משחקים זזים לאט יותר בVISTA וזה סופי!!
מה גם שדלפו לרשת 2 עדכונים שמתקנים בעיות שונות.
זה נקרא Vista Performance and Reliability Pack
זה מה שהם עושים:
938979 Vista Performance and Reliability Pack
This update resolves a number of individual issues which may be affecting some computers running Windows Vista. These issues have been reported by customers using the Error Reporting service, product support, or other means. Installing this update will improve the performance and responsiveness for some scenarios and improves reliability of Windows Vista in a variety of scenarios. Some examples of the improvements contained in this update are:
* Improves performance in resuming back to the desktop from the Photo and Windows Energy screensaver.
* Resolves an issue where some secured web pages using advanced security technologies may not get displayed in Internet Explorer on Windows Vista.
* Resolves an issue where a shared printer may not get installed if the printer is connected to a Windows XP or Windows Server 2003 system and User Access Control is disabled on the Vista client.
* Resolves an issue where creating AVI files on Vista may get corrupted.
* Improves the performance in calculating the estimated time remaining when copying/moving large files.
* Improves performance in bringing up Login Screen after resuming from Hibernate.
* Resolves an issue where synchronization of offline files to a server can get corrupted.
* Resolves a compatibility issue with RAW images created by Canon EOS 1D/1DS Digital SLR Camera which can lead to data loss. This only affects RAW images created by these two specific camera models.
* Resolves an issue where a computer can lose its default Gateway address when resuming from sleep mode.
* Improves the performance when copying or moving entire directories containing large amounts of data or files.
* Improves the performance of Vistas Memory Manager in specific customer scenarios and prevents some issues which may lead to memory corruption.
938194 Vista Compatibility and Reliability Pack
This update resolves a number of individual issues which may be affecting some computers running Windows Vista. These issues have been reported by customers using the Error Reporting service, product support, or other means. Installing this update will improve the reliability and hardware compatibility of Windows Vista in a variety of scenarios. Some examples of the improvements contained in this update are:
* Improved reliability and compatibility of Vista when used with newer graphics cards in several specific scenarios and configurations.
* Improved reliability when working with external displays on a laptop.
* Increased compatibility with many video drivers.
* Improved visual appearance of games with high intensity graphics.
* Improved quality of playback for HD-DVD and Blue-Ray disks on large monitors.
* Improved reliability for Internet Explorer when some third party toolbars are installed on Vista.
* Improved Vista reliability in networking configuration scenarios.
* Improved the reliability of Windows Calendar in Vista.
* Improved reliability of systems that were upgraded from XP to Vista.
* Increased compatibility with many printer drivers.
* Increased reliability and performance of Vista when entering sleep and resuming from sleep.
מה אתם מתקינים XP בdual boot? ויסטה יכול לעבוד טוב. סתם קטנוניות או מחשבים עתיקים.
אם אתה יודע לקרוא אז אני שמח, אבל לעזעזל למה להגיב בלי קשר???? יש אימרה מאוד מתוקה שאלוהים אומר אותה הרבה(אלוהים זה UNDERTAKER בשבילי): "REST IN PEACE", אולי אתה צריך לקחת את זה על 3 פניו.
  • תגובות 77
  • צפיות 6.7k
לידיעתך halo2 נפרץ כבר מזמן והוא עובד נהדר על xp.
השאלה שנשארה פתוחה :
האם ההאקרים יצליחו לבסוף לפרוץ את ה-dx10 ,כך שהוא יוכל לרוץ גם על xp ואז מבחינתי Microsoft ,יכולה מבחינתי לעשות רק דבר אחד עם vista :
Shove it up their ass hole
אני יודע שפרצו אותו לXP אבל אני מתכוון בדרך רגילה שמיקרוסופט לא שיחררה בכוונה מההתחלה את Halo2 לXP בשביל שאנשים
יקנו וויסטה... בגלל זה הדגשתי את העניין הזה, אבל מה נעשה בעתיד אם משחקים שמשוחררים רק לוויסטה?...
נקודה למחשבה. לא הכול ניתן לפרוץ...
לכן במוקדם או מאוחר, הרבה גיימרים יעברו לוויסטה גם בגלל DX10 וגם בגלל שהכול יתחיל לתמוך רק בוויסטה...
בקיצור, כמה שינסו לעשות עידכונים ופריצות שיותאם גם לXP, בשלב כולשהו כבר לא יגיעו לרמה של וויסטה, אי אפשר להתאים כול דבר...!
