מיקרוסופט עושה זאת שוב-לא כל משחק ירוץ על כל 360
זמן תה
בזמן האחרון יש כל מיני פרסומים כאלו-
I continue to be disappointed that folks on the internet treat any positive thing we say about one platform as some sort of critique of another platform. We're a multi-platform company folks please come to grips with that. We like the PC. We like the 360. We like the PS3. We like the Macintosh. We like Linux. We will deliver UT3 for all of these platforms and it will rock on every one.
The simple facts state that the optical disc on the PS3 holds more data than the optical disc on the 360. If we exceed size of the 360s optical disc then we'll have to find alternative ways to get the content to 360 users such as making it downloadable. Adding a second DVD to a game like UT3 would be a challenge because when playing online you might not know exactly what map you're going to be playing next and we have to be able to accommodate users of the core system. So does that mean the disc on the 360 might have a map or two less? Possibly although it is too early to tell for sure. People love Unreal Tournament because we always ship it with tons of great content but that also makes it a bit of a disc hog - in a good way
Obviously, and as is true with most major games on 360 and PS3, you're going to be putting your hard drive to good use if you want to experience the full richness of content that UT3 will have to offer over the lifetime of the game. the fact that you can do this is a good thing.
I don't know the exact numbers but I suspect the version of Gears of War that most of our customers play today on their 360s, when you combine the downloadable content with the content on the disc, is larger than what we could fit on the 360's optical disc alone. So clearly there are perfectly good strategies to cope with this situation. We're all very used to downloading extra content for console games and with UT3 there will be lots of it for all supported platforms. In fact the cool thing about our engine is that when you make content for one platform it can run on all of them. If history is any indication, the vast majority of UT3 content won't even come from Epic - it will come from some very brilliant end users with lots of cool and innovative ideas.
When it comes to user created mods on the 360 - we will work with Microsoft to find a way to support them. We just don't have all the answers today and it isn't our chief priority at this very moment because we already have our hands completely full shipping UT3 on PC and PS3 as well as shipping Gears of War on PC. When we get those out of the way, and get a little time to spend with our friends and families, then we'll get back on this issue and figure it out.
http://www.maxconsole.net/?mode=news&newsid=19796
ככה שמה שאתה אומר בקשר למקום לא נכון
ואתה יודע מה זה אומר שחלק מהמשחק יגיע בצורת הורדות?
זה אומר חובה ארד דיסק וחובה חיבור לLIVE ובהרבה מקרים חובה תשלום נוסף
וזה לא המשחק היחיד אם בעיה בשטח איכסון ב360
יש עוד דיווחים בסגנון
מה יקרה במחשב? -
מחשב לא צריך לא בלו רי ולא HD-DVD כי אפשר להתקין תמשחק על הארד דיסק ולכל PC
ביתי רגיל יש ארד דיסק
ככה שגם אם המשחק יגיע על 2 DVD או על 4 DVD אחרי ההתקנה תיצתרך רק DVD 1
בלי להחליף
ב360 אם תיהיה התקנה כזאת הקור עוד פעם יהיה חייב בשדרוג
  • תגובות 59
  • צפיות 5.7k
ולגבי משקלי המשחקים שהבאת, נחמד אבל... לא. המספרים שהבאת פה מלאים באיזורי ג'אנק שלא מכילים מידע (אחרת איך תסביר שאובליביון, דה דרקנס ונינג'ה גיידן יצאו גם לאקסבוקס, כשאיזכור של נינג'ה גיידן הוא בכלל מגוחך מכיוון שזה פורט מהאקסבוקס הראשון) המשחק הראשון שיעבור את 9GB של DL DVD יהיה הבנלי סורד שיהיה 10GB וגם זה רק כי דחפו את כל הזונים שבעולם על דיסק אחד (איזה מזל שעכשיו יש גם את הדיבוב הסיני, היפני, הקוראני, והצ'רקסי על הדיסק!)
כמה מספרים חביבים מגירסאות ה360:
ביושוק 6.5 גי'גה
בלו דרגון 6.6 ג'יגה
אובילביון 6.4 ג'יגה
מדאן 08 6.3 ג'יגה
וכמובן, איך אפשר בלי גירס אוף וור 6.3 ג'יגה
כפי שאתה רואה כרגע זה האיזור שבו משחקים נמצאים. יש להם עוד יותר מ2 ג'יגה פנויים על הכונן, ובכוונה לקחתי משחקים שאי אפשר לאמר עליהם שהתקמצנו בתוכן שלהם, כל אחד מכיל גרפיקה הכי עדכנית שאפשר ותוכן בכמויות.
