פורסם 2008 באפריל 3018 שנים תראו מה מצאתי בתיקייה שכוחת אל אחת שיש לי על המחשב #ifndef _Console_H_#define _Console_H_//////////////////////////////////////////////////////////////////// // A simple win32 Console wrapper class that facilitates // clearing the screen, going to a specific screen position// and seting screen colors.// Future updates: // - create/destroy a new console window// - clear a specific rectangle with a character/attribute// (good for making text windows)// - whatever else I think of //// Author: _Dimi // Oct 20 2000 - Createdclass Console{public: // Wrap a given console (hCout be the output handle) or // get the handle to the current Console(HANDLE hCout = NULL) { if (hCout == NULL) { hCout = GetStdHandle(STD_OUTPUT_HANDLE); } m_hCout = hCout; } // Goto a screen position defined by (row, col) void GoTo(UINT row, UINT col) { if (m_hCout != NULL) { COORD c; c.X = col; c.Y = row; SetConsoleCursorPosition(m_hCout, c); } } // Set the text color. Range is 0(black) .. 14(bright white) void SetTextColor(UINT c) { if (m_hCout != NULL) { WORD attr = 0; switch(c) { case 1: attr = FOREGROUND_RED; break; case 2: attr = FOREGROUND_GREEN; break; case 3: attr = FOREGROUND_BLUE; break; case 4: attr = FOREGROUND_RED | FOREGROUND_GREEN; break; case 5: attr = FOREGROUND_RED | FOREGROUND_BLUE; break; case 6: attr = FOREGROUND_GREEN | FOREGROUND_BLUE; break; case 7: attr = FOREGROUND_RED | FOREGROUND_GREEN | FOREGROUND_BLUE; break; case 8: attr = FOREGROUND_RED | FOREGROUND_INTENSITY; break; case 9: attr = FOREGROUND_GREEN | FOREGROUND_INTENSITY; break; case 10: attr = FOREGROUND_BLUE | FOREGROUND_INTENSITY; break; case 11: attr = FOREGROUND_RED | FOREGROUND_GREEN | FOREGROUND_INTENSITY; break; case 12: attr = FOREGROUND_RED | FOREGROUND_BLUE | FOREGROUND_INTENSITY; break; case 13: attr = FOREGROUND_GREEN | FOREGROUND_BLUE | FOREGROUND_INTENSITY; break; case 14: attr = FOREGROUND_RED | FOREGROUND_GREEN | FOREGROUND_BLUE | FOREGROUND_INTENSITY; break; } m_ForeGround = attr; SetConsoleTextAttribute(m_hCout, m_ForeGround | m_BackGround); } } // Set the background color. Range is 0(black) .. 14(bright white) void SetBkColor(UINT c) { if (m_hCout != NULL) { WORD attr = 0; switch(c) { case 1: attr = BACKGROUND_RED; break; case 2: attr = BACKGROUND_GREEN; break; case 3: attr = BACKGROUND_BLUE; break; case 4: attr = BACKGROUND_RED | BACKGROUND_GREEN; break; case 5: attr = BACKGROUND_RED | BACKGROUND_BLUE; break; case 6: attr = BACKGROUND_GREEN | BACKGROUND_BLUE; break; case 7: attr = BACKGROUND_RED | BACKGROUND_GREEN | BACKGROUND_BLUE; break; case 8: attr = BACKGROUND_RED | BACKGROUND_INTENSITY; break; case 9: attr = BACKGROUND_GREEN | BACKGROUND_INTENSITY; break; case 10: attr = BACKGROUND_BLUE | BACKGROUND_INTENSITY; break; case 11: attr = BACKGROUND_RED | BACKGROUND_GREEN | BACKGROUND_INTENSITY; break; case 12: attr = BACKGROUND_RED | BACKGROUND_BLUE | BACKGROUND_INTENSITY; break; case 13: attr = BACKGROUND_GREEN | BACKGROUND_BLUE | BACKGROUND_INTENSITY; break; case 14: attr = BACKGROUND_RED | BACKGROUND_GREEN | BACKGROUND_BLUE | BACKGROUND_INTENSITY; break; } m_BackGround = attr; SetConsoleTextAttribute(m_hCout, m_ForeGround | m_BackGround); } } // Clear the screen using the currently set attributes and // the given fill character (default = space). void Clear(TCHAR ch = ' ') { if (m_hCout != NULL) { COORD c = {0,0}; DWORD len; FillConsoleOutputAttribute(m_hCout, m_ForeGround | m_BackGround, 100000, c, &len); FillConsoleOutputCharacter(m_hCout, ch, len, c, &len); } }private: HANDLE m_hCout; // the console handle WORD m_ForeGround; // the current foreground attribute WORD m_BackGround; // the current background attribute};#endif
