CPU Cooler Recommendation (budget Under 400)
Hey
i have the system in my spec
i wanted to buy a cooler to hold on my CPU overclocked to 3.2 - 3.5GHz all the time, 24 7.
note that my case has lots of fans that can collide with the cooler. i need a cooler that is NOT higher than 13cm
Recommendation Please.
thank you
budget?
the budget isnt a concern, i want something that is able to hold the overclock very well wihout being noisy if possiable too
the real limit here is the 13cm high since, thermaltake big typhon, zalman CNPS9700 and Tuniq Tower are all higher than that and wont fit
anything that will fit and is as good as these?
how much would water cooling cost?
good WC = 1K+
AIR cooling (search google)
ANDY SAMURAI MASTER
Zalman CNPS7700-Cu
SAMURAI-Z Rev.B
and
TT BT SHOULD FIT
Thermaltale BigTyphone is 15CM high and wont fit
ANDY SAMURAI MASTER
this one looks really good
is it beter than ZSalman 9500AT wich is 12.5cm too????
so wich one do u recommend from between these too???
Enzotech Ultra-X
they dont ship this to israel?????
i cant find it anywhere
is there any risk on the motherboard since the cooler is heavey, way pass specification????
i dont wanna end up with a broken motherboard
ha!!!!!!!!!!!!!!! ???? this is wired, xbit labs lists ANDY as beter than CNPS9700 while the other site lists it as worse than the intel stock cooler!!!!!!!!!!!!!!! how is that possiable
http://www.madshrimps.be/?action=getarticle&number=11&artpage=2445&articID=556
Enzotech, as most of us know, israel is the worse place to get good hardware
on the weight issue, there is non. don't worry about it
how the hell did u read madsshrimps chart? in order to come to this conclusion
page 11 says this
intel stock = 62C
andy + NCB @ LOW = 63C
9700 LOW = 51C
andy + NCB @ HIGH = 53.5C
9700 HIGH = 47C
were did u get the idea that andy is worse then intel stock?
and one more thing. on the 11 page they use NCB fans and not stock fan for the andy
the 9700 used it's stock fan due to the fact u "can't" remove it
"intel stock = 62C
andy + NCB @ LOW = 63C"
what is the NCB fan? and the stock fan should make a great differenave?
DEAR LORD
do u have some thing in your head or is it empty? read the whole thing not just a part
NMB - a fan they use to compare different HSF under the same conditions
"intel stock = 62C
what u didn't read here is
intel stock = 66.8DBA
andy + NCB @ LOW = 39.7DBA
can u understand the different in the noise?
What can we conclude from the results?
- The Scythe Katana 2 and Kama Cross perform best with their 100mm stock fan at high speed, offering a better noise/performance ratio. When we turn down the fan speed the NCB comes out ahead slightly in both noise and temperature results. Performance wise the Kama Cross is trailing the Katana 2 by ~2-3°C. At low fan speed the Katana 2 has identical results as the Hyper TX from Coolermaster.
- The Scythe ANDY holds its own against the larger heatsinks, its stock fan is quieter than the NCB but also less performing, -3dBA but + 1°C. The ANDY trails the Scythe Ninja with only 1°C when the NCB is set to High speed! At low speed however the difference is much larger at 8°C. The stock fan at low speed offers better performance than the NCB but not by much (1.5°C).
- The GeminII with two low noise fans (the NCB and Papst) at high speed sits in the middle of the ranking, not threatening the large tower coolers (Ninja, Tower 120, NPH BIG)
- The Tuniq Tower 120 at high fan speed (with the NCB) ranks very high, besting the Scythe Ninja by close to 4°C. But at low fan speed its trailing the Ninja by 1.5°C.
i dont care about noise, i care about tempreture only.
so the results is that:
intel stock = 62C
and from ur qoute they say:
The Scythe ANDY holds its own against the larger heatsinks, its stock fan is quieter than the NCB but also less performing, -3dBA but + 1°C"
the stock fan is more quite but is less performing, aka, has another 1C so still stock intel cooler has lower tempreture than ANDY at LOW speed.
now if we turn ANDY to 2000RPM its surly way beter than intel stock cooler, but it will not be quit any more, and lots of the other coolers are beter than andy including the CNPS9700, since they clearly state that the stock cooler doesnt improve perfomance than the NCP
u don't care about the noise? why didn't u say so
take the andy and pair it up with a DELTA fan or even TT SF2 you'll have gr8 performance
but!!! u talk about NCB fan
u don't get it with andy, u get the stock fan
and so what u need to read is this
u don't use a fan on low so why read only the data from it?
but we talk about 9500 or did u forget not 9700
u really don't have many options with the 13CM limit
yeah i know i dont have much options
1)how risky is it overclock with the intel stock cooler?
note i have this case, it has a side panel with 2 fans
http://legionhardware.com/document.php?id=284
2)do u think if i removed the 2 fans wich will remove the 13cm limit and got the tuniq tower or some like it would i get beter perfomance than having ANDY with the 2 fans???
3)the 2 fans will be very close to andy's fan (about 0.5cm) will that help or make things worse????
4) how risk it is to keep my CPU(E6600) overclocled to 3.2GHz ?? can stores know that it have been overclocking it and void warranty?
5) same as 4 but with intel stock cooler and the 2fan's panel
