בעיה עם arch- xorg/gnome
הכל התחיל אחרי שעשיתי את העדכון האחרון
מאז אני מקבל שגיאה ב gdm
greeter application appears to ba crashed....
ניסיתי לטעון את gnome ב inittab במקום Daemon אותה שגיאה
עשיתי שכשיופעל שרת x
(start x)
גנום יעלה אוטומטי (ע"י עריכה של הקובץ xinitrc)
גם זה לא עובד
הנה הlog
X Window System Version 7.2.0
Release Date: 22 January 2007
X Protocol Version 11, Revision 0, Release 7.2
Build Operating System: UNKNOWN
Current Operating System: Linux myhost 2.6.20-ARCH #1 SMP PREEMPT Fri Apr 20 22:54:27 CEST 2007 i686
Build Date: 08 April 2007
Before reporting problems, check [url]http://wiki.x.org[/url]
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Tue Apr 24 18:31:03 2007
(==) Using config file: "/etc/X11/xorg.conf"
(==) ServerLayout "Simple Layout"
(**) |-->Screen "Screen 1" (0)
(**) | |-->Monitor "973"
(**) | |-->Device "6600"
(**) |-->Input Device "Evdev Mouse"
(**) |-->Input Device "Keyboard1"
(II) No default mouse found, adding one
(**) |-->Input Device "<default pointer>"
(WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi".
Entry deleted from font path.
(Run 'mkfontdir' on "/usr/share/fonts/100dpi").
(WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi".
(Run 'mkfontdir' on "/usr/share/fonts/75dpi").
(**) FontPath set to:
/usr/share/fonts/misc
(==) RgbPath set to "/usr/share/X11/rgb"
(==) ModulePath set to "/usr/lib/xorg/modules"
(WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
(II) No APM support in BIOS or kernel
(II) Loader magic: 0x81c44a0
(II) Module ABI versions:
X.Org ANSI C Emulation: 0.3
X.Org Video Driver: 1.1
X.Org XInput driver : 0.7
X.Org Server Extension : 0.3
X.Org Font Renderer : 0.5
(II) Loader running on linux
(II) LoadModule: "pcidata"
(II) Loading /usr/lib/xorg/modules//libpcidata.so
(II) Module pcidata: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 1.0.0
ABI class: X.Org Video Driver, version 1.1
(--) using VT number 7
(II) PCI: PCI scan (all values are in hex)
(II) PCI: 00:00:0: chip 10de,00e1 card 0000,0000 rev a1 class 06,00,00 hdr 00
(II) PCI: 00:01:0: chip 10de,00e0 card 1458,0c11 rev a2 class 06,01,00 hdr 80
(II) PCI: 00:01:1: chip 10de,00e4 card 1458,0c11 rev a1 class 0c,05,00 hdr 80
(II) PCI: 00:02:0: chip 10de,00e7 card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:1: chip 10de,00e7 card 1458,5004 rev a1 class 0c,03,10 hdr 80
(II) PCI: 00:02:2: chip 10de,00e8 card 1458,5004 rev a2 class 0c,03,20 hdr 80
(II) PCI: 00:05:0: chip 10de,00df card 1458,e000 rev a2 class 06,80,00 hdr 00
(II) PCI: 00:06:0: chip 10de,00ea card 1458,a002 rev a1 class 04,01,00 hdr 00
(II) PCI: 00:08:0: chip 10de,00e5 card f458,5002 rev a2 class 01,01,8a hdr 00
(II) PCI: 00:0a:0: chip 10de,00e3 card 1458,b002 rev a2 class 01,01,85 hdr 00
(II) PCI: 00:0b:0: chip 10de,00e2 card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:0e:0: chip 10de,00ed card 0000,0000 rev a2 class 06,04,00 hdr 01
(II) PCI: 00:18:0: chip 1022,1100 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:1: chip 1022,1101 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:2: chip 1022,1102 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 00:18:3: chip 1022,1103 card 0000,0000 rev 00 class 06,00,00 hdr 80
(II) PCI: 01:00:0: chip 10de,00f1 card 1682,2119 rev a2 class 03,00,00 hdr 00
(II) PCI: 02:0b:0: chip 11ab,4320 card 1458,e000 rev 13 class 02,00,00 hdr 00
(II) PCI: 02:0d:0: chip 1095,3512 card 1095,6512 rev 01 class 01,04,00 hdr 00
(II) PCI: End of PCI scan
(II) Host-to-PCI bridge:
(II) Bus 0: bridge is at (0:0:0), (0,0,2), BCTRL: 0x0008 (VGA_EN is set)
(II) Bus 0 I/O range:
[0] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) Bus 0 non-prefetchable memory range:
[0] -1 0 0x00000000 - 0xffffffff (0x0) MX[B]
(II) Bus 0 prefetchable memory range:
(II) PCI-to-ISA bridge:
(II) Bus -1: bridge is at (0:1:0), (0,-1,-1), BCTRL: 0x0008 (VGA_EN is set)
(II) PCI-to-PCI bridge:
(II) Bus 1: bridge is at (0:11:0), (0,1,1), BCTRL: 0x000c (VGA_EN is set)
(II) Bus 1 non-prefetchable memory range:
[0] -1 0 0xf8000000 - 0xfaffffff (0x3000000) MX[B]
(II) Bus 1 prefetchable memory range:
[0] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
(II) Bus 2: bridge is at (0:14:0), (0,2,2), BCTRL: 0x0004 (VGA_EN is cleared)
(II) Bus 2 I/O range:
[0] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[1] -1 0 0x00009400 - 0x000094ff (0x100) IX[B]
[2] -1 0 0x00009800 - 0x000098ff (0x100) IX[B]
[3] -1 0 0x00009c00 - 0x00009cff (0x100) IX[B]
[4] -1 0 0x0000a000 - 0x0000a0ff (0x100) IX[B]
[5] -1 0 0x0000a400 - 0x0000a4ff (0x100) IX[B]
