best mobo for Core 2 E6600 overclocking
what is the best mobo for the continuous hardcore overclocking of the Core 2 E6600 ?
key parameters:
maximum tested supported FSB frequency
maximum cpu/VDDR/chipset voltages
current Mobos being considered: Gigabyte GA-965P-S3 / Abit IP35-E
GA-965P-S3 maximum supported FSB: 500 Mhz (*9 = 4500 Mhz) according to
http://www.www.xbitlabs.com/articles/mainboards/display/ga-965p-s3_6.html#sect0
which appears to be good but according to
http://www.xbitlabs.com/articles/mainboards/display/abit-ip35-pro_9.html#sect0
it is not stable for continuous overclocking
Abit IP35-E maximum supported FSB: 488 Mhz (*9 = 4392 Mhz)
http://forums.anandtech.com/messageview.aspx?catid=29&threadid=2063989
currently considered RAM: Corsair 2GB Kit PC2-6400 DDR2-800 4-4-4-12 + EPP TWIN2X2048-6400C4
http://www.pcstats.com/ArtVNL.cfm?articleid=1960&page=2
seems to be able to reach 1000 mhz at this latency with proper voltage
קח לך DFI Lanparty P35 T2R על פי כל הביקורות הוא יעשה לך יותר
הוא מחזיק בשיא עולם של כמעט 667 MHZ בבאס.
אם כי יותר סביר להניח שתגיע איתו ל540-550MHZ בכלים שלך.
overkill, I don't want and don't need SLI support
ממתי ה-35P של אינטל תומך ב-SLI :s07:?
sorry I guess I didn't mean SLI I probably meant crossfire or dual X16 PCI-E slots, which usually makes the board more expensive significantly ... do you know where I can find in-depth reviews of this mobo which include bios options maximum supported FSB frequency and maximum core voltage ?