למה אתה מביא לי את גודל הRAR של ההורדה שלהם באימיול? אחרי שאתה עושה להם EXTRACT הם הרבה יותר גדולים ::)
(אגב באמת עשיתי בדיקה והבאת את הגדלים האלה מאימיול חח)
והגדלים שאני הבאתי הם ממיני נובה , אבל נוק אאוט , תסכים שבXBOX הם לא יעברו את הטווח של DL.
liviur
לפי הכתבה שנתתי מאוד יכול להיות שהם כן יעברו בעזרת
הורדות
כי אנריל כניראה יגיע מלא על הPS3
ולא מלא על ה360 ויצתרכו להוריד תוכן נוסף לקבל את הכל- מה שיעבור
תמגבלת 9 גיגה של הDL
וצריך ארד דיסק וחיבור לרשת
נו כי XBOX לא יכול לקרוא מדיה גדולה מDL... השאלה היא האם בעתיד הם יחליטו להשתמש בנגן הHD DVD שנרכש בנפרד בשביל משחקים. את זה נדע רק כנראה בעוד כשנה-שנתיים.
אני מעריך שהם ישתמשו בארד דיסק במקום
ובעלי קור יהיו חיבים שדרוג ואולי גם בעלי פרימיום
או שבעלי פרימיום יצתרכו למחוק הרבה מידע כל כמה זמן שיהיה מקום למשחקים בעלי נפח גבוה
בדיוק מהסיבה הזאת אני חושב שעדיף להם כבר להנשתמש בHD DVD. זה יעשה הרבה פחות כאב ראש לצרכן וזה יעלה לו לא בהרבה יותר יקר מהארד דיסק. (אני לא יודע מחירים לXBOX360 ממש אז אולי אפילו זול יותר...תלוי איזה גודל ד.קשיח)
אם יעשו בHD-DVD יותר מ10 מיליון יצתרכו לשדרג
הבעיה שגם אם יעשו משחקים כבדים מבחינת שטח איכסון יותר מי 10 מיליון יצתרכו לשדרג
אז זהו שבגלל זה אני חושב שעדיף כבר HD DVD מכיוון שלא יהיה את הכאב ראש של "יש לי מספיק מקום למשחק הזה? אבל אם אין אני עדיין לא רוצה למחוק את המשחק הזה והזה... ובלה בלה בלה".
בכל מקרה הם בבעיה גדולה
לשדרג ארד דיסק באופן רישמי ל360 מאוד יקר אבל גם לשדרג לכונן HD-DVD
בסופו של דבר שסוני תצליח בסוף להוריד את מחיר הPS3 למחיר נורמלי
הוא יהיה יותר מישתלם בהרבה מה360
אלו הגדלים של הISO, הRAR רק שומר על שלמות המידע ומחלק את הISO הגדול לחתיכות נוחות להורדה, הוא כמעט ולא דוחס (פחות מ10 אחוז נדחס, אז לכל היותר תוסיף 500 מגה למספרים שרשמתי, עדיין יש מרווח מגבול המידע של DVD). ולא, לא הבאתי אותם מאימיול, יש לי את המקורות שלי.
liviur הגדלים שהבאת כוללים איזורי ג'אנק שכרגע נכללים מכיוון שלא ידוע אם ההגנה משתמשת בהם. גם האימג'ים הראשונים שהופצו של משחקי 360 היו 8.5GB מלא, למרות שבפועל הרבה מה"מידע" הזה מיותר (חלק ממשחקי ההשקה היו קטנים מ4.7GB אפילו, אבל בגלל שההגנה של האקסבוקס נמצאת על השיכבה השניה של DL DVD היה צריך לפריצות המוקדמות את "כל" 8.5GB של המידע.)
קרירין, אתה בכוח מחפש בעיות במקום שהם לא קימות. באמת נראה לך שמי שקונה גירס אוף וור או UT3 משתמש בגירסאת הקור? היא מהווה אחוז קטן מהליין של מס, ומיועדת בעיקר לאנשים שישחקו ויוה פנייטה ודומיו. עם הורדת המחיר שמורידה את הפער בין הגירסאות ל70 דולר עוד פחות אנשים יקנו אותה.
אבל לא, אתה חייב לציין את העובדה שמשחקי MMO מסוימים שיצטרכו אישור מקדים של MS לפני הפיתוח כדי לדרוש מקום איחסון (אף אחד לא דיבר על הארד דיסק, כרטיס זיכרון גם תקף וזה יש לכל מי שמשתמש ב360 למשחקים) כ"חיסרון ענק" ו"בעיה גדולה".
DVD עדיין מספק, ואם לא יש תמיד אפשר להוסיף עוד אחד.
האחוז הקטן שאתה מדבר עליו מוערך ב2 מיליון מכשירים
והקור עדיין מיוצר
וכמו שאמרתי לפרימיום גם בעיקרון עלולה להיות בעיה
כי אם תאכסן חצי משחק של משחק אם 20 גיגה בארד דיסק
2 משחקים מותקנים וכבר נגמר לך המקום
לסוני אין תבעיה הזאת בזכות הבלו רי
לנינטנדו אין תבעיה הזאת כי היא לא תומכת בHD בכלל והמשחקים הרבה יותר פשוטים מבחינה גרפית
אז לא צריך מקום ענק
אבל במשחקי 360 שחיבים לתמוך בHD כולל סירטוני מעבר HD זה בעיה
רוצה להפיץ משחק על כמה DVD סבבה מתאים לRPG יפני
אבל לא מתאים למולטיפליר\מרוצים\ספורט וכו
הנחנו התחלנו להגיע לשלב שמשחקים באמת מתחילים לנצל תחומרה של הPS3\360
וצריך בחלק מהמשחקים האלו המון שטח איכסון
וכן זה בעיתי ל360
וכמו בכותרת -
ודרך אגב כרטיס זכרון לא הספיק לפינל פנטזי
וקשה לי להאמין שיספיק להורדות תוכן לאנריל לדוגמה אם באמת לא יצליחו לדחוס את אנריל לDVD אחד
וגם ההורדות
הורדות=חובה חיבור לרשת
אתה לא רואה את זה כבעיה?
