office
יש לי דיסק התקנה צריך להכניס PRODUCT KEY ב5 חלונות עם 5 תווים בכל אחד.
באחד הקבצים יש לי את ה PRODUCT KEY
ProductCode={90260409-6002-11D3-8CFE-0150048383C9}איך לרשום את הקוד כדי שאוכל להתקין? בססמא הנ"ל יש 32 אותיות\מספרים
אני יודע שהתוכנה הותקנה מהCD הזה בעבר...
; Microsoft Office SETUP.EXE settings file.
[MSI]
; The MSI section gives the name of the MSI file to install. This file must be in
; the same folder as Setup.exe, and both must be in the root of the installation
; tree.
MSI=OWC10.MSI
[Product]
ProductCode={90260409-6002-12D3-8CFE-0150048383C9}
ProductName=Microsoft Office XP Web Components
ProductVersion=11.0.5614.0
Recache=1
[MST]
; The MST section gives the full path to a transform that should be applied.
;MST1=\\server\share\some transform.mst
;MST1=D:\transforms\my transform.mst
[Options]
; The option section is used for specifying individual Installer Properties.
;USERNAME=Customer
;COMPANYNAME=my company
;INSTALLLOCATION=C:\Program Files\MyApp
[Display]
; The diplay section is used for overriding the default UI
; Value Default Description
; Display full Option to override the default UI
; [none, quiet, basic, reduced, full]
; CompletionNotice Yes Option to display a setup completion
; notice for otherwise quiet setup
;Display=None
;CompletionNotice=Yes
[Logging]
; The logging section provides settings for controlling the Setup log files.
; Type vpiwaeo Logging modes
; [a, c, e, i, m, o, p, r, u , v,
; w, *, +]
; Path %TEMP% Path to create logfiles
; Template SetupLog(*).txt File name for log file should end in
; "(*).txt"; the * is replaced with a 4
; digit number to make the file name unique
Template=Microsoft Office XP Web Components Setup(*).txt
Type=piwaeo
;Path=\\MyServer\logfiles\
;Template=Product %UserName%(*).txt
[MinOSRequirement]
; MinOSRequirement is used for defining the minimal OS requirement for
; installing the product.
VersionNT_1=500
WindowsBuild_1=2195
ServicePackLevel_1=3
[Cache]
; The cache section provides settings for caching the install source locally
; CDCACHE 2 Option to specify cache level
; [auto, 0, 1, 2]
; LOCALCACHEDRIVE <predefined> Option to specify a drive to cache
; the install source to
; DELETABLECACHE 1 Option to display UI to remove the
; cache at the end of setup [0,1]
; PURGE 0 Option to always remove cache at end of
; setup [0,1]
CDCACHE=auto
;LOCALCACHEDRIVE=C:\
DELETABLECACHE=1
PURGE=0
ה Product Key וה ProductCode הם שתי דברים שונים...
אין לך אפשרות להכניס שם דבר כזה...
בדרך כלל ה Key מגיע על הקופסא של הדיסק בספר או על הקופסא של הדיסק אבל לא בקבצים בפנים..
