מי צריך מרובע ליבה כשיש 80?,יש סירטון עמ 7
אינטל מציגה 80 ליבות!
Intel last week demonstrated a working processor with 80 individual processing cores. Each core, or "tile" as Intel calls them, consists of a compute element and a router that allows each tile to connect to its neighbor. The chip can deliver more than 1 trillion floating point operations per second (teraflops), depending on how fast it's running. This is only a research project right now, as there are a lot of challenges involved in making an 80-core chip that's a practical option for PCs and servers.
Intel demonstrated the teraflop research chip in a briefing for reporters last week at a San Francisco hotel. It built a special cooling system for the chip and ran a few applications to demonstrate its performance. Intel had the chip running at around 3GHz during the demonstration, but has gotten it to run faster in its Oregon labs with a water-cooled system, said CTO Justin Rattner.
This is how Intel demonstrated the chip for reporters. Several power supplies were required, and Intel also needed to build a special motherboard. Engineers showed how Intel can obtain different levels of performance by tweaking the chips' clock speed and voltage supply while running an application that solved complex mathematical equations.
מקור:
http://news.com.com/2300-1006_3-6158220.html?tag=ne.gall.latest
Vara says the 80-core chip uses less than 100 watts of energy; a dual-core chip uses 60 to 70 watts and a quad-core uses 105 to 130 watts. Of course the numbers for the 80-core chip could be affected by the fact that it's lacking some functionality, but Rob Enderle, president and principal analyst of the Enderle Group, says it's still a significant accomplishment.
"We're quite literally creating a network mesh to let each little core communicate with the other cores and the rest of the system," says Vara. "The cores will want to know what the other cores will doing so they don't fight."
While it may take five to eight years to come out with a working 80-core chip, Vara says IT managers might start watching for what he calls "different flavors" of quad-core chips. "Maybe you'll have interim chips where they have more complex cores along with simpler cores, too."
מקור:
http://www.eetimes.com/showArticle.jhtml;jsessionid=OXQWATIR1TAX2QSNDLPSKH0CJUNN2JVN?articleID=196901229
עוד מידע:
http://www.theinquirer.net/default.aspx?article=37572
קרדיט:
http://www.xtremesystems.org/forums/showthread.php?p=2008022#post2008022
:o :o
  • תגובות 105
  • צפיות 12.1k
א) אני רוצה לראות אותם מוציאים את המעבד לשיווק בתוך פחות מ-5 שנים!!!.
ב) מעניין איזה קירור צריך בשבילו.
נ.ב
תודה על הכתבה
נ.ב 2 :)
http://img444.imageshack.us/my.php?image=cuteraflopschip550x367tl6.jpg
המעבד הוא 80 ליבות?... - או כל הלוח?
:lol: מה קרה לאינטל נגמר השכל? למה שלא יחברו את כל המפעלים שלהם בעולם לליבה אחת גדולה בחיי נפלו על השכל. :kopfpatsch:
הדבר המדהים שזה צורך פחות מ 100 וואט (K10 צורך יותר!)
חח ניראה לי תוך שנתיים נראה מחשבי HTPC עם 4 ליבות [סתם דוגמא לכמה זול זה יהיה] ומחשבים נייחים עם 20 ליבות
נו בטח! אף תוכנה לא תומכת בבלאגן הזה, אז יותר מ-90% מהליבות במוות קליני.
יצא משהוא ב-12 השנים האלו שיצרוך\יתמוך ב-80 ליבות :s05:
עוד לא יצא משחק שתומך ב-5 הם כבר מייצרים של 80.
כמובן שהתוכנה המתמטית שהם הריצו על זה תומכת בכל הליבות.
זה פרויקט ניסיוני, לא בשביל מחשב ביתי ובטח לא בשביל להריץ משחקים..
זה אשכרה ממש כואב לך לשמוע חדשות כאלו על אינטל
מדהים
מדהים
מה בדיוק הפריצת דרך פה? סתם ספין לבעלי המניות.
2 שאלות:
- באחת התמונות יש מעבד - המעבד עם כל ה-80 ליבות,זה כל הלוח? או רק המעבד?
- אם הם הצליחו לייצר מעבד של 80 ליבות - למה הם לא משתמשים באותה ארכיטקטורה? (ה-nm של המעבד)
שאני אזכיר לך את ההתלהבות שלך כשהציגו לראשונה את המרובע ליבות של AMD
ואז בסה"כ הריצו איתו TASK MANAGER
אתה רוצה להגיד לי שאתה באמת לא רואה בזה שום דבר חוץ מספין?
80 ליבות? צריכת חשמל?
נו עכשיו אתם עושים חשבון על צריכת חשמל, כשיש מים קרים באמבטיה את לא מדליק את הבוילר שעתיים?
מפתחים בקושי מסתדרים עם ה-CELL של סוני, אז תרוצה לסבך אותם עם 80 ליבות :kopfpatsch:
WOW
איפה כל הפוסטים על צריכת החשמל של הP4 בזמנו?
היתכן שהזכרון שלך כ"כ קצר?
אתה קולט שאפילו חלק מכפולי הליבה של AMD צורכים יותר?
שלא לדבר על ה4X4 :P
זה בסה"כ בשביל לבחון טכנולוגיות, אל תכנס לסרטים
הCELL הכניסו אותו בכלל בPS3 שהוא למשחקים.
המעבד הזה אינו מיועד למשחקים או לשוק הביתי :nono:
לשאלה פה באיזה קירור הוא מקורר:
כתוב קירור מים :)
