Halo 3: Finish the Fight, more like Finish the Console
http://www.maxconsole.net/?mode=news&newsid=21238
Halo 3: Finish the Fight, more like Finish the Console - mass Disc errors/RRoD's reported
Masses of gamers have confirmed on the Xbox and Bungie forums that their copies of Halo 3 are experiencing disc read errors (over 100 posts at the current time of writing). However, but that is not all, beyond the disc error reports, there have been lockups and even the dreaded RRoD reported belived to be as a result of Halo 3. At the current time, most reports seem to be from the standard edition not the LE version with some speculating the discs contain corrupt data which damages the hard drive. The problems seem to happen randomly with some able to play the game fine for a few short hour(s) before problems begin while others are saying the problems are limited to just a few selective game modes.
אני באמת לא מבין איך הם יכולים לפשל כל כך הרבה ?
וחוץ מהבעיות האלו יש גם בעיות שמירה אם רוצים להעביר שמירה ל360 אחר
Bungie investigating Halo 3 game save bug
Bungie has confirmed that it is aware of an issue which prevents Halo 3 gamers transferring campaign progress onto another Xbox 360 regardless of whether they use a memory unit or take your hard drive. A message churns out stating that it is 'unsafe to respawn' which then takes gamers back to the menu screen. Bungie are now investingating the cause of the problem and are trying to come up with a solution.
quote:
Gamers who played Halo 3 on their console and decided to finish the fight in a friend's Xbox 360 got a nasty surprise. There is a bug that stops you from transfer campaign progress to another Xbox 360 console whether you use a memory unit or take your hard drive. You can load up any mission or insertion point youve previously completed but you wont be able to resume from your last saved spot. You simply get a Unsafe to Respawn message and then you're taken to the menu screen.
Bungie has announced it is aware of this issue and it is currently investigating the cause and solution to the problem.
Also, the developer announced that Bungie PRO subscriptions are currently offline due to a small issue that is also being investigated.
http://www.maxconsole.net/?mode=news&newsid=21237
כבר נימאס לי לדווח על דברים כאלו
צחקתי הליהם מספיק אבל יאלה שיסדרו תבעיות המטומטמות כבר
ולי נמאס לקרוא את העברית העילגת שלך ומלאת השגיאות.
ומעניין שלא נתת את הקישור הזה שאומר: Wii is a joke, most games are complete garbage
http://www.maxconsole.net/?mode=news&newsid=21227
לך תדוג דגים בזלדה......
הביקורת הזאת של-
Wii owner
לא אתר או מגזין או משהו בסגנון
אני יכול להביא לך המון סירטונים ביוטיוב של בעלי 360 מאוכזבים
אז זה מה שקובע?
מדברים פה על בעיות חומרה ותוכנה
בעיות שלא היו צריכות להיות כל כך נפוצות בטח אחרי כימאת שנתיים בשוק
תפסיקו עם המלחמות עם קרירין
אתם כאלה חסרי חיים
חלאס כל אחד מה שהוא אוהב!!!! >:( >:(
מספיק לריב חבר'ה, זה בסה"כ העדפה אישית ומי שאוהב משהו מסויים לא חייב לאהוב משהו אחר ואין צורך להעליב אחד את השני.