[6] -1 0 0x0000a800 - 0x0000a8ff (0x100) IX[B]
[7] -1 0 0x0000ac00 - 0x0000acff (0x100) IX[B]
(II) Bus 2 non-prefetchable memory range:
[0] -1 0 0xfb000000 - 0xfcffffff (0x2000000) MX[B]
(II) Bus 2 prefetchable memory range:
[0] -1 0 0x50000000 - 0x500fffff (0x100000) MX[B]
(--) PCI:*(1:0:0) nVidia Corporation NV43 [GeForce 6600/GeForce 6600 GT] rev 162, Mem @ 0xf8000000/24, 0xe0000000/28, 0xf9000000/24
(II) Addressable bus resource ranges are
[1] -1 0 0x00000000 - 0x0000ffff (0x10000) IX[B]
(II) OS-reported resource ranges:
[0] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[1] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[2] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[3] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[4] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[5] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
(II) PCI Memory resource overlap reduced 0xf0000000 from 0xf7ffffff to 0xefffffff
(II) Active PCI resource ranges:
[0] -1 0 0xfc004000 - 0xfc0041ff (0x200) MX[B]
[1] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[2] -1 0 0xfd001000 - 0xfd001fff (0x1000) MX[B]
[3] -1 0 0xfd000000 - 0xfd000fff (0x1000) MX[B]
[4] -1 0 0xfd005000 - 0xfd0050ff (0x100) MX[B]
[5] -1 0 0xfd004000 - 0xfd004fff (0x1000) MX[B]
[6] -1 0 0xfd003000 - 0xfd003fff (0x1000) MX[B]
[7] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[8] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[9] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[10] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[11] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[12] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[13] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[14] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[15] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[16] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[17] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[18] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[19] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[20] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[21] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[22] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[23] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[24] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[25] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[26] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[27] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[28] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[29] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) Active PCI resource ranges after removing overlaps:
(II) OS-reported resource ranges after removing overlaps with PCI:
(II) All system resource ranges:
[4] -1 0 0xfc004000 - 0xfc0041ff (0x200) MX[B]
[5] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[6] -1 0 0xfd001000 - 0xfd001fff (0x1000) MX[B]
[7] -1 0 0xfd000000 - 0xfd000fff (0x1000) MX[B]
[8] -1 0 0xfd005000 - 0xfd0050ff (0x100) MX[B]
[9] -1 0 0xfd004000 - 0xfd004fff (0x1000) MX[B]
[10] -1 0 0xfd003000 - 0xfd003fff (0x1000) MX[B]
[11] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[12] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[13] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[14] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[15] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[16] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[17] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[18] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[19] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[20] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[21] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[22] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[23] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[24] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[25] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[26] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[27] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[28] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[29] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[30] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[31] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[32] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[33] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[34] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[35] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