מתישהו יעברו לוויסטה וזהו. חוץ מאלה שלא גיימרים, שלא צריכים יותר מאינטרנט, אולי פוטושופ, משחקים קטנים, וזהו...
בעיקרון המון גיימרים בטח יעברו. ואז משתמשים רגילים בגלל היופי שבה ובגלל כמה תכונות..
הכל ניתן לפריצה. זה עניין של כדאיות והאם המאמץ שווה את זה...
זה ברור ש Vista עם ביצועים נחותים על XP. ככה גם XP היתה עם 2000, ו 2000 עם 98, 98 עם 95 וכו'.
אבל בסופו של דבר, כמו שעכשיו 2000 נחות על XP, כך Vista תהיה עליונה על XP...
מבחינתי מספיק משחק אחד שעובד רק על DX10 כדי להתקין Vista ב Dual Boot. למה לא?
ולכל אלה שמתבכיינים ש Vista צורכת משאבי מערכת מטורפים... אין אפשרות לבטל את ממשק ה Aero, ולעשות את הכל יותר מכוער לטובת ביצועים? היתה את האפשרות הזאת ב XP...
מישהו יכול להסביר עוד קצת על הVlite הזו? ובאזיו גירסא יש בעיות ובאיזו פתרו אותם?
בקשר לת'ראד, אנחנו לא יכולים לעצור את הקידמה, ואנחנו גם לא יכולים לשבת בצד בזמן הקידמה, אנחנו חייבים לזרום איתה.
ויסטה היא מערכת הפעלה מצוינת, התקנתי אותה אתמול והיא רצה מצוין, תוכנות דרייברים הכל בסדר, היא תופסת הרבה מקום בדיסק ובגלל זה אני שואל לגבי הוי לייט אבל חוץ מזה היא מצוינת. משחקים עובדים לאט יותר כי המערכת כבדה יותר, אם אין לך 1.5GB זכרון מינימום אתה לא יכול לצפות להפעיל משחק כבד בזמן שהויסטה רצה. שיחקתי GRAW2 בויסטה, על 1024X1280 כולל AAx4 וAFx16 והיו לי בין 70 ל80 FPS, בדיוק אותו דבר כמו בXP.
זה ממש לא נכון כי הפעם AERO משתמש בכוח הכרטיס מסך לעומת הלונה של XP.
לך ל Appearance Setttings ושם תוכל להשתמש בממשקים אחרים ולא ב Aero.
זה נכון יש לי ויסטה ואני מרגיש הבדלים ועוד המחשב שלי חדש
מה התכוונתה לומר הבדלים? מהיר יותר איטי יותר :nixweiss:
מי שלא יודע ברגע שמפעילים משחק אז הארו מתבטל אוטומטית וחוזר אוטומטית שאתם יוצאים מהמשחק
אתה יודע שהממשק הזה לוקח למעלה מחצי גיגה מהזיכרון כ570MB זה המון למי שיש מחשב עם גיגה זיכרון שלא נדבר על פחות יכול לשכוח מהמערכת הזו מספיק
שאתה מפעיל כמה תוכנות בו זמנית(שיתוף קבצים נגן MP3 וגולש בו זמנית) והמחשב מקרטע !!
זו מערכת כבדה שמתאימה למחשבים בינונים פלוס
מה כל כך המון שזיכרון הוא החלק הכי זול במחשב
אני רק צריך להגיד לך שעם הארו היתה צריכה של 980 מגה זיכרון וששמתי את הממשק הקלאסי (סטייל 95) צריכת הזיכרון ירדה ל950
לפי החשבון שלי זו צריכה של 30 מגה ולא 570
כרגע הויסטה היא מערכת הפעלה פשוט לא כדאית אלא אם כן יש לך מחשב חזק בצורה מטורפת ואתה רוצה להיות נסיין
הויסטה לא מציע כלום חוץ מיופי ואפשרויות חיפוש מתקדמות וכמובן באגים שעוד לא התגלו
עד שלא ייצא SP1 אני לא יחשוב בכלל להחליף
אתה בוחר להשמיט את DX10.
הדבר הכי חשוב!
עכשיו שיוצאים משחקים של DX10 נראה שדווקא שווה להתקין VISTA.
לא הבנתה מה שאני אמרתי וגם אין לי מושג מאיפה המספרים שזרקתה שברור שהם לא נכונים
הAERO צורך כ570MB זיכרון לא 980 MB כמו שאתה טוען מספר דמיוני לחלוטין
והדרך שאתה בדקתה היא לא דרך לבדיקת צריכת זיכרון
