדמות איזשהי תמיכה ב- CF, נדמה לי X16 במקום X8. לא זוכר בדיוק, כי זה אף פעם לא עניין אותי. מהסיבה הזו, הסתכלתי על לוחות P43 הזולים יותר, אבל אם יש לוח P45 זול ב- 80-100 שקלים מ- P43 אחרים, אז למה לא? מהבחינה של כרטיס הקול, כרטיס הרשת, חיבורי סאטא, יואסבי וכדומה - דומה עד זהה. זו הסיבה שאקנה את הזול מביניהם.
NEO-F לא לוחות מומלצים במיוחד, לא משנה כל כך המחיר שלהם.
NEO2-F ו NEO3-F טובים.
P43 לא תומך CF ה P45 תומך ב CF אבל מוגבל ל X8 בכל חריץ X38/48 תומכים CF מלא.
