ATI HD3870 owners -- post your results here!
I am specifically targeting owners of a single HD3870, preferably overclocked. If you are running crossfire, please either disable crossfire for the testing or post your results with and without crossfire enabled.
Please post a screenshot of your 3DMark06 score with the latest version of GPU-Z open and visible in the screenshot. Get the latest version of GPU-Z here:
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
Please make sure you are running the latest drivers, which as of this post, are the 7.11 "hotfix" drivers. These may be obtained here:
http://support.ati.com/ics/support/d...estionID=30533
Please note that even though it is called a "hotfix" by ATI, it is actually the full beta of catalyst 7.11, so please uninstall your current version of catalyst, and then remove the remaining traces of it using the free tool Guru3D Driver Sweeper:
http://www.guru3d.com/index.php?page=driversweeper
Please also post your system specs in this format (obviously use your own specs):
Motherboard: abit IP35-E
CPU: Core 2 Duo E6750 @ 3.4GHz
RAM: 2x1GB DDR2 @ 1020MHz 5-5-5-15-2T
Video Card: 2900Pro 512-bit 1GB GDDR4 @ 820/2070
Sound Card: ESI Juli@
Power Supply: Corsair CMPSU-520HX
p.s. Please let this be confined to the HD3870, not other cards
example:
http://img.photobucket.com/albums/v169/antho_ie/overclock/untitled3.jpg
