פורסם 2008 במרץ 1518 שנים Hey there,i have asus p5k deluxe and i want to know on what stat should i put my hard drives so it will work in raid but with Ahci and all the features they support.(if possible)p.thanks for your help
פורסם 2008 במרץ 1618 שנים You shouldn't have to do anything special in terms of physical modifications only configure your BIOS to use AHCI (native mode) and turn on the RAID function in the same place. For further information just check your motherboard manual
