כמה אחוזי פגמים יש לXBOX 360 ?
מיקרוסופט אומרת בין 5 ל4 אחוז
בסקר באחד האתרים הגיעו ל61 אחוז
Xbox 360: 61 Per Cent Failure Rate?
When it comes to the "Three Rings Of Death" (TROD for short), the Xbox 360 is becoming all to familiar with the term. So just how bad is Microsoft's next-gen console's failure rate? Take a look at this survey, which takes a fresh look into the problem, and attempts to update the failure rate situation.
quote:
Everywhere you turn, theres another story of a broken 360 and anyone you speak to has either had their console fail on them, or knows of many others who have. It really is the problem that simply wont go away.
Well, with Microsoft sticking to its 4 5% failure rate story, we figured wed have another look at our survey, which has at the time of writing attracted 3780 submissions and 2355 comments the majority of which are from angry owners who feel cheated by the Xbox 360s build quality and Microsofts after sales service.
One example of this was left by Gamertag Jarandco, who commented: Had original Xbox 360 [die] after about 14 months. Due to it being out of warranty had to pay £80 for it to be fixed, well for them to send me a different one anyway I disagree with having to pay that after they repaired the American 360s for free, they werent very helpful on the phone either!
At the time of writing, 2,315 (61 per cent) responses to the survey have complained that theyve got through at least one console, with many having got through even more than that. Obviously we accept that our figures are probably skewed towards the negative, but such a response is still unprecedented and were sure that if in a years time we ran a similar survey on our sister site PS-Gamer.com we wouldnt get anywhere near such a response. In fact, we may well do this Anyway, its not just us who believes this problem is beyond that of other consoles, after getting through 3 consoles, Gamertag henk live left the message: MS dare to say they don't have a problem (Yeah right), I have been a gamer for 25 years and I never have seen this kind of reliability with a console.
http://www.maxconsole.net/?mode=news&newsid=17067
וזה מאתר של חובבי XBOX לא אתר של פאנים מנינטנדו או סוני
אלו הם לא נתונים מדויקים בכלל, הם בדקו רק לפי מי שהגיב וזה ממש ממש מטומטם!!!
מה שכן, אני בעצמי לא הייתי לוקח סיכון עם הגרסאות הנוכחות של ה-360!
אלוהים כמה שאתה מפגר.
לא אמרתי שזה נתונים אמיתים
זה רק נתוני סקר לא רישמי
אני גם לא חושב שיש באמת 60% קונסולות שנהרסו
אני כן חושב שיש הרבה יותר מ4-5% שמיקרוסופט אומרת
ודובי זובי אני מטומטם למה?
בינתיים רוב הערכות שלי צדקו בניגוד אליך שהערכה שמיקרוסופט לא תרחיק מישתמשי לייב זהב
בגלל שהם משלמים לשרות נכשלה קשות ;D ;D ;D
אם מיקוסופט תגיד שזה בין 15-20 אחוז היא תפשוט את הרגל..
אלא אם כן היא לא תדחה לכלכך הרבה זמן את השקת המעבדים של ה-65nm!
למה לעזאזל הם דוחים את זה לכלכך הרבה זמן??? אם הם לא רוצים לדפוק את שאר הגרסאות, אז שלפחות היו עושים הבדלי מחירים משמעותיים...
היא לא תפשוט את הרגל
כי ה360 גם ככה לא תורם לה לריווחיות
מיקרוסופט מרוויחה מהWIN ואופיס בעיקר
לקונסולות היא ניכנסה במחשבה לעתיד והיא תיהיה מוכנה להפסיד עוד הרבה
כדי לנסות לימנוע מסוני ונינטנדו לגנוב תשוק העתידי של קונסולות שיכולות לבצע דברים של מחשב
ובכך לבטל להרבה צרכנים תצורך בWIN
דובי זובי קיבלת אזהרה, זוהי אזהרה שלישית שלך אתה במיוט לשבועיים.
אוקיי,ומה אתה רוצה?
אבל אתה לא יכול להגיד שה עדין מפסידים עוד כסף בכלל דחיית המעבדים קטנים.
הרבה מפחדים מעניין ההתחממות, וגם אלה שמעדיפים 360, לא רוצים לחכות כלכך הרבה זמן, ולכן הם ילכו על ה-PS3 או משהו אחר...
וכמה כבר זמן לוקח לעבוד על זה???
אני מקווה שהסיבה לדחייה היא בגלל שהם רוצים לעבוד על עוד כמה באגים במכשיר
לפי מה שהבנתי מיקרוסופט כבר לא מפסידים על כל פרימיום שנמכר כמו שהיה בהתחלה
ובקשר למעבדים החדשים -אני לא חושב שהם רוצים עוד פעם מוצר אם יחס פגמים כל כך גדול
ויש גם תמוניטין של AMD וIBM שמיצרים תכרטיס הגרפי ותמעבד
ככה שהבא בטח יהיה הרבה יותר אמין
הערכה שלי בקריסמס הבא הם יוציאו את זה ויעשו פירסום גדול
כדי לנסות ליפגוע בנינטנדו שלפי כמה ערכות הולכת להיות ענקית בקריסמס הבא
כמה משחקים טובים יש לWII?
נינטנדו אומרת בין 3-4
בסקר באחד האתרים הגיעו למשחק אחד, שקשור במקרה למריו!
די קרירין די, בסדר, הXBOX מת, לפחות יש לו משחקים טובים.
זה לא נראה שלמיקרסופט היה אכפת כלכך שה-360 היה מלא בדפיקות!!!
קודם כל תראה לי תסקר הזה ?
ושנית תיבדוק אם זה לא מאתר לא נטרלי
אני נתתי לך סקר מאתר של חובבי XBOX ואם כבר אם היו צריכים להיות בעד מיקרוסופט
שנית לWII יש כרגע 3 משחקים מאוד טובים:
1-זלדה TP
2-סופר מאריו נייר
3-המשחק החדש של אוריו
חוץ מיזה יש הרבה משחקים די טובים לדוגמה סוניק ומידן היו יותר טובים בWII לאומת גירסאות ה360
ותזכור שהWII רק בערך 6 חודשים בשוק לאומת ה360 ששנה וחצי בערך בשוק
עכשיו מאריו כדורגל כניראה יקבל ציון טוב בגלל המולטיפליר ואם לא יפשלו אם מטרויד 3 שיוצא באוגוסט
הוא גם יהיה גדול
ומשחקים כמו דרגון קווסט הבא וNiGHTS ו Soulcalibur Legends ועוד הרבה בפיתוח
ככה שתן זמן ותיראה איך הספריה של הWII תיתפתח מאוד
רק לפני יומים או קאפקום או נאמקו (לא זוכר) אמרו שהם מגדילים תפיתוח לWII
אוי, כאילו מאמר אחד של אתר אחד יצביע על כשלון ה-360 :s07::screwy:
אין, אתה מחפש את זה!
איך תפסת מהאתר הזה, מילא זה היה מאמר עם נתונים של מספרים ענקיים, אל תשאל מישמע כמה כבר אנשים השתתפו בו... אתה יודע שאתה מגזים מעל ומעבר...
