פורסם 2008 בפברואר 1718 שנים I'm in Romania right now living as a guest in a friend's home and I want to fix his computer,, reinstall windows firsthis cdrom is not working, there is a "!" sign in the device manager and when i try to boot from windows cd it doesnt recognize a cd is in.in the device manager it says "This device cannot start. (Code 10)"can I fix the cdrom some how ?can i install windows from somewhere else? (i have the windows iso and i have mp3 player 1 giga and there is another computer here, a new laptop(thank u, it is most urgent because I return to Israel in 3 days
פורסם 2008 בפברואר 1718 שנים best way is to try to temporary get a usb cdrom and use itif notgood luck withhttp://www.vandomburg.net/installing-windows-xp-from-usb/
פורסם 2008 בפברואר 1718 שנים מחבר WOWsuper complicated though it seems to be the answer I cannot do such experiments on a computer that's not mineI might fuck up his computer that now works relatively finewhat can I do ?the man is prepared to buy a new cdrom should I tell him to do it? because the problem could be in another place and a new cdrom won't work either
