פורסם 2003 בפברואר 1123 שנים שלום לתומכים ( ) כשאני מנסה לצרוב דיסק יש לי בעייה, ישר הוא מגיע בערך ל25 אחוז, בודק משהו בבאפר ובווווווווום Power Calibration Error 6:01:16 PM#10 Phase 24 File dlgbrnst.cpp, Line 1426 Caching of files started 6:01:16 PM#11 Phase 25 File dlgbrnst.cpp, Line 1426 Caching of files completed 6:01:16 PM#12 Phase 36 File dlgbrnst.cpp, Line 1426 Burn process started at 12x (1800 KB/s) 6:01:16 PM#13 Text 0 File ThreadedTransferInterface.cpp, Line 1844 Verifying CD position of item 0 (relocatable, CD pos, no patch infos, orig at #0): write at #0 6:01:16 PM#14 Text 0 File Mmc.cpp, Line 14392 Set BUFE: supported -> ON 6:01:31 PM#15 SCSI -1106 File Cdrdrv.cpp, Line 1325 SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x02730088 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x03 (KEY_MEDIUM_ERROR) Sense Code: 0x73 Sense Qual: 0x03 CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x1F 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x73 0x03 6:01:31 PM#16 mmc -1106 File Writer.cpp, Line 308 Power calibration error 6:01:31 PM#17 Text 0 File ThreadedTransfer.cpp, Line 219 all writers idle, stopping conversion 6:01:31 PM#18 CDR -201 File WriterStatus.cpp, Line 183 Invalid writestate 6:01:31 PM#19 TRANSFER -18 File WriterStatus.cpp, Line 183 Could not perform EndTrack 6:01:31 PM#20 SCSI -1026 File Cdrdrv.cpp, Line 1121 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x2C Sense Qual: 0x04 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x2C 0x04 6:01:31 PM#21 mmc -1026 File WriterStatus.cpp, Line 222 Current program area empty 6:01:31 PM#22 TRANSFER -19 File WriterStatus.cpp, Line 222 Could not perform Fixation 6:01:31 PM#23 Text 0 File WriterStatus.cpp, Line 231 falling back to disc fixation 6:01:31 PM#24 SCSI -1026 File Cdrdrv.cpp, Line 1121 SCSI Exec, HA 1, TA 0, LUN 0 Status: 0x04 (0x01, SCSI_ERR) HA-Status 0x00 (0x00, OK) TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND) Sense Key: 0x05 (KEY_ILLEGAL_REQUEST) Sense Code: 0x2C Sense Qual: 0x04 CDB Data: 0x5B 0x01 0x02 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0A 0x00 0x00 0x00 0x00 0x2C 0x04 6:01:31 PM#25 mmc -1026 File WriterStatus.cpp, Line 222 Current program area empty 6:01:31 PM#26 TRANSFER -19 File WriterStatus.cpp, Line 222 Could not perform Fixation 6:01:31 PM#27 Phase 38 File dlgbrnst.cpp, Line 1426 Burn process failed at 12x (1800 KB/s) 6:01:31 PM#28 Text 0 File Scsicmd.cpp, Line 371 SCSI not using temporary buffers 20 out of 20 temporary buffers allocated Existing drivers:
פורסם 2003 בפברואר 1123 שנים לדעתי אין מה לעשות בדרך כלל בעיות בPOWER הם בעיות חומרה, תיראה אם יש עדיין אחריות.1.) נסה את זה על ספק/מחשב אחר, יכול להיות שזה בעייה.מקס, קונים אחד חדש ב120 שקל X24
פורסם 2003 בפברואר 1223 שנים מחבר העברתי את זה למחשב של אבא שלי, ובמחשב שלו זה בכלל לא מזהה את הצורב! :'(
פורסם 2003 בפברואר 1223 שנים הביוס מוצא אותו?אם לא כנראה זו בעית ג'אמפריםאם הוא כן מוצא אותו והוא מופיע "במחשב שלי" אז כנראה שתוכנת הצריבה צריכה עדכון.