(II) LoadModule: "dbe"
(II) Loading /usr/lib/xorg/modules/extensions//libdbe.so
(II) Module dbe: vendor="X.Org Foundation"
Module class: X.Org Server Extension
ABI class: X.Org Server Extension, version 0.3
(II) Loading extension DOUBLE-BUFFER
(II) LoadModule: "extmod"
(II) Loading /usr/lib/xorg/modules/extensions//libextmod.so
(II) Module extmod: vendor="X.Org Foundation"
(II) Loading extension SHAPE
(II) Loading extension MIT-SUNDRY-NONSTANDARD
(II) Loading extension BIG-REQUESTS
(II) Loading extension SYNC
(II) Loading extension MIT-SCREEN-SAVER
(II) Loading extension XC-MISC
(II) Loading extension XFree86-VidModeExtension
(II) Loading extension XFree86-Misc
(II) Loading extension DPMS
(II) Loading extension TOG-CUP
(II) Loading extension Extended-Visual-Information
(II) Loading extension XVideo
(II) Loading extension XVideo-MotionCompensation
(II) Loading extension X-Resource
(II) LoadModule: "freetype"
(II) Loading /usr/lib/xorg/modules/fonts//libfreetype.so
(II) Module freetype: vendor="X.Org Foundation & the After X-TT Project"
compiled for 7.2.0, module version = 2.1.0
Module class: X.Org Font Renderer
ABI class: X.Org Font Renderer, version 0.5
(II) Loading font FreeType
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="NVIDIA Corporation"
compiled for 4.0.2, module version = 1.0.9755
ABI class: X.Org Server Extension, version 0.1
(II) Loading extension GLX
(II) LoadModule: "nvidia"
(II) Loading /usr/lib/xorg/modules/drivers//nvidia_drv.so
(II) Module nvidia: vendor="NVIDIA Corporation"
Module class: X.Org Video Driver
(II) LoadModule: "evdev"
(II) Loading /usr/lib/xorg/modules/input//evdev_drv.so
(II) Module evdev: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.0
Module class: X.Org XInput Driver
ABI class: X.Org XInput driver, version 0.6
(II) LoadModule: "kbd"
(II) Loading /usr/lib/xorg/modules/input//kbd_drv.so
(II) Module kbd: vendor="X.Org Foundation"
(II) LoadModule: "mouse"
(II) Loading /usr/lib/xorg/modules/input//mouse_drv.so
(II) Module mouse: vendor="X.Org Foundation"
compiled for 7.1.1, module version = 1.1.1
(II) NVIDIA dlloader X Driver 1.0-9755 Mon Feb 26 23:23:13 PST 2007
(II) NVIDIA Unified Driver for all Supported NVIDIA GPUs
(II) Primary Device is: PCI 01:00:0
(--) Assigning device section with no busID to primary device
(--) Chipset NVIDIA GPU found
(II) Loading sub module "fb"
(II) LoadModule: "fb"
(II) Loading /usr/lib/xorg/modules//libfb.so
(II) Module fb: vendor="X.Org Foundation"
ABI class: X.Org ANSI C Emulation, version 0.3
(II) Loading sub module "wfb"
(II) LoadModule: "wfb"
(II) Loading /usr/lib/xorg/modules//libwfb.so
(II) Module wfb: vendor="NVIDIA Corporation"
compiled for 7.1.99.2, module version = 1.0.0
(II) Loading sub module "ramdac"
(II) LoadModule: "ramdac"
(II) Loading /usr/lib/xorg/modules//libramdac.so
(II) Module ramdac: vendor="X.Org Foundation"
compiled for 7.2.0, module version = 0.1.0
(II) resource ranges after xf86ClaimFixedResources() call:
(II) resource ranges after probing:
[15] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B]
[16] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B]
[17] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B]
[18] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[19] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[20] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[21] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[22] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[23] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[24] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[25] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[26] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[27] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[28] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[29] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[30] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[31] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[32] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[33] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[34] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[35] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[36] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[37] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[38] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[39] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B]
[40] 0 0 0x000003c0 - 0x000003df (0x20) IS[B]
(II) Setting vga for screen 0.
