פורסם 2003 במרץ 1723 שנים גרסה 1.2 של התוכנה הפופולרית זמינה להורדה, לחצו כאןונעבור לעידכונים:We are proud to announce that Spybot-S&D 1.2 is ready for the public! Over the past two month, we've been working hard to add some nice new features as well as to make the whole thing easier for newbies. Here's a short list of the most important changes:Introduced Easy mode for newbies, Advanced mode for pros Improved detections to avoid false positives (MD5 checksums) Improved detection mechanisms for morphing files (dynamic checksums) Added new Immunize section as a preventive measure against spyware Improved help (including description of each page, quick help & help buttons on each page) Added silent mode command line parameters Fixed some problems appearing as Zugriffsverletzung Improved readability for blind users Improved and printable logs Fixed bug that prevented all user accounts to be scanned Improved support for running on non-admin account Added support for external file viewersThis update is available using the usual ways. You can use the integrated updater, where you will see a new Main application update, and a new Includes update after you've downloaded that one. Or you could use the manual update, using the links at the bottom of this mail. Finally, the main download has also been updated, but is not yet available on all mirrors.I'm sure you'll want to know the changes in what is detected, too:Updates on March, 16th, 2003:Hijacker: + BDHelper+ FreeScratchAndWin+ IGnetNet+ ILookup+ MafiaPics + MediaLoads + QcBar + RapidBlaster + SearchEx + XupiterDialer:++ Bestdialer (1) ++ Comsoft (2) ++ Dialer_XX (7) ++ Direct Dialer (1) ++ erodata (1) ++ erdial (1) ++ I-Dialer (1) ++ Gekolabs (1) ++ Hi Speed Internet SEX Connection (4) ++ RSE 721 (17) ++ SexTV (1) ++ SMSDialer (2) ++ TC Dialer (1) ++ Unknown (13) ++ WimCom (3) ++ XRV Dialer (3) + Aconti (1) + AIS Dialer (1) + Area (1) + All-in-One Telcom (1) + CarpeDiem Vars (3) + Central24 (2) + EOPS (2) + eGroup (2) + Fairdialer (1) + Hacker (1) + Huysuzseks (1) + IBS (7) + Idialer (1) + Interfun (1) + InterSysInc (67) + Italian Frameless (1) + PrivateNet (1) + Starlux (3) + Teenxxx (1) + MainPean (12) + Webdialer (5) + XXXDialer (1)Malware: + FriendGreetings + Haczyk
פורסם 2003 במרץ 1723 שנים מחבר אכן תוכנה להסרת SpyWare, אני חושב שהיא כרגע התוכנה הכי טובה... (יותר מ-AD AWARE)ולגבי האנשים שאומרים שזה דפק להם את המחשב וניתק להם את האינטרנט וכל זה... אין לי מושג! אני משתמש בה כבר המון זמן ואין לי שום בעיות, התוכנה עושה את עבודתה על הצד הטוב ביותר!
