MS לא תחייב בעלי XBOX360 לעבור לdashboard החדש
דובי אתה יכול לנשום לרווחה -
MS: If you don't like the new 360 dash, then don't use it
As part of his latest podcast, Major Nelson has reminded us all that if we don't like the new Xbox 360 dashboard then we simply don't have to use it. He noted that all the functions in the current Xbox 360 dash will be included in the brand new dashboard of which you can completely bypass the pleasure of using should you wish. His comments come as he anticipated that people simply don't like change sometimes, listen to the podcast in full at Majornelson.com.
http://www.maxconsole.net/?mode=news&newsid=29741
נחמד אבל אני אישית קודם ינסה אותו ואחרי זה יחליט
לא חושב שצריך לשפוט משהו לפני שהשתמשת\אכלת\***** אותו