(**) NVIDIA(0): Depth 24, (--) framebuffer bpp 32
(==) NVIDIA(0): RGB weight 888
(==) NVIDIA(0): Default visual is TrueColor
(==) NVIDIA(0): Using gamma correction (1.0, 1.0, 1.0)
(**) NVIDIA(0): Enabling RENDER acceleration
(II) NVIDIA(0): NVIDIA GPU GeForce 6600 GT at PCI:1:0:0 (GPU-0)
(--) NVIDIA(0): Memory: 131072 kBytes
(--) NVIDIA(0): VideoBIOS: 05.43.02.57.00
(II) NVIDIA(0): Detected AGP rate: 8X
(--) NVIDIA(0): Interlaced video modes are supported on this GPU
(--) NVIDIA(0): Connected display device(s) on GeForce 6600 GT at PCI:1:0:0:
(--) NVIDIA(0): Samsung SyncMaster (CRT-1)
(--) NVIDIA(0): Samsung SyncMaster (CRT-1): 400.0 MHz maximum pixel clock
(II) NVIDIA(0): Assigned Display Device: CRT-1
(II) NVIDIA(0): Validated modes:
(II) NVIDIA(0): "1280x1024"
(II) NVIDIA(0): "1024x768"
(II) NVIDIA(0): "800x600"
(II) NVIDIA(0): "640x480"
(II) NVIDIA(0): Virtual screen size determined to be 1280 x 1024
(--) NVIDIA(0): DPI set to (104, 113); computed from "UseEdidDpi" X config
(--) NVIDIA(0): option
(--) Depth 24 pixmap format is 32 bpp
(II) do I need RAC? No, I don't.
(II) resource ranges after preInit:
[0] 0 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B]
[1] 0 0 0xe0000000 - 0xefffffff (0x10000000) MX[B]
[2] 0 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B]
[3] -1 0 0x00100000 - 0x3fffffff (0x3ff00000) MX[B]E(B)
[4] -1 0 0x000f0000 - 0x000fffff (0x10000) MX[B]
[5] -1 0 0x000c0000 - 0x000effff (0x30000) MX[B]
[6] -1 0 0x00000000 - 0x0009ffff (0xa0000) MX[B]
[7] -1 0 0xfc004000 - 0xfc0041ff (0x200) MX[B]
[8] -1 0 0xfc000000 - 0xfc003fff (0x4000) MX[B]
[9] -1 0 0xfd001000 - 0xfd001fff (0x1000) MX[B]
[10] -1 0 0xfd000000 - 0xfd000fff (0x1000) MX[B]
[11] -1 0 0xfd005000 - 0xfd0050ff (0x100) MX[B]
[12] -1 0 0xfd004000 - 0xfd004fff (0x1000) MX[B]
[13] -1 0 0xfd003000 - 0xfd003fff (0x1000) MX[B]
[14] -1 0 0xf0000000 - 0xefffffff (0x0) MX[B]O
[15] -1 0 0xf9000000 - 0xf9ffffff (0x1000000) MX[B](B)
[16] -1 0 0xe0000000 - 0xefffffff (0x10000000) MX[B](B)
[17] -1 0 0xf8000000 - 0xf8ffffff (0x1000000) MX[B](B)
[18] 0 0 0x000a0000 - 0x000affff (0x10000) MS[B](OprD)
[19] 0 0 0x000b0000 - 0x000b7fff (0x8000) MS[B](OprD)
[20] 0 0 0x000b8000 - 0x000bffff (0x8000) MS[B](OprD)
[21] -1 0 0x0000ffff - 0x0000ffff (0x1) IX[B]
[22] -1 0 0x00000000 - 0x000000ff (0x100) IX[B]
[23] -1 0 0x0000a400 - 0x0000a40f (0x10) IX[B]
[24] -1 0 0x0000a000 - 0x0000a003 (0x4) IX[B]
[25] -1 0 0x00009c00 - 0x00009c07 (0x8) IX[B]
[26] -1 0 0x00009800 - 0x00009803 (0x4) IX[B]
[27] -1 0 0x00009400 - 0x00009407 (0x8) IX[B]
[28] -1 0 0x00009000 - 0x000090ff (0x100) IX[B]
[29] -1 0 0x0000e000 - 0x0000e07f (0x80) IX[B]
[30] -1 0 0x0000dc00 - 0x0000dc0f (0x10) IX[B]
[31] -1 0 0x00000b70 - 0x00000b73 (0x4) IX[B]
[32] -1 0 0x00000970 - 0x00000977 (0x8) IX[B]
[33] -1 0 0x00000bf0 - 0x00000bf3 (0x4) IX[B]
[34] -1 0 0x000009f0 - 0x000009f7 (0x8) IX[B]
[35] -1 0 0x0000f000 - 0x0000f00f (0x10) IX[B]
[36] -1 0 0x0000c000 - 0x0000c07f (0x80) IX[B]
[37] -1 0 0x0000bc00 - 0x0000bcff (0x100) IX[B]
[38] -1 0 0x0000b800 - 0x0000b807 (0x8) IX[B]
[39] -1 0 0x00002000 - 0x0000203f (0x40) IX[B]
[40] -1 0 0x00001c00 - 0x00001c3f (0x40) IX[B]
[41] -1 0 0x0000e400 - 0x0000e41f (0x20) IX[B]
[42] 0 0 0x000003b0 - 0x000003bb (0xc) IS[B](OprU)
[43] 0 0 0x000003c0 - 0x000003df (0x20) IS[B](OprU)
(II) NVIDIA(0): Setting mode "1280x1024"