אתה חושב שלא יהיו אנשים שיקנו את הקור יותר?
אז אני מבין שכל הקונים מבינים גדולים בקונסולות?
זה כמו שתגיד שלא יקנו יותר את ה8800GTS-320
כי ה8800U יותר טוב
איזה טיעון אבסורדי. לא כל WII יריץ כל משחק- רק אלה שקנו את את הWII FIT אם האביזר שלו יוכלו לשחק בו! שערוריה! וגם הידעת? כדי לשחק בשני שחקנים צריך שלט נוסף שלא כלול במחיר הקונסולה! איך דוחקים ככה קהל שלם של אנשים.
נו באמת. כפי שהראתי למשחקים עדיים נשאר בערך 2 ג'יגה של מקום על ההארד דיסק. זה שווה ערך לשעת וידאו באיכות 720P. וטכנולוגיות הכיווץ והפרוסידורל סינטסיס (יצרת התוכן ע"י אלגורתימים- לדוגמא העצים באובליביון) מתקדמות בצעדי ענק. אם רובו בליץ- משחק שמבוסס על UE3 יכול להכנס ל50 מגה בלבד אני לא חושש. וגם במשחקי אונליין, אין שום בעיה. פצל את מרכיב הסינגל והמולטי לשני דיסקים. 8.5 GB רק למפות יהיה די והותר. התקנה על ההארד דיסק? לUT04 נוספו רק שני ג'יגה של מפות במשך כל תוחלת החיים שלו. גם אם מפות של UT3 יהיו כפולות בגודלן עדיין תשאר עם קרוב ל16 ג'יגה של מקום פנוי על ההארד דיסק לכל משחק שרק תחפוץ (אל תשכח שבמדינות הנורמליות, רוחב הפס מספיק גבוה בשביל להוריד את מפת המשחק בתוך שניות ספורות. גם אם תחליט למחוק חלק מהמפות הישנות יותר ופתאום הם יצוצו, לכל היותר תאלץ להמתין דקה שתיים נוספות לפני טעינת המשחק)
דיברת על תוכן בהורדות? יותר מחצי ממשתמשי ה360 ופס3 בכלל לא מודעים שהקונסלה שלהם יכולה לעשות את זה (ואני אנחש שרוב קבוצת הקור הם כאלה).
בסופו של דבר, הארד דיסק 20 GB ל 360 עולה כיום כ90 דולר (ואפשר למצוא גם ב70) מחיר סטנדרטי של אביזר שמעשיר את חוית המשחק מהקונסלה שלך. חוץ ממספר MMO בודדים (כמה כבר יצאו במהלך חייו של האקס בוקס? 5? 10?) כל משחק ירוץ בלי שום דרישה נוספת. אתה רוצה תוכן נוסף? תשלם. ככה העולם עובד.
אתה משווה באמת את אנריל טורנמנט 2004 לאנריל 3 ? :screwy: :screwy: :screwy:
אנחנו כמה שנים אחרי אנריל 2004 והדרישות בהתאם
אתה מדבר על כיווץ במדיה עצמה?
כן זה אפשרי אבל אם הקונסולה תיצתרך לפתוח את הקבצים בזמן אמת
חלק מהכח עיבוד יהלך למשימה הזאת או במילים אחרות תקבל פגיעה בביצועים\איכות גרפית פחותה
יופי אבל בעלי הPS3 יקבלו תמשחק המלא על הדיסק
בעלי ה360 שלא מורידים יקבלו משחק לא שלם
סוף סוף אתה נותן רעיון נחמד
הרעיון לא הכי נוח אבל זה עדיף על הפתרונות האחרים אם מיקרוסופט באמת תישתמש בו
מה שאתה אומר מעלה תמחיר האמיתי של ה360 משמעותית יחסית למחיר הקניה
זה אולי לא הרבה במחירים בחול אבל כידוע גם בארצות הברית אוהבים קונסולות בזול
ומינסטרים בחול זה 200$
חוץ מיזה-אתה בעצמך אמרתה שקוני הקור לא מבינים בקונסולות
מה יקרה שיצאו משחקים שדורשים ארד דיסק?
זה מבלבל ומרגיז צרכנים לא מבינים ועלול להרחיק אותם ממיקרוסופט בדור הבא
לא יצאו משחקים שדורשים הארד דיסק למעט MMO. שום דבר בנתיים לא הראה שום שינוי. זה שMS פשוט מיסדו את הקטע של MMO (שמלכתכילה היה ידוע שיכולים לדרוש הארד דיסק!) לא מעיד על שום זאנר אחר.
