The BIOS Companion, The book that doesn't come with your motherboard
מומלץ בחום..למי שלא וגם למי שכן מבין מה יש בביוס וכל הפונקציות שלו ואיך הוא עובד
%7Boption%7D[http://img413.imageshack.us/img413/4361/20070511015149cv1.gif/img]
Inside your computer are several smaller ones, which must work together for best performance
Getting them to do this, rather than pulling against each other, can make quite a difference to how your machine behaves, but most come out of their boxes inadequately set up because there isn't enough time or incentive for the manufacturers to do it for you - they mostly choose standard CMOS settings to suit the widest circumstances (and keep BIOS problems to a minimum), which are often the slowest. The BIOS Companion explains those secret settings in the CMOS Setup and contains a wealth of data for troubleshooting, including Nasty Noises, Error and POST Codes (for your diagnostic card), and more - there are over 500 pages. It helps you cope with CMOS problems and reduces the need to call for tech support. Download the first 28 pages of BIOS information here (includes Table of Contents).
By:P Phil Croucher
Publisher:BookSurge Publishing
Number Of Pages: 494
Publication Date: 2004-12-17
ISBN / ASIN: 0968192807
Format: PDF
2.2 MB
download:
Code:
http://rapidshare.com/files/30330444/The_Ultimate_BIOS_Guide.rar
or
http://www.megaupload.com/?d=BMIRG6R0
תוריד בבקשה את הלינקים