(II) Loading extension NV-GLX
(II) NVIDIA(0): NVIDIA 3D Acceleration Architecture Initialized
(II) NVIDIA(0): Using the NVIDIA 2D acceleration architecture
(==) NVIDIA(0): Backing store disabled
(==) NVIDIA(0): Silken mouse enabled
(II) Loading extension NV-CONTROL
(==) RandR enabled
(II) Initializing built-in extension MIT-SHM
(II) Initializing built-in extension XInputExtension
(II) Initializing built-in extension XTEST
(II) Initializing built-in extension XKEYBOARD
(II) Initializing built-in extension XC-APPGROUP
(II) Initializing built-in extension XAccessControlExtension
(II) Initializing built-in extension SECURITY
(II) Initializing built-in extension XINERAMA
(II) Initializing built-in extension XFIXES
(II) Initializing built-in extension XFree86-Bigfont
(II) Initializing built-in extension RENDER
(II) Initializing built-in extension RANDR
(II) Initializing built-in extension COMPOSITE
(II) Initializing built-in extension DAMAGE
(II) Initializing built-in extension XEVIE
(II) Initializing extension GLX
(II) evdev brain: Rescanning devices (1).
(**) Option "CorePointer"
(**) Evdev Mouse-usb-0000:00:02.0-4/input0: Core Pointer
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: Found 3 relative axes.
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: Configuring as pointer.
(**) Evdev Mouse-usb-0000:00:02.0-4/input0: WHEELRelativeAxisButtons: 4 5.
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: Found 8 mouse buttons
(**) Evdev Mouse-usb-0000:00:02.0-4/input0: Configuring 3 relative axes.
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: Configured 10 mouse buttons
(**) Option "CoreKeyboard"
(**) Keyboard1: Core Keyboard
(**) Option "Protocol" "standard"
(**) Keyboard1: Protocol: standard
(**) Option "AutoRepeat" "500 30"
(**) Option "XkbRules" "xorg"
(**) Keyboard1: XkbRules: "xorg"
(**) Option "XkbModel" "pc101"
(**) Keyboard1: XkbModel: "pc101"
(**) Option "XkbLayout" "us"
(**) Keyboard1: XkbLayout: "us"
(**) Option "CustomKeycodes" "off"
(**) Keyboard1: CustomKeycodes disabled
(WW) <default pointer>: No Device specified, looking for one...
(II) <default pointer>: Setting Device option to "/dev/input/mice"
(--) <default pointer>: Device: "/dev/input/mice"
(==) <default pointer>: Protocol: "Auto"
(**) Option "AlwaysCore"
(**) <default pointer>: always reports core events
(==) <default pointer>: Emulate3Buttons, Emulate3Timeout: 50
(**) <default pointer>: ZAxisMapping: buttons 4 and 5
(**) <default pointer>: Buttons: 9
(II) XINPUT: Adding extended input device "<default pointer>" (type: MOUSE)
(II) XINPUT: Adding extended input device "Keyboard1" (type: KEYBOARD)
(II) XINPUT: Adding extended input device "Evdev Mouse-usb-0000:00:02.0-4/input0" (type: MOUSE)
(II) XINPUT: Adding extended input device "evdev brain" (type: evdev brain)
(**) Evdev Mouse-usb-0000:00:02.0-4/input0: 3 valuators.
(**) evdev_btn.c (166): Registering 10 buttons.
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: Init
(II) evdev brain: Rescanning devices (2).
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: On
(--) <default pointer>: PnP-detected protocol: "ExplorerPS/2"
(II) <default pointer>: ps2EnableDataReporting: succeeded
(II) Evdev Mouse-usb-0000:00:02.0-4/input0: Off
(II) UnloadModule: "evdev"
FreeFontPath: FPE "/usr/share/fonts/misc" refcount is 2, should be 1; fixing.
