JAVA בFF
(ביריזי)
יש אפשרות להתקין נגן גאווה לFF?
יש מדריך בווסאפ אבל לא הבנתי אותו בגרוש... :nixweiss:
ממ קודם כל למה בריזי?
מעבר לזה תחליף את המקורות שלך (אם אני זוכר נכון) זה נמצא ב /etc/apt/sources.list
אפשר לערוך ככה
sudo gedit /etc/apt/sources.list
שם תמחק הכל ותשים את זה
deb-src [url]http://us.archive.ubuntu.com/ubuntu[/url] breezy main restricted
## Major bug fix updates produced after the final release of the
## distribution.
deb [url]http://us.archive.ubuntu.com/ubuntu[/url] breezy-updates main restricted
deb-src [url]http://us.archive.ubuntu.com/ubuntu[/url] breezy-updates main restricted
## Uncomment the following two lines to add software from the 'universe'
## repository.
## N.B. software from this repository is ENTIRELY UNSUPPORTED by the Ubuntu
## team, and may not be under a free licence. Please satisfy yourself as to
## your rights to use the software. Also, please note that software in
## universe WILL NOT receive any review or updates from the Ubuntu security
## team.
# deb-src [url]http://us.archive.ubuntu.com/ubuntu[/url] breezy universe
## Uncomment the following two lines to add software from the 'backports'
## repository.
## N.B. software from this repository may not have been tested as
## extensively as that contained in the main release, although it includes
## newer versions of some applications which may provide useful features.
## Also, please note that software in backports WILL NOT receive any review
## or updates from the Ubuntu security team.
# deb [url]http://us.archive.ubuntu.com/ubuntu[/url] breezy-backports main restricted universe multiverse
# deb-src [url]http://us.archive.ubuntu.com/ubuntu[/url] breezy-backports main restricted universe multiverse
deb [url]http://security.ubuntu.com/ubuntu[/url] breezy-security main restricted
deb-src [url]http://security.ubuntu.com/ubuntu[/url] breezy-security main restricted
# deb [url]http://security.ubuntu.com/ubuntu[/url] breezy-security universe
# deb-src [url]http://security.ubuntu.com/ubuntu[/url] breezy-security universe
deb [url]http://us.archive.ubuntu.com/ubuntu/[/url] breezy universe main restricted multiverse
אפשר לערוך ככה
## distribution.
## repository.
## team.
## repository.
תודה!
ננסה בהקדם.
בקשר לבריזי
למה לא?
פשוט כבר התקנתי ואין לי כוח להתקין שוב,וגם המחשב שלי די חלש
sudo apt-get install sun-java5-jre sun-java5-plugin
קרפד מה שאמרת זה רק אחרי שהוא ערך את המקורות
חשבתי שזה מובן, תודה על התיקון כפרע :-*
עשיתי כמו שאמרתם אבל אחרי שאני מחליף את הרשימה אני כותב את הפקודה והוא כותב לי:
doron@Doron:~$ sudo apt-get install sun-java5-jre sun-java5-plugin
E: Type '-src' is not known on line 1 in source list /etc/apt/sources.list
E[b]: רשימת המקורות לא ניתנת לקריאה.[/b]
נדפקה לי הרשימה?! :o
עריכה: הדבקתי שוב ועכשיו הוא כותב את השגיאות הבאות:
Reading package lists... Done
Building dependency tree... Done
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy/universe Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy_universe_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy/main Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy/restricted Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy_restricted_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy/multiverse Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy_multiverse_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy-updates/main Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy-updates_main_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy-updates/restricted Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy-updates_restricted_binary-i386_Packages) - stat (2 No such file or directory)W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy/universe Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy_universe_binary-i386_Packages) - stat (2 No such file or directory)
W: Couldn't stat source package list [url]http://us.archive.ubuntu.com[/url] breezy-updates/restricted Packages (/var/lib/apt/lists/us.archive.ubuntu.com_ubuntu_dists_breezy-updates_restricted_binary-i386_Packages) - stat (2 No such file or directory)W: You may want to run apt-get update to correct these problems
E: Couldn't find package sun-java5-jre
שימו לב לכל ה"Couldn't..."
לא עובד :(
עשיתי את המדריך של הבריזי כי מה שהבאת לי זה 6.10
זה:
http://ubuntuguide.org/wiki/Ubuntu#How_to_add_extra_repositories
והעתקתי את כל הרשימה בלי להוסיף ## או משהו דומה..
זה בסדר?
אני אעשה את ה6.10?
כשהחזרת את הrepositories של בריזי APT עבד?
אם כן תעשה:
sudo aptitude update && sudo aptitude upgrade
gksudo "update-manager -c -d"
מזה APT? :smile1:
sudo apt-get install fifa 2006
חח מה?!
לא ממש בא לי פיפא
זה סתם דוגמא
בוא נקצר תהליכים
הדבק את מה שרשום לך ב sources.list פה
ונתקדם משם
