רכישת נגן ה HD ל XBOX 360 מארה"ב
היי
רציתי לשאול אם יש פה מישהו שרכש בארה"ב את נגן ה HD החיצוני של ה XBOX 360 ויכול לומר לי איזה ספק אני צריך כדי לעבוד איתו במתח 220V.
שנית האם חיברתם אותו למחשב ואתם יכולים לספר על החוויה.
הוא מתחבר דרך USB 2
ככה שאני לא חושב שאתה צריך לחבר אותו לחשמל בנפרד -
HD DVD Player
The Xbox 360 with HD DVD Player and universal Media Remote at CEATEC 2006
Bill Gates announced during his keynote speech at CES 2006 that an external HD DVD drive would be released for the 360 during 2006.[4] At E3 2006, Microsoft officially presented the external HD DVD drive. The HD DVD drive launched in North America on November 7, 2006, retailing for US$199.99, and in Japan on November 17, 2006 at a price of ¥25,900 (US$220).[5] The drive is able to play HD DVD movies, but all Xbox 360 games will continue to use DVD-9 media.[6]
The HD DVD drive does not have any A/V output; it connects to the Xbox 360 via USB. All of the Video/Audio processing is done on the 360 itself, and then the signal is output on whatever connection the Xbox 360 is using, be that Component, VGA, or HDMI (on the Elite). The unit can also function as a USB hub with two ports on the rear, along with a spot for the Xbox 360 Wireless Adapter to clip on to.
Despite the fact that it is an external drive for the Xbox 360, it can be connected to a normal PC with a USB 2.0 cable.[7] Windows will recognize it as a DVD drive, and drivers have surfaced so Windows will see it as the Xbox 360 HD DVD drive. Mac OS X, however, natively recognizes it. Windows Vista has native drivers.
As of December 31, 2006, 92,000 Xbox 360 HD DVD drives have been sold in the United States.[8]
Peter Moore has stated that if HD DVD loses the format war, Microsoft may also release an external Blu-ray drive.[9] This was later denied by Microsoft. According to Japan's chief of Xbox operations, Yoshihiro Maruyama, Microsoft will not release Xbox 360 games in the new disc formats. On October 31, 2006, Microsoft released an update for the Xbox 360 that allows it to support native 1080p games and movies[10].
On February 2, 2007, Microsoft announced that the HD DVD player for the Xbox 360 will make its debut in Australia on March 29, 2007 retailing for AU$250.[11] The launch of the HD DVD player will coincide with the Australian release of the PlayStation 3, which was released six days prior to the HD DVD player launch. Similarly to the USA, the HD DVD player will be bundled with the Universal Media Remote and a copy of King Kong.
On February 28, 2007 the HD DVD player was released in the European market. In this case there was no movie bundled, only the player and Universal Media Remote
האם אתה בטוח שלא צריך לחבר לחשמל?
אם יש לו חיבור לחשמל אז כנראה שצריך,לא?
אני רואה בתמונה אחורית של הנגן שיש חיבור חשמלי .
כנראה חייב ספק שמוציא 12vDC , כי הUSB יכל לספק רק 5v ...
לא בטוח -תבדוק ברשת
דרך אגב האם לא חשוב כמה וואט הנגן צורך כדי להתאים ספק?
ב MANUAL רשום 12V@1.7A INPUT
תשמע , יכל להיות שהספק שמגיע שם אונברסלי כלומר 110 ~ 220 וולט 50/60Hz ...
ואפילו אם לא , אז שנאי פשוט יעשה את העבודה , כי לא מדובר על הספקים גדולים כאן .
כן אבל אני לא יודע איזה הספק צריך יש כל מיני הספקים.
אבל אני מאוד מקווה שהספק אוניברסלי.
תגיד למה החלטתה לקנות דווקה עכשיו תנגן הזה?
אין הרבה סירטי HD-DVD כרגע במיוחד בארץ
עדיין יש תחרות בין הבלו רי לHD-DVD
והנגן הזה לא נותן לך כלום במשחקי 360 וכניראה גם בעתיד לא ישמש להרצת משחקי 360
בנוסף הוא יקר מאוד יחסית למה שהוא נותן אז למה אתה רוצה אותו?
מי מדבר בכלל על סרטים בארץ.
קניתי אותו כי מצאתי אותו במחיר של DVD פשוט של פיוניר ועד שהם יחליטו שם מי מנצח יעבור עוד הרבה זמן ואני בינתיים יכול להנות מ HD במחיר זול.
1000 שקל ומעלה לא הייתי מוציא עליו אבל במחיר שקניתי פשוט חבל לפספס.
זה מזכיר לי את התקופה שקניתי פלזמה רגילה למרות שאמרו לי כדאי לקנות HD כי בקרוב יהיו שידורי HD.
עברו יותר משנתיים ומה קרה?כלום
הדבר היחיד שקרה זה שמחיר פלזמות ה HD ירדו לרמות של פלזמה רגילה אז.
מי אמר לך שבקרוב יהיו שידורי HD בכבלים\לווין
הHD זה לקונסולות \HD-DVD \בלו רי \ותוכניות שאתה מוריד מהרשת באיכות HD
ואתה אומר שקניתה פלזמה רגילה ובפלזמה רגילה לא תיראה תאיכות בכלל של הHD-DVD
כבר עדיף לך לקנות DVD איכותי במחיר הזה
גם ככה איפה תימצא מספיק סרטים עכשיו בארץ? ואתה תיצתרך לקנות טלוויזיה חדשה ויקרה כדי להפיק תתועלת מהנגן
סמוך עלי יש לי הכל גם פלזמה לטלוויזיה וגם LCD ל HD תנוח דעתך.
ויש לי DVD איכותי של דנון חוץ מזה.
